    Sonos Module
    18 Posts 7 Posters 10.1k Views 6 Watching
      Atreo
      Hi Guys.
      Hope that some of you can help me.
      I have problems with my sonos module,
      On the mirror it`s only saying loading music.
      On my pi i get
      Sonos Update
      Failure Error: Connect Econnrefused 192.168.0.79
      I can access 192.168.0.79:5005 and change song and change volym and so on.
      Any ide why i can’t get any information on my mirror ???
      Kind regards
      Jonas
      • SnilleS Offline
        Snille Module Developer
        Hi @Atreo do you have the http-sonos-api installed on your mirror or on another device?
        I had problems before I ran on a raspberry Pi when I ran the mirror in Server mode. Don’t know why though. :)
        If you cant find it, make it and share it!
        Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
          Atreo
          Hi @Snille Thx for the reply.
          Yes i have sonos-http-api installed on my mirror,
          This is making me crazy, i like the ide to have the information on the mirror.
          Banging my head against the wall…
          • W Offline
            Wedee
            I have the Sonos mod running on my Mirror. I get the same thing when I run more than one speaker as a group. If I run each speaker as separate it will load each speaker fine. I haven’t bothered looking into it much as I rarely use the speakers in group mode…
              Atreo
              Thx for the info @Wedee, I only have one and i am stuck… = /
              Any one have any tips ?
              • SnilleS Offline
                @Atreo Do you get the “zones” up if you do: http://192.168.0.79:5005/zones ?
                You should get a list of all the zones and stuff. :)
                  Atreo
                  @Snille Yes i can my kitchen zone and i hole lot information what the sonos is playing.
                  SnilleS 2 Replies Last reply Reply Quote 0
                  • SnilleS Offline
                    Snille Module Developer @Atreo
                    @Atreo Hmm… Then it should be all good. Can you post your “MMM-Sonos” part of the config?
                    • SnilleS Offline
                      @Atreo This is my “MMM-Sonos” config part…
                      			module: "MMM-Sonos",
                      			header: "Spelas på SONOS",
                      			position: "top_center",
                      			classes: "",
                      				// The API is not om my RPi. It's on another server...
                      				apiBase: "http://ip-of-the-api",
                      				apiPort: 5005,
                      				showAlbumArt: true,
                      				showRoomName: true,
                      				showPausedZone: false,
                      				showStoppedRoom: false,
                      				preRoomText: 'Rum: ',
                      				preArtistText: 'Artist: ',
                      				preTrackText: 'Spår: ',
                      				preTypeText: 'Källa: ',
                      				animationSpeed: 1000,
                      				apiEndpoint: "zones",
                      				exclude: ["Living-Room-SUB"]
                        Atreo @Snille
                        @Snille Thx. I will check your setting vs my.
                        Trevligt att du har det på svenska = )
                        Tack återkommer strax
                        SnilleS 1 Reply Last reply Reply Quote 0
