Sonos Module
18 Posts 7 Posters 9.1k Views 6 Watching
    Atreo
    Hi Guys.
    Hope that some of you can help me.
    I have problems with my sonos module,
    On the mirror it`s only saying loading music.
    On my pi i get
    Sonos Update
    Failure Error: Connect Econnrefused 192.168.0.79
    I can access 192.168.0.79:5005 and change song and change volym and so on.
    Any ide why i can’t get any information on my mirror ???
    Kind regards
    Jonas
      Snille Module Developer
      Hi @Atreo do you have the http-sonos-api installed on your mirror or on another device?
      I had problems before I ran on a raspberry Pi when I ran the mirror in Server mode. Don’t know why though. :)
      If you cant find it, make it and share it!
      Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
        Atreo
        Hi @Snille Thx for the reply.
        Yes i have sonos-http-api installed on my mirror,
        This is making me crazy, i like the ide to have the information on the mirror.
        Banging my head against the wall…
        • W Offline
          Wedee
          I have the Sonos mod running on my Mirror. I get the same thing when I run more than one speaker as a group. If I run each speaker as separate it will load each speaker fine. I haven’t bothered looking into it much as I rarely use the speakers in group mode…
            Atreo
            Thx for the info @Wedee, I only have one and i am stuck… = /
            Any one have any tips ?
              @Atreo Do you get the “zones” up if you do: http://192.168.0.79:5005/zones ?
              You should get a list of all the zones and stuff. :)
                Atreo
                @Snille Yes i can my kitchen zone and i hole lot information what the sonos is playing.
                S 2 Replies Last reply Mar 7, 2017, 12:54 PM Reply Quote 0
                  Snille Module Developer @Atreo
                  @Atreo Hmm… Then it should be all good. Can you post your “MMM-Sonos” part of the config?
                    @Atreo This is my “MMM-Sonos” config part…
                    			module: "MMM-Sonos",
                    			header: "Spelas på SONOS",
                    			position: "top_center",
                    			classes: "",
                    				// The API is not om my RPi. It's on another server...
                    				apiBase: "http://ip-of-the-api",
                    				apiPort: 5005,
                    				showAlbumArt: true,
                    				showRoomName: true,
                    				showPausedZone: false,
                    				showStoppedRoom: false,
                    				preRoomText: 'Rum: ',
                    				preArtistText: 'Artist: ',
                    				preTrackText: 'Spår: ',
                    				preTypeText: 'Källa: ',
                    				animationSpeed: 1000,
                    				apiEndpoint: "zones",
                    				exclude: ["Living-Room-SUB"]
                    A 1 Reply Last reply Mar 7, 2017, 1:04 PM Reply Quote 0
                      Atreo @Snille
                      @Snille Thx. I will check your setting vs my.
                      Trevligt att du har det på svenska = )
                      Tack återkommer strax
                      S 1 Reply Last reply Mar 7, 2017, 1:18 PM Reply Quote 0
