    Weekly Calendar
    65 Posts 13 Posters 92.5k Views 21 Watching
    • K Offline
      KirAsh4 Moderator
      Harder part is going to be adding time display to the events … or, an hourly view. Thinking of real estate again. How many arrays can I nest … :)
        Mitchfarino Module Developer @KirAsh4
        @KirAsh4 I’m really looking forward to this being released, it looks great and gives a better view than the default list.
        Nice work, and thanks for putting the time in
          billp100
          Wow…Awesome work, that is pretty damn close to what I was envisioning…Thank you for your work
          • K Offline
            KirAsh4 Moderator
            The issue with taking up most of the screen is … that it’s not easily done. There are several “regions” on the screen that are constrained to a specific size so they don’t overlap others. Even on my large vertical screen, I can’t display a full 24 hour list. I’m flirting with the idea of limiting it to 12 hours (say 7am to 7pm) but that’s still stuff to just play with. As I said, this isn’t anywhere near even a test phase.
            • K Offline
              KirAsh4 Moderator
              Writing this code is not for the faint of heart. I will put out this warning: this may or may not result in the final piece. And the reason I say this is simply because of how difficult it is to deal with the various overlays. I may end up scrapping this idea completely and go for a different solution that may or may not end up looking similar. (Yes I’m aware that the time starts at midnight … the actual element takes up the whole screen, it’s been pushed down and ‘height restricted’.)
              • K Offline
                KirAsh4 Moderator
                And I seriously can not fathom that this thread has almost 1,000 views. Sheesh guys … you’re making me giddy. :)
                • W Offline
                  Wilco89
                  Looks very Nice, but I think this will fill my Screen a bit to much.
                  Maybe there is also 1 Step back and then with numbers under the title “starttime - endtime”?
                  • K Offline
                    KirAsh4 Moderator
                    Fill as it too wide? It’s merely following the regions defined within MM. Or do you mean height? At the moment it’s restricted. I can’t follow the regions there because otherwise there’s very little that can fit. So it’s an overlay “on top” of everything else and then I forcibly restrict the height. It’s not a perfect solution and it’s only being done to get the layout right.
                    As for a ‘step back’, I’m not sure what you mean. You mean going back to what I posted yesterday? Yeah that code didn’t go away (I never get rid of code that way). This right here is literally an exercise. I wanted to see what it would take, how much and whether it can be done. I also needed a hair cut, and this helped with me pulling my hair out at times. :)
                      Mitchfarino Module Developer @Wilco89
                      @Wilco89 yeah, it seems to take up too much real estate on screen.
                      So a lot of the reflection will be the calendar.
                      Must be hard to work with he regions available though
                      • W Offline
                        Wilco89 @KirAsh4
                        @KirAsh4 the width won’t be the problem, height will.
                        When you should use your yesterdays post and set startingtime and EndTime under the title of the appointment, it would be usefull for my mirror, otherwise it will fill my mirror too much.
                        I Hope you van make that to An module.
                        (Sorry for typo’s, using my phone with autocorrect (dutch))
                        • K Offline
                          KirAsh4 Moderator
                          Geen probleem. Yeah, since I’m just testing things out, I wouldn’t worry too much about what it looks like right now. I won’t make something that won’t work for people. I tend to make it all user configurable anyway, so don’t worry about that part.
                          • K Offline
                            KirAsh4 Moderator
                            Also, keep in mind that what you see there is a portion of a full mirror. When I’m at the office, I don’t have a vertical display, so I have to turn things off for it to display right. When I get home later, I’ll take another screen shot and see what it looks like then.
                            • W Offline
                              Wilco89 @KirAsh4
                              @KirAsh4 and I only was giving you opinion, and to help you through this little dilemma!
                              Im going to sleep now !
                              • K Offline
                                KirAsh4 Moderator
                                Opinions/suggestions are good. After all, I am making this for you guys, not just for me. :) Slaap lekker.
                                • K Offline
                                  KirAsh4 Moderator
                                  I haven’t forgotten, it’s just been two rather busy weeks. And I’m recovering from a failed server HD today/this weekend. Yay for backups … not so much fun when it’s terabytes of data. Anyway, I’ll get back this as soon as this mayhem stops, or at least subsides a bit.
                                  • T Offline
                                    trividar
                                    @KirAsh4 any news about the state of the development ? Thanks a lot for your work!!!
                                    • K Offline
                                      KirAsh4 Moderator
                                      I have some code written, but it’s nothing that’s working properly yet. It’s progressing rather slowly. Our office was recently bought out and we’re going through some painful changes that’s keeping everyone busy. I’ll have more time to focus on this once the dust settles.
                                        Hi @KirAsh4 , has this developed any further?
                                        The initial screenshots looked great!
                                          Hi @KirAsh4 - any news on this one?
                                          • K Offline
                                            KirAsh4 Moderator
                                            This was bound to come out publicly eventually … so here goes.
                                            The short answer: no, there has been zip, nada, none, zero progress on this, and here’s why:
                                            My daughter was hit and killed recently and my ability to sit, focus, and think is just about non-existent at the moment. Do I want to get back to this and finish it, sure. Can I? Probably, but I wouldn’t expect that to happen any time in the near future. There is a lot going on mentally and I’m just riding the waves of emotions right now.
                                            If anyone else wants to jump in and tackle this, please do so!
                                            And if no one does, I will eventually get back to it. But for now … no.
                                            M Y 2 Replies Last reply Reply Quote 0
                                            • 3 / 4
