    Magic Mirror minus the mirror
    28 Posts 10 Posters 32.1k Views 15 Watching
      billp100 @jaymichael78
      @jaymichael78 Here you go…
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	ipWhitelist: ["192.168.1.18", "::ffff:127.0.0.1", "::1"],
      	language: 'en',
      	timeFormat: 12,
      	units: 'imperial',
      			module: 'alert',
      			module: 'clock',
      			position: 'top_left'
      			module: 'calendar_monthly',
      			position: 'top_left',
      				cssStyle:'slate'
      			module: 'calendar',
      			header: ' Bill  Janice  Vinny ',
      				colored: 'true',
      						symbol: 'male',
      						url: 'Calendar link',
      						color:'#4286f4'
      						symbol: 'child',
      						color:'#33cc33'
      						symbol: 'female',
      						color:'#eb42f4'
      			module: 'calendar',
      			header: 'Important Dates',
      			config:{
      				colored: 'true',
      						symbol: 'users',
      						color: '#ffff00'
      					{	symbol: 'birthday-cake',
      						color: '#b380ff'
      			module: 'MMM-Wunderlist',
      			position: 'bottom_center',
      			header: 'To-Do List',
      				accessToken: 'your access token',
      				clientID: 'your client id',
      				lists: ["MM List"]
      			module: 'MMM-WunderGround',
          			position: 'top_right',
              		apikey: 'your api key', // private; don't share!
              		pws: 'pws:KNYHUNTI41', //culemborg
              		coloricon: 'true',
      			hourly: '1',
              		fctext: '1',
              		layout: "horizontal",
      			fcdaycount: "3",
              		fcdaystart: "0",
              		hourlyinterval: "3",
              		hourlycount: "2",
              		alerttime: 10000,
              		alerttruncatestring: "english:",
          			roundTmpDecs: 1,
          			UseCardinals: 0,
          			sysstat: 0
      			module: 'newsfeed',
      				feeds: [
      						title: "Fox News",
      						url: "http://feeds.foxnews.com/foxnews/latest?format=xml"
      				showSourceTitle: true,
      				showPublishDate: true
                              module: 'MMM-Traffic',
                              classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
                              api_key: 'your api key',
                              mode: 'driving',
                              origin: 'starting address',
                              destination: 'destination address',
                              route_name: 'nickname',
                              show_summary: true,
                              changeColor: true,
                              showGreen: true,
                              limitYellow: 5, //Greater than 5% of journey time due to traffic
                              limitRed: 20, //Greater than 20% of journey time due to traffic
                              traffic_model: 'pessimistic',
                              interval: 120000 //2 minutes
      			module: 'MMM-MTA',
          			sStation: 'DPK',
          			mtaAPIKey: '9e9374cf6751033431c1f54a4e7576c3' //API KEY needs to be requested from datamine.mta.info
      			module: 'MMM-NHL',
      				colored: 'true',
      				focus_on: [2],
      				datesToLookAhead: '7',
      Y P 2 Replies Last reply Reply Quote 1
        @jaymichael78 Here is the custom css
         * Magic Mirror                                      *
         * Custom CSS                                        *
         * By Michael Teeuw http://michaelteeuw.nl           *
         * MIT Licensed.                                     *
         * Add any custom CSS below.                         *
         * Changes to this files will be ignored by GIT. *
         header {
         text-transform: uppercase;
         font-family: "Roboto Condensed";
         font-size: 20px;
         font-weight: 300;
         body {
         margin: 30px;
         position: absolute;
         height: calc(100%-50px);
         width: calc(100%-50px);
         background-image: url('bg1.jpg');
         backgroung-repeat: no-repeat;
         background-size: 1920;
        .newsfeed, div#module_7_newsfeed {
         width: 550px;
         font-size: 12px;
        • Y Offline
          yawns Moderator @billp100
          @billp100
          Boolean values and numbers should be written without " or ’
            jaymichael78 @billp100
            @billp100 thanks! This really is nice. You did good work. I appreciate you sharing this seeing the two side by side really helps me understand how to manage this better. Big week, will get back fo it this weekend.
              billp100 @yawns
              @yawns Thank you for the clarification. I wasn’t sure why some values needed the " or ', basically if the config file loaded, I counted that as a success
              @jaymichael78 Thanks for the compliment. Next step is building a frame for it to mount on the fridge. Plus I’ll be still tinkering away at the contents.
              • Y Offline
                yawns Moderator
                Some explanation from @strawberry-3-141
                'false' is a string and a string always represents the boolean true, so 'test', 'true' and 'false' all become true it doesn’t matter what the content of the string is.
                There are multiple types:
                • object {}
                • array []
                • number 2, -17 and 3.14
                • string "I am a string" and 'me too'
                • boolean true or false
                • O Offline
                  ooom416354
                  @billp100 this is spectacular.
                    cyberphox
                    i use Wunderground weather…why can i not get these fabulous weather icons!
                    going to compare your CSS and config files! thanks
                    • strawberry 3.141S Offline
                      strawberry 3.141 Project Sponsor Module Developer @cyberphox
                      @cyberphox coloricon: true
                        cyberphox @strawberry 3.141
                        @strawberry-3.141 definitely have that set in my config file. cleared out everything in my custom.css so nothing would interfere…maybe my location doesn’t get pretty realistic icons…sigh
                        • Y Offline
                          yawns Moderator @cyberphox
                          @cyberphox
                          Please share your config file
                            cyberphox
                            Actually I have solved the issue! Anyone else having this problem - I solved it with two words - git pull.
                            Yup…I i was using an older version of the MMM-WunderGround module…doh!
                              pflodo @billp100
                              @billp100 The photo shows your Calendar module with a header that matches your calendar colours, like a legend, which is great. But how did you do that? It is not reflected in the config you posted, unless I am missing something.
                                strawberry 3.141 Project Sponsor Module Developer @pflodo
                                @pflodo https://forum.magicmirror.builders/topic/1692/calendar-heading-changes
                                  misterfrei @billp100
                                  @billp100 ![alt text]ttps://forum.magicmirror.builders/assets/uploads/files/1488818811433-infodisplay4.jpeg0_1511171562750_1488818811433-infodisplay4.jpeg
                                  Hallo zusammen
                                  wie kann ich bei den angezeigten objekten , die farbe ändern? wie hier dargestellt?
                                  kann man auch das grosse icon verschieben? zum beispiel in die mitte des display und es auch grösser machen?
                                  Hello everybody
                                  how can I change the color of the displayed objects? as shown here?
                                  is it possible to move the big icon? for example, in the middle of the display and make it bigger too?
