    Layout problem
    9 Posts 4 Posters 6.6k Views 3 Watching
    • brobergB Offline
      broberg Project Sponsor @fiskaren
      @fiskaren in what regions have you placed your modules?
      I would suggest regions top_left and top_right for the clock and weather.
      And you probably have to change the font sizes to make it fit.
      Add this in to your custom.css file
      .xsmall {
        font-size: 15px;
        line-height: 20px;
      .small {
        font-size: 20px;
        line-height: 25px;
      .medium {
        font-size: 30px;
        line-height: 35px;
      .large {
        font-size: 65px;
        line-height: 65px;
      .xlarge {
        font-size: 75px;
        line-height: 75px;
        letter-spacing: -3px;
      Then change the font-size until you have the look you want.
      • F Offline
        fiskaren @broberg
        @broberg Awesome, will try that soon after my trip to the store for a PIR-sensor.
        The clock is at top_bar and right now the weather is at top_left. When both are placed at top_barthe clock are one row over the weather. Will that auto-adjust when changing the font?
        • brobergB Offline
          @fiskaren no, if they are in the same region they will always stock on top of each other.
          use top_left for clock and top_right for weather and then place the other modules in the upper/lower third regions and bottom regions.
          • F Offline
            fiskaren @broberg
            @broberg Well I am not really happy with the results right now. I have changed the size pretty much, but they still merge into eachother. And I realize I have to change the size even more if I dont want them to do that. And since that changes the font on every module it will look crazy and also unreadable.
            Here is a picture of how it looks right now:
            http://imgur.com/a/t8JDj
            Is it possible to force the modules some pixels out? Because if so I could put them closer to the edges and that would probably solve the problem.
            The last solution could be to remove wind-speed. But it’s windy where I live and I would very much like to know the wind speed!
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @fiskaren
              @fiskaren custom.css
              body {
                margin: 0px;
                height: 100%;
                width: 100%;
              • brobergB Offline
                Do what strawberry wrote, it will give you more space on the screen.
                also
                This should change the size of the fonts in the top two modules only
                .currentweather {
                font-size: 50%;
                .clock {
                font-size: 50%;
                • F Offline
                  fiskaren @strawberry 3.141
                  @strawberry-3.141 said in Layout problem:
                  body {
                    margin: 0px;
                    height: 100%;
                    width: 100%;
                  @broberg said in Layout problem:
                  also
                  .currentweather {
                  font-size: 50%;
                  .clock {
                  font-size: 50%;
                  Awesome. Thank you both. It looks perfect now! :D
                  • FlatPepsiF Offline
                    FlatPepsi
                    You might find this useful, I thought it was awesome when I saw it:
                    https://forum.magicmirror.builders/topic/286/regions
                    top_bar and bottom_bar are light gray
                    top_left and bottom_left are red
                    top_center and bottom_center are blue
                    top_right and bottom_right are green
                    upper_third is yellow
                    middle_center is cyan
                    lower_third is magenta
                    All these regions will resize as needed.
                    alt text
