    Layout problem
    9 Posts 4 Posters 6.7k Views 3 Watching
    • brobergB Offline
      broberg Project Sponsor @fiskaren
      @fiskaren no, if they are in the same region they will always stock on top of each other.
      use top_left for clock and top_right for weather and then place the other modules in the upper/lower third regions and bottom regions.
      • F Offline
        fiskaren @broberg
        @broberg Well I am not really happy with the results right now. I have changed the size pretty much, but they still merge into eachother. And I realize I have to change the size even more if I dont want them to do that. And since that changes the font on every module it will look crazy and also unreadable.
        Here is a picture of how it looks right now:
        http://imgur.com/a/t8JDj
        Is it possible to force the modules some pixels out? Because if so I could put them closer to the edges and that would probably solve the problem.
        The last solution could be to remove wind-speed. But it’s windy where I live and I would very much like to know the wind speed!
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @fiskaren
          @fiskaren custom.css
          body {
            margin: 0px;
            height: 100%;
            width: 100%;
          • brobergB Offline
            Do what strawberry wrote, it will give you more space on the screen.
            also
            This should change the size of the fonts in the top two modules only
            .currentweather {
            font-size: 50%;
            .clock {
            font-size: 50%;
            • F Offline
              fiskaren @strawberry 3.141
              @strawberry-3.141 said in Layout problem:
              body {
                margin: 0px;
                height: 100%;
                width: 100%;
              @broberg said in Layout problem:
              also
              .currentweather {
              font-size: 50%;
              .clock {
              font-size: 50%;
              Awesome. Thank you both. It looks perfect now! :D
              • FlatPepsiF Offline
                FlatPepsi
                You might find this useful, I thought it was awesome when I saw it:
                https://forum.magicmirror.builders/topic/286/regions
                top_bar and bottom_bar are light gray
                top_left and bottom_left are red
                top_center and bottom_center are blue
                top_right and bottom_right are green
                upper_third is yellow
                middle_center is cyan
                lower_third is magenta
                All these regions will resize as needed.
                alt text
