    Automatic installation
    11 Posts 4 Posters 7.2k Views 1 Watching
      acdacd2
      • Install jessie OS
      • curl ok
      • but same error = ligne 1 404 command no found
      • KirAsh4K Offline
        KirAsh4 Moderator
        What is the exact command you are trying to run? And what instructions are you trying to follow? Just in case it’s an outdated one …
          acdacd2
          this one
          curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
            acdacd2
            https://github.com/MichMich/MagicMirror/blob/master/README.md
            • KirAsh4K Offline
              KirAsh4 Moderator
              Then there’s still something wrong with your base OS install. We can go back and forth with this and not figure out what’s going on. That’s not ideal. A better solution is if you can start by following the complete tutorial that I wrote up yesterday (and will complete today). The parts already written is how to get the Raspberry Pi 3 setup, updated, and configured properly before you even try to install MM² on it. Please try to follow the steps there before you try to run the automatic installer again. There are a lot of step-by-step instructions complete with screen captures for you to follow along with.
              https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
                acdacd2 @KirAsh4
                @KirAsh4 I will réinstall my rpi but there is no différence with your tutorial
                  acdacd2
                  ok found, the link yesterday was not the same v2-beta in place of master
                  ok now
                  • G Offline
                    gauka12345
                    can you please show the link ? did you managed to sot this ?
                      sdetweil @gauka12345
                      @gauka12345 use the scripts on my repo
                      read the readme for the commands to enter
