    Automatic installation
    11 Posts 4 Posters 7.8k Views 1 Watching
      acdacd2
      On a raspi 3, when we use the automatic installation of mmv2, we received the error " curl comment not found"
      any idea to solve this ?
      thanks,
      • K Offline
        KirAsh4 Moderator
        It means you don’t have curl installed. Did you install the default Jessie OS, or Jessie-Lite? Did you use NOOBS to install the OS?
        The standard Jessie install (done from the Jessie image file) would have that installed for you already. From NOOBS, I don’t know. Guess I’ll have to try it.
        In the mean time, you can manually install curl with the following:
        'sudo apt-get update; sudo apt-get install curl'
        Say Y(es) to any additional packages it wants to install so that curl would work.
          acdacd2
          • Install jessie OS
          • curl ok
          • but same error = ligne 1 404 command no found
          • K Offline
            KirAsh4 Moderator
            What is the exact command you are trying to run? And what instructions are you trying to follow? Just in case it’s an outdated one …
              acdacd2
              this one
              curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
                acdacd2
                https://github.com/MichMich/MagicMirror/blob/master/README.md
                • K Offline
                  KirAsh4 Moderator
                  Then there’s still something wrong with your base OS install. We can go back and forth with this and not figure out what’s going on. That’s not ideal. A better solution is if you can start by following the complete tutorial that I wrote up yesterday (and will complete today). The parts already written is how to get the Raspberry Pi 3 setup, updated, and configured properly before you even try to install MM² on it. Please try to follow the steps there before you try to run the automatic installer again. There are a lot of step-by-step instructions complete with screen captures for you to follow along with.
                  https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
                    acdacd2 @KirAsh4
                    @KirAsh4 I will réinstall my rpi but there is no différence with your tutorial
                      acdacd2
                      ok found, the link yesterday was not the same v2-beta in place of master
                      ok now
                      • G Offline
                        gauka12345
                        can you please show the link ? did you managed to sot this ?
                          sdetweil @gauka12345
                          @gauka12345 use the scripts on my repo
                          read the readme for the commands to enter
