    Layout problem
    9 Posts 4 Posters 6.7k Views 3 Watching
    • F Offline
      fiskaren @broberg
      @broberg Well I am not really happy with the results right now. I have changed the size pretty much, but they still merge into eachother. And I realize I have to change the size even more if I dont want them to do that. And since that changes the font on every module it will look crazy and also unreadable.
      Here is a picture of how it looks right now:
      http://imgur.com/a/t8JDj
      Is it possible to force the modules some pixels out? Because if so I could put them closer to the edges and that would probably solve the problem.
      The last solution could be to remove wind-speed. But it’s windy where I live and I would very much like to know the wind speed!
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @fiskaren
        @fiskaren custom.css
        body {
          margin: 0px;
          height: 100%;
          width: 100%;
        • brobergB Offline
          broberg Project Sponsor
          Do what strawberry wrote, it will give you more space on the screen.
          also
          This should change the size of the fonts in the top two modules only
          .currentweather {
          font-size: 50%;
          .clock {
          font-size: 50%;
          • F Offline
            fiskaren @strawberry 3.141
            @strawberry-3.141 said in Layout problem:
            body {
              margin: 0px;
              height: 100%;
              width: 100%;
            @broberg said in Layout problem:
            also
            .currentweather {
            font-size: 50%;
            .clock {
            font-size: 50%;
            Awesome. Thank you both. It looks perfect now! :D
            • FlatPepsiF Offline
              FlatPepsi
              You might find this useful, I thought it was awesome when I saw it:
              https://forum.magicmirror.builders/topic/286/regions
              top_bar and bottom_bar are light gray
              top_left and bottom_left are red
              top_center and bottom_center are blue
              top_right and bottom_right are green
              upper_third is yellow
              middle_center is cyan
              lower_third is magenta
              All these regions will resize as needed.
              alt text
