    Sonos Module
    18 Posts 7 Posters 10.7k Views 6 Watching
    • W Offline
      Wedee
      I have the Sonos mod running on my Mirror. I get the same thing when I run more than one speaker as a group. If I run each speaker as separate it will load each speaker fine. I haven’t bothered looking into it much as I rarely use the speakers in group mode…
        Atreo
        Thx for the info @Wedee, I only have one and i am stuck… = /
        Any one have any tips ?
        • SnilleS Offline
          Snille Module Developer
          @Atreo Do you get the “zones” up if you do: http://192.168.0.79:5005/zones ?
          You should get a list of all the zones and stuff. :)
          If you cant find it, make it and share it!
          Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
            Atreo
            @Snille Yes i can my kitchen zone and i hole lot information what the sonos is playing.
            SnilleS 2 Replies Last reply Reply Quote 0
            • SnilleS Offline
              Snille Module Developer @Atreo
              @Atreo Hmm… Then it should be all good. Can you post your “MMM-Sonos” part of the config?
              • SnilleS Offline
                @Atreo This is my “MMM-Sonos” config part…
                			module: "MMM-Sonos",
                			header: "Spelas på SONOS",
                			position: "top_center",
                			classes: "",
                				// The API is not om my RPi. It's on another server...
                				apiBase: "http://ip-of-the-api",
                				apiPort: 5005,
                				showAlbumArt: true,
                				showRoomName: true,
                				showPausedZone: false,
                				showStoppedRoom: false,
                				preRoomText: 'Rum: ',
                				preArtistText: 'Artist: ',
                				preTrackText: 'Spår: ',
                				preTypeText: 'Källa: ',
                				animationSpeed: 1000,
                				apiEndpoint: "zones",
                				exclude: ["Living-Room-SUB"]
                  Atreo @Snille
                  @Snille Thx. I will check your setting vs my.
                  Trevligt att du har det på svenska = )
                  Tack återkommer strax
                  SnilleS 1 Reply Last reply Reply Quote 0
                  • SnilleS Offline
                    @Atreo Hehe, yes. But let’s keep it to English anyway. :)
                    You are using my “fork” of the “MMM-Sonos” right, if not some of the config-stuff will not work. :)
                    This is my fork: https://github.com/Snille/MMM-Sonos
                      Dicous
                      Can someone please share a working config? Please ^^
                      My following does not work:
                      module: 'MMM-Sonos',
                      	header: "Playing on SONOS",
                      	classes: "default everyone",
                      				apiBase: "http://localhost",
                      				apiPort: 5005,
                      				showAlbumArt: true,
                      				showRoomName: true,
                      				preRoomText: 'Raum: ',
                      				preTrackText: 'Lied: ',
                      				preTypeText: 'Quelle: ',
                      				exclude: []
                      • SnilleS Offline
                        Snille Module Developer @Dicous
                        @Dicous What happens, what does not work?
