    Activate Profiles (via MMM-ProfileSwitcher) using MMM-Remote-Control...
    7 Posts 4 Posters 5.1k Views 3 Watching
    • SnilleS
      Snille Module Developer
      Hi all,
      I’m trying to switch profiles with the MMM-Remote-Control module via notifications to the MMM-ProfileSwitcher module.
      But I can’t get it to work. I do get the MMM-ProfileSwitcher to “switch” but only to a profile called [object Object].
      My profile in this case is called “Snille”.
      The Profile Switcher work otherwise with the MMM-Touch-Navigation module, so it’s not broken otherwise. :)
      Iv’e tried with the following URL (and variants of that):
      http://MagicMirorIP:8080/remote?action=NOTIFICATION&notification=CURRENT_PROFILE&payload={“Profile”:“Snille”}
      As long as the “json” is ok at the end I get the “Switched to profile [object Object]” on the mirror. But, of course I don’t have any “[object Object]” profile. :)
      I do get a: {“status”:“success”} from the MMM-Remote-Control as well (as long as the “json” string is ok as well).
      Anybody have any idea? :)
        mortenbirkelund
        http://MagicMirorIP:8080/remote?action=NOTIFICATION¬ification=CURRENT_PROFILE&payload={Profile:“Snille”}
        What about if you remove the double quotes from Profile? Just a guess.
        SnilleS J 2 Replies Last reply Reply Quote 0
        • SnilleS
          Snille Module Developer @mortenbirkelund
          @mortenbirkelund {“status”:“Unexpected token P in JSON at position 1”}
          Tried that… :)
            Jopyth Moderator @mortenbirkelund
            @Snille It is not an object, that you are supposed to send, see the documentation, just a simple string, i.e. ...?action=NOTIFICATION&notification=CURRENT_PROFILE&payload=%22Snille%22.
            SnilleS 1 Reply Last reply Reply Quote 0
            • SnilleS
              Snille Module Developer @Jopyth
              @Jopyth said in Activate Profiles (via MMM-ProfileSwitcher) using MMM-Remote-Control...:
              %22Snille%22
              Oh! Works! :) I can’t believe that I did not try that… Thank you! :)
              • SnilleS
                Bonus for anyone who wounder why I wanted to do this…
                I’m a user of “Alexa” (Amazons Echo Dot). I have 6 dots in my house. I wanted to be able to interact with the mirror with Alexa. And, yes I know there are lot’s of modules and stuff out there for this. But I have tried and not been satisfied with different modules/solutions that I found.
                Now, It happens I already use a small software called “HA-Bridge” for controlling all kind of things using Alexa (for example all my lights via Z-Wave using a Fibaro HC2 controller). So this software can be configured to “visit” URL:s when called up on with a voice command though Alexa (in reality HA emulates a Philips HUE light that Alexa can “find” under “Smart House”, that give 3 different commands: On, off and dim.). This opens up a sea of opportunities as you can imagine. :)
                So, now I say: “Alexa, turn on Snilles Mirror” to view my profile. (Switches to my profile)
                Or: “Alexa, turn off Mirror Screen.” (Monitor off)
                Or: “Alexa, turn off Mirror” (Shutdown the mirror)
                And so on…
                Yes… Imagine the possibilities. :)
                ceddirrC 1 Reply Last reply Reply Quote 0
                • ceddirrC
                  ceddirr @Snille
                  @snille Hello Snilles how are you?
                  I’ve been stuck for ages trying to do the same thing (switch profile on demand) with scripts or Google Home. The reason is:
                  1. I can’t find any php or js function to (as you said) “visit” URL:s --> because you have to be in a browser
                  2. You can add commands on Google Home via IFTTT request, which only uses external IP!
                  Would you have any idea that could help me please?
                  Thank you very much for your help,
                  Cedric
