    Throwing down the gauntlet
    85 Posts 11 Posters 114.1k Views 11 Watching
      jbeck615 @strawberry 3.141
      @strawberry-3.141
      .region.top.right .MMM-WunderGround table.small td:nth-child(6) {
        display:none;
      .MMM-WunderGround .weathericon {
        font-size: 45%;
        line-height: 5px;
        display: inline-block;
        -ms-transform: translate(0, -3px); /* IE 9 */
        -webkit-transform: translate(0, -3px); /* Safari */
      .MMM-WunderGround .day {
        padding-left: 0;
      #  padding-right: 10px;
      .MMM-WunderGround .vcen {
         vertical-align: top;
      .MMM-WunderGround .weather-icon {
        padding-left: 0px;
        text-align: center;
        width:50px;
      .MMM-WunderGround .max-temp {
        padding-left: 0px;
        padding-right: 0;
      .MMM-WunderGround .min-temp {
      #  padding-left: 10px;
      #  padding-right: 0;
      .MMM-WunderGround .forecastText {
      #  padding-right: 0;
      #  word-wrap: break-word;
      #  text-align: right;
      #  rowspan: 0;
      .MMM-WunderGround .tableheader {
        font-size: 75%;
        text-align: center;
      .MMM-WunderGround .hour {
        font-size: 75%;
        text-align: center;
      .MMM-WunderGround .pop {
        font-size: 86%;
      .MMM-WunderGround .mm {
        font-size: 75%;
      .MMM-WunderGround .green {
        color: #83FFB3;
      .MMM-WunderGround .yellow {
        color: yellow;
      .MMM-WunderGround .red {
        color: #FF4C4C;
      .MMM-WunderGround .center {
      	text-align: center;
      .MMM-WunderGround .left {
      	text-align: left;
      .MMM-WunderGround .lpad {
      	padding-left: 10px;
      .MMM-WunderGround .currentWeatherIcon {
        font-size: 75%;
        line-height: 45px;
        width: 40%;
        height: 40%;
      .MMM-WunderGround .forecastWeatherIcon {
        font-size: 75%;
        line-height: 65px;
        width: 50%;
      .MMM-WunderGround .moonPhaseIcon {
        height: 34px;
        vertical-align: middle;
      .MMM-WunderGround .hrDivider {
              font-size: 10px;
      .MMM-WunderGround .sub {
          vertical-align: sub;
          font-size: smaller;
      .MMM-WunderGround .smaller {
          font-size: 60%;
        color: #FF1A1A;
        color: #0080ff;
        color: #6f6;
      .region.top.center .MMM-WunderGround table.small {
        display:none;
      .region.top.right .MMM-WunderGround table:not(.small) {
        display:none;
        display:none;
        jbeck615 @Mykle1
        @Mykle1 ive never touched any of the monthly calendar files until i added your lines above to the end of my mcal.css file and was curious if you had any thoughts as to why your numbers are aligned to the left (when facing monitor) of the abbreviated days and mine are aligned to the right? just curious
          @strawberry-3.141 the main config file and never touch the config files of each modules folder?
            Mykle1 Project Sponsor Module Developer @jbeck615
            @jbeck615 said in Throwing down the gauntlet:
            Those should have been added to your custom.css file within your css folder
            Are you talking about WunderGround still? If so, then mine are aligned to the right as well.
              There are no config files in each module folder. Anything inside the actual module folder is part of the module and should not be altered. You set up each modules configuration in the config.js file inside your config folder. After that, any customizing of each module should be done in the custom.css file in your css folder.
              This is the WunderGround entry in my config.js file. The setup of the module.
                  			module: 'MMM-WunderGround', // Just for current weather
                  			position: 'top_center',
                      		apikey: 'YOUR API KEY', // private; don't share!
                      		pws: 'pws:KNYNEWYO103', // Richmondtown Weather Station - Very Cool
              			currentweather: 1,
                      		coloricon: true,
              			animationSpeed: 5000,
                  			roundTmpDecs: 0,
                  			UseCardinals: 1,
              			windunits: "mph", // bft or mph
                  			module: 'MMM-WunderGround', // Just for forecast
                  			position: 'top_right',
                      		apikey: 'YOUR API KEY AGAIN', // private; don't share!
              			currentweather: 0,
                      		coloricon: true,
                      		hourly: '1',
                      		fctext: '1',
                      		fcdaycount: "10",
                      		fcdaystart: "1",
                      		hourlyinterval: "2",
                      		hourlycount: "1",
                      		alerttime: 10000,
                      		alerttruncatestring: "english:",
                  			roundTmpDecs: 0,
                  			UseCardinals: 1,
                  			layout: "vertical",
              			windunits: "mph",
                  			sysstat: "0"
              And this is the WunderGround entry in my custom.css file. To customize things like color, icons, position, size, etc…
              .region.top.right .MMM-WunderGround table th {
                display: none; /* removes icons above max-temp, min-temp and % chance of rain */
                color: #f66;
                color: #0ff;
                color: #f93;
                color: #6f6;
              .region.top.center .MMM-WunderGround table.small,   /* selector for ONLY current weather Thanks to Strawberry-3.141 */
              .region.top.right .MMM-WunderGround table:not(.small),   /* selector for ONLY weather forecast */
                display: none;    /* this line and line above selector for NO rain amount column */
              I hope this clears things up for you
              J 3 Replies Last reply Reply Quote 0
                jbeck615 @Mykle1
                @Mykle1 sorry i meant to say the js files not the config. i swear im not as dumb as im sounding here! however your clarification did make sense so thank you!
                  jbeck615 @Mykle1
                  @Mykle1 but just to make sure, changes only go in the config.js file in the config folder, dont touch the js files in each of hte modules, and if needed, modify the css files in each module correct? ive just been a bull in a china shop even if most of it is working well. thanks!
                  Mykle1M jproehlJ 2 Replies Last reply Reply Quote 0
                    Each module has a ReadMe that describes the config.js options. You’re not really changing the config.js file. You’re choosing options that the author has provided
                    Correct. Those are part of the module itself
                    You modify the custom.css file FOR each module, not IN the module folder
                      jbeck615 @Mykle1
                      @Mykle1 yep on the same page now! ill stop messing with the js files in each modules folder. thanks
                        You’re welcome. I did it too, at first
                        • jproehlJ Offline
                          jproehl @jbeck615
                          @jbeck615 The custom.css file is in the css directory in /pi/MagicMirror not within each module directory.
                            jbeck615 @jproehl
                            @jproehl yep i am aligned after getting that clarification earlier. HUGE thanks
                              jbeck615 @Mykle1
                              @Mykle1 quick question, at the bottom of the css coding above, what does “selector” mean? thanks again!
                              • strawberry 3.141S Offline
                                strawberry 3.141 Project Sponsor Module Developer @jbeck615
                                @jbeck615 it’s kind of a query to which elements you want a css rule to be applied
                                  cyberphox
                                  Almost accomplished this look today. Got some duplicate weather showing up I’m sure I can fix. The main problem I’m having is: No Realistic icons for weather at all. :(
                                    Mykle1 Project Sponsor Module Developer @cyberphox
                                    @cyberphox said in Throwing down the gauntlet:
                                    Are you using WunderGround weather? If so, make sure you have coloricon: true, in your config. Like this.
                                    			currentweather: 1,
                                            		coloricon: true,
                                        			roundTmpDecs: 0,
                                        			UseCardinals: 1,
                                      cyberphox @Mykle1
                                      @Mykle1 Definitely using WunderGround…got the colors changed and have coloricon: true…gonna go double check it again! lol
                                        cyberphox
                                        @Mykle1 ok so turns out all this time I was using an older WunderGround module. Once I did a git pull and updated - bam - there were the realistic icons!
                                        Now I have to play with widths! how did you manage to fit your calendar, date/weather, and weather forecast all along the top! LOL
                                          Yup, that’ll do it. You won’t forget that ever again, will ya? ;-)
                                          in custom.css
                                          body {
                                            margin: 20px; /* This made the entire screen have a 20px border. Thanks to Strawberry-3.141  */
                                            height: calc(100% - 40px);
                                            width: calc(100% - 40px);
                                          That gives you a margin of only 20pixels around the entire screen. You can go even closer but I didn’t want anything too close to the edge. That’s enough to gain you some more real estate. Also, I have my monitor set to its highest resolution. You might want to try that.
                                          Then I simply put calendar in top_left, date and weather both top_middle and weather forecast top_right.
                                            cyberphox @Mykle1
                                            @Mykle1 Tried adding the CSS and didn’t really seem like anything changed. Checked my monitor settings in Display settings and it said it detected my monitor at 1015x1856
                                            Maybe I’m not getting a full 1200x1920 resolution?
                                            Never mind…running tvservice -s shows 1920x1080 resolution…must be something little i am missing again!
                                            • 4 / 5
