    Automatic installation
    11 Posts 4 Posters 7.2k Views 1 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator
      What is the exact command you are trying to run? And what instructions are you trying to follow? Just in case it’s an outdated one …
        acdacd2
        this one
        curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
          acdacd2
          https://github.com/MichMich/MagicMirror/blob/master/README.md
          • KirAsh4K Offline
            KirAsh4 Moderator
            Then there’s still something wrong with your base OS install. We can go back and forth with this and not figure out what’s going on. That’s not ideal. A better solution is if you can start by following the complete tutorial that I wrote up yesterday (and will complete today). The parts already written is how to get the Raspberry Pi 3 setup, updated, and configured properly before you even try to install MM² on it. Please try to follow the steps there before you try to run the automatic installer again. There are a lot of step-by-step instructions complete with screen captures for you to follow along with.
            https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
              acdacd2 @KirAsh4
              @KirAsh4 I will réinstall my rpi but there is no différence with your tutorial
                acdacd2
                ok found, the link yesterday was not the same v2-beta in place of master
                ok now
                • G Offline
                  gauka12345
                  can you please show the link ? did you managed to sot this ?
                    sdetweil @gauka12345
                    @gauka12345 use the scripts on my repo
                    read the readme for the commands to enter
