    MMM-SpotifyConnectUI
    21 Posts 11 Posters 26.9k Views 12 Watching
      Cato Module Developer @alexyak
      @alexyak Not hard at all!
      Spotify-Connect-Web do this already… ;-)
      • O
        onetwankyfive
        I made the logo bigger and did a little CSS work so the logo was the closer to the same size as the album and text below it… (I also did some css work with the nest module)
        Love the module… Still trying to figure out the best way to get the spotify-connect-web to load on reboot/startup… Now I run a shell script with an & after it and then start the mirror…
        C 1 Reply Last reply
          Cato Module Developer @onetwankyfive
          @onetwankyfive Glad you liked the module. I’ve added instructions for running spotify-web-connect as a service in README .md on GitHub. Notice, it’s only in the Dev-branch at the moment…
          Feel free to submit PR on GitHub if your CSS is better - I’ll gladely add it if I like it too! ;-)
            Updated module to version 1.0.2.
            MMM-SpotifyConnectUI Change Log
            [1.0.2] - 2016-08-11
            Documentation
            • Added instructions on how to run spotify-web-connect as a service
            Fixed
            • Fixed styling issues
            [1.0.1] - 2016-08-07
            Documentation
            • Changed correct position-value in the config
            • Added Spotify dev/key-links
            • Used same cursor-syntax on all code samples
            • Some typos…
            • L
              luvien
              Hello!
              Thanks for this module. I’m wondering about a usecase.
              If I install this module, and I’m playing music from another device using my Spotify account, and not playing from the Rpi, will it display the right cover on the mirror?
              Thanks!
              LJ
                Cato Module Developer @luvien
                @luvien No, unfortunately not.
                Edit: It uses the API provided by spotify-connect-web. You can install spotify-connect-web on another device, though…
                Edit 2: spotify-connect-web is a third party client/API
                • L
                  luvien
                  Thank you for your answer!
                  I guess this module is better suited for my needs : [Last.FM] Music Scrobbler
                  LJ
                    Pbaan93
                    • N
                      nex0
                      Great module!
                      I have a question, can I listening music with him?
                      Sorry for reliving old post.
                        Cato Module Developer @nex0
                        @nex0 Not sure if I understand the question.
                        This module is only a front end for Spotify Connect Web and does not play music.
                        But IF your Raspberry Pi where you have installed
                        Spotify Connect Web (not the module) have speakers connected and IF you get your hands on a API key from Spotify then you can play music and see what song in my module.
                        N 1 Reply Last reply
                        • N
                          nex0 @Cato
                          @Cato Ok, I understand, thanks!
                          Another question… In spotify I get:
                          The libspotify key generation and retrieval service has been deprecated, along with libspotify.
                          You may apply to get a key using our App-key Request Form for private, individual usage. Bear in mind that you should do no new development using libspotify.
                          But when I request the key, they do not send it to me, does anyone have any news of this? Or another solution!
                          Thanks!
                          Y 1 Reply Last reply
                          • Y
                            yawns Moderator @nex0
                            @nex0
                            I had to submit the form twice. I waited several weeks after first key request, then just sent the same request again and received the key one or two days later
                            • A
                              Advokaten
                              Hello. Is there a workaround to use Spotify on the RPi? Like using the webplayer somehow, vlc, anything. I can’t find anything that works, so I figured I’d ask here.
                                B4rth
                                you can use mopidy as a alternative.
                                pro: you can use also soundcloud, youtube, webradio etc
                                cons: no spotify conect, you have to use a mpd app or the webpage
                                  schlachtkreuzer6
                                  newer spotify connect app - raspotify works out of the box:
                                  https://github.com/dtcooper/raspotify
                                  https://discourse.osmc.tv/t/howto-spotify-connect-support-via-raspotify-librespot/38348
                                  but there is no frontend yet
