    MMM-TouchPlayerBasic - Simple Webradio and mp3 Playlist player.
    touchmusicradio
    15 Posts 7 Posters 16.1k Views 10 Watching
      broberg Project Sponsor
      Description:
      This module caters to you who are running touch mirrors and want to be able to just choose a radio station or playlist and play it, no fuzz just buzz.
      Simple audio controls like volume up/down and mute/unmute.
      Pressing stop kills the radio and playlist that is playing and hides all buttons so only the start button is visible.
      I made this for my intended touch mirror but since plans have changed I can no longer use it, better somebody else that runs touch can!
      Thanks to @gismo2006 for making the MMM-Voiceradio that this module is based on.
      Screenshots:
      Download:
      [card:brobergp/MMM-TouchPlayerBasic]
      Version 0.1
      • First release
      • Can play mp3 files, streamed via webradio or playlists (.m3u only)
      • Controls master volume of your Pi
      • Y Offline
        yawns Moderator
        I did not test it, but the interface on your screenshots looks awesome
          broberg Project Sponsor @yawns
          @yawns Thanks!
          For those who don’t want to install it, here is a link to show the animations :
          https://www.youtube.com/watch?v=ii-LgaDGUjw&feature=youtu.be
            plumcraft
            The design looks great ! Going to try it soon !
              Got asked how to hide the text above the icons, the easiest way is to add
              .MMM-TouchPlayerBasic .rotate {display: none;}
              To your custom.css file
              johnnyboyJ 1 Reply Last reply Reply Quote 0
              • johnnyboyJ Offline
                johnnyboy @broberg
                • T Offline
                  Toast
                  tnx for this module now i can hook up my squeezebox to my magic mirror since that does not requier touch at all can be remote controlled :)
                  johnnyboyJ 1 Reply Last reply Reply Quote 1
                    johnnyboy @Toast
                    • T Offline
                      Toast @johnnyboy
                      @johnnyboy Logitech Squeezebox player is an old player (but still developed) that allows you to stream music to small devices like pi or computer or phones for that matter
                      http://wiki.slimdevices.com/index.php/Logitech_Media_Server
                      all you need is a client to receive the music via logitechs own protocol or m3u files so you already support it but if you want to implement native support that would be awesome.
                      for more info on the protocol
                      http://wiki.slimdevices.com/index.php/SlimProto_TCP_protocol
                      and i do belive there is a package for nodejs for the protocol
                      https://www.npmjs.com/package/squeezenode
                      not sure how good it is.
                        johnnyboy @Toast
                        • T Offline
                          Toast
                          Nice, would be cool to have a fully functional squeezeclient in the mirror :)
                            Benjoe1896
                            Hi, I love this TouchPlayer, but Soundconrol didn’t work. Volume up/down and mute/unmute. Anyone could help me?
                              broberg Project Sponsor @Benjoe1896
                              @Benjoe1896
                              It uses alsamixer command lines in the node helper file, your system probably doesn’t have alsa installed then.
                              Either install that or check what your linux distribution uses for sound management and change the node helper file accordingly!
                                Benjoe1896
                                Hi, i run alexa (AVS) at background. I think alexa control alsamixer. Maybe it stop other Programms to control it too.
                                  rentaro
                                  Thanks for the modules works well, instructions were to the tee!.
