    Layout problem
    9 Posts 4 Posters 6.7k Views 3 Watching
    • F Offline
      fiskaren @broberg
      @broberg Awesome, will try that soon after my trip to the store for a PIR-sensor.
      The clock is at top_bar and right now the weather is at top_left. When both are placed at top_barthe clock are one row over the weather. Will that auto-adjust when changing the font?
      • brobergB Offline
        broberg Project Sponsor @fiskaren
        @fiskaren no, if they are in the same region they will always stock on top of each other.
        use top_left for clock and top_right for weather and then place the other modules in the upper/lower third regions and bottom regions.
        • F Offline
          fiskaren @broberg
          @broberg Well I am not really happy with the results right now. I have changed the size pretty much, but they still merge into eachother. And I realize I have to change the size even more if I dont want them to do that. And since that changes the font on every module it will look crazy and also unreadable.
          Here is a picture of how it looks right now:
          http://imgur.com/a/t8JDj
          Is it possible to force the modules some pixels out? Because if so I could put them closer to the edges and that would probably solve the problem.
          The last solution could be to remove wind-speed. But it’s windy where I live and I would very much like to know the wind speed!
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @fiskaren
            @fiskaren custom.css
            body {
              margin: 0px;
              height: 100%;
              width: 100%;
            • brobergB Offline
              Do what strawberry wrote, it will give you more space on the screen.
              also
              This should change the size of the fonts in the top two modules only
              .currentweather {
              font-size: 50%;
              .clock {
              font-size: 50%;
              • F Offline
                fiskaren @strawberry 3.141
                @strawberry-3.141 said in Layout problem:
                body {
                  margin: 0px;
                  height: 100%;
                  width: 100%;
                @broberg said in Layout problem:
                also
                .currentweather {
                font-size: 50%;
                .clock {
                font-size: 50%;
                Awesome. Thank you both. It looks perfect now! :D
                • FlatPepsiF Offline
                  FlatPepsi
                  You might find this useful, I thought it was awesome when I saw it:
                  https://forum.magicmirror.builders/topic/286/regions
                  top_bar and bottom_bar are light gray
                  top_left and bottom_left are red
                  top_center and bottom_center are blue
                  top_right and bottom_right are green
                  upper_third is yellow
                  middle_center is cyan
                  lower_third is magenta
                  All these regions will resize as needed.
                  alt text
