MMM-Fuel
@Dom1n1c I commented on your changes
Is it possible to choose other typs of fuel like non-leaded supergrade plus petrol or premium?
@reaper81 the api only provides diesel e5 and e10 sorry
Hi
If I take the example with a matching token,
“Node serveronly” does not start.Loading config …
Loading module helpers …
WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
Whoops! There was an uncaught exception…
[SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode]
If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issuesvar config = {
port: 8070,
ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “192.168.1.22”],language: 'de', timeFormat: 24, units: 'metric',
module: ‘MMM-Fuel’,
position: ‘top_right’,
api_key: ‘f9fXXXXXXX’,
lat: 51.899177,
lng: 10.184662,
types: [‘diesel’],
@jayjay2017 please post your config without api keys or check your config on jshint.com
@jayjay2017 sounds like your node version doesnt support es6 which node version are you using?
The version of node was the point. I had Version 4.2.6, now updated to V7.7.2.
It works now.
Thank you very much.
Hi, have an issue with the shortenText parameter. When I use it, the address is max shorter(in px) then the name of the gas station. That’s a little bit anoying if more then one station is shown from the big companies and I can’t see the complete address, even if there is still enough place. Any idea, how I can change it? In the custom.css for example.
@sindbad6 looks strange, your name gets cut after 35 chars and your address after ~19 can you send me your geo data you’re using in config as a private message?
@strawberry-3.141 Sorry, I’m a complete newbie and can’t see how to send a private message. I tried it over the chat button. I hope you meant this.
