    PIR Sensor turning display on/off over and over
    29 Posts 13 Posters 24.8k Views 13 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @elmerito25
      @elmerito25 I don’t have a mirror to test, but the code does the following
      from gpiozero import MotionSensor
      pir = MotionSensor(4)
      while True: #repeat this forever
          if pir.motion_detected: # if motion is detected print the message
              print("Motion detected!")
      after the print is done it immediately repeats the loop, because their is no sleep, timeout, delay or whatsoever in there. So for me the expected behaviour is that it prints over and over the same message. You could try to check motion not detected
      import time
          if not pir.motion_detected: # if no motion is detected print the message
              print("No motion detected!")
          time.sleep(1)
      run this and leave your sensor alone it will print just every second
      • H Offline
        hermlam
        I have the same issue. Maybe it’s related to WiFi. I tested the PIR with on older PI 2, no WiFi. Ran the Python script, working perfectly.
        After installing the PIR to my Mirror Pi, a Pi 3 screen wouldn’t go out. Installed the test Python script again and I am getting a lot of false positives, over 5 a minute. So PIR stays highs and screen stays on.
        I am thinking that WiFi is interfering with the PIR.
        Anybody any experiences or ideas?
        Thanks,
        Herman
        • F Offline
          fischi87
          by my mirror it works really nice. i have a question, it is possible the time to change right now it turns the display off after 4 minutes. i would like to change the time maybe 2 minutes or so.
          thanks
            Renfield
            It might be interference. Try installing a ferrite bead. The person whose site I’ve linked below had a very similar problem and describes how he fixed it.
            https://helentronica.com/2016/01/11/magic-mirror-with-motion-detector/
            Renfield
            cowboysdudeC johnnyboyJ 2 Replies Last reply Reply Quote 2
            • cowboysdudeC Offline
              cowboysdude Module Developer @Renfield
              @Renfield said in PIR Sensor turning display on/off over and over:
              Renfield
              It’s what I had to do with mine… they are very inexpensive…
              • E Offline
                elmerito25 @cowboysdude
                @cowboysdude said in PIR Sensor turning display on/off over and over:
                Renfield
                Thanks guys! Will try this once I get home tonight!
                E 1 Reply Last reply Reply Quote 1
                • E Offline
                  elmerito25 @elmerito25
                  @elmerito25 said in PIR Sensor turning display on/off over and over:
                  Renfield
                  Thanks @Renfield and @cowboysdude ! Followed your advice and found a ferrite bead on unused USB cable and got the PIR sensor working perfectly!
                    Renfield
                    Great to hear. I love it when a plan comes together.
                    Now I need to scrounge up a bead for my build.
                    Ren
                    • H Offline
                      hermlam
                      Hi all,
                      Thanks for the reactions. I ordered one and will test tomorrow.
                      Herman
                        cyberphox
                        i gave up on my PIR sensor cause this was happening to me…guess who is searching for a Ferrite bead tomorrow!!!
