    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 569.5k Views 48 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @DeSlow
      @DeSlow The config works for me when I replace the quotes. check your pm for support in german
      EDIT: the problem was a missing comma in the config file
        Dom1n1c
        The Addon works great
        But: is a filter based on opened station in a defined radius possible?
        I want to hide the distance and detailed address, to reduce the size of the mmm-fuel box.
        Only Shell (Zip/City), Aral (Zip/City) should be displayed.
        my requirements in detail:
        no rotate (check)
        2 types of gas (check)
        maximum of 3 displayed station (check)
        not possible yet:
        display only open stations
        reduce length of the station name, remove address, or at least shorten.
        Thanks (and merry christmas btw)
          Dom1n1c @Dom1n1c
          Furthermore i want to hide the car icon, because it does not fit into the mm style (just my opinion)
            strawberry 3.141 Project Sponsor Module Developer @Dom1n1c
            Changelog:
            4 new config options
            • shortenText: shorten name and address after certain characters
            • showAddress: show address of gas station or not
            • showOpenOnly: show only gas stations that are open or all
            • iconHeader: display icon in header
            [card:fewieden/MMM-Fuel]
              Dom1n1c
              I did a replacement on the Station names, because “Shell” is typically naming there stations after the Street name.
              I fixed the City name to have only the first Letter in uppercase.
              How can i remove the " null" part, which is occuring at JET stations,
              or how can i tidy up the street names? (every seperate word starting with an uppercase)
              of course i can start with a list of the complete string that should be replaced, but there might be another option.
                @Dom1n1c
                • null @jets is propably that they inserted the house number in the street name and the house number value returns null
                • for the street names i would split at the space character and then for each array item charAt(0).toUpperCase() and the rest of the string lowercase and finally join them together
                  Dom1n1c
                  I added checks for house numbers==null and splitted the street names.
                  Also the Brand names starting with (star,ESSO,Aral were replaced automatically)
                  (Shell and no-name stations are a special case, so i need to handle them individually)
                  But, there is still another special case:
                  Streetnames with " " or “-” should be splitted, but no housenumbers (from JET :D ).
                  How can i avoid splitting numbers:
                  This is the section that does the splitting
                  words = str.toLowerCase().split(/-| /);
                  can be found here in total:
                  https://github.com/Dom1n1c/MMM-Fuel/blob/master/MMM-Fuel.js
                    @Dom1n1c I commented on your changes
                      reaper81
                      Is it possible to choose other typs of fuel like non-leaded supergrade plus petrol or premium?
                        strawberry 3.141 Project Sponsor Module Developer @reaper81
                        @reaper81 the api only provides diesel e5 and e10 sorry
                          jayjay2017
                          Hi
                          If I take the example with a matching token,
                          “Node serveronly” does not start.
                          Loading config …
                          Loading module helpers …
                          WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                          Whoops! There was an uncaught exception…
                          [SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode]
                          var config = {
                          port: 8070,
                          ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “192.168.1.22”],
                          language: 'de',
                          timeFormat: 24,
                          units: 'metric',
                          module: ‘MMM-Fuel’,
                          position: ‘top_right’,
                          api_key: ‘f9fXXXXXXX’,
                          lat: 51.899177,
                          lng: 10.184662,
                          types: [‘diesel’],
                          Y strawberry 3.141S 2 Replies Last reply Reply Quote 0
                          • Y Offline
                            yawns Moderator @jayjay2017
                            @jayjay2017 please post your config without api keys or check your config on jshint.com
                              strawberry 3.141 Project Sponsor Module Developer @jayjay2017
                              @jayjay2017 sounds like your node version doesnt support es6 which node version are you using?
                                jayjay2017
                                The version of node was the point. I had Version 4.2.6, now updated to V7.7.2.
                                It works now.
                                Thank you very much.
                                  sindbad6
                                  Hi, have an issue with the shortenText parameter. When I use it, the address is max shorter(in px) then the name of the gas station. That’s a little bit anoying if more then one station is shown from the big companies and I can’t see the complete address, even if there is still enough place. Any idea, how I can change it? In the custom.css for example.
                                  0_1489269011731_upload-acb11020-7933-41d5-a659-9402199ec1a1
                                    strawberry 3.141 Project Sponsor Module Developer @sindbad6
                                    @sindbad6 looks strange, your name gets cut after 35 chars and your address after ~19 can you send me your geo data you’re using in config as a private message?
                                      sindbad6 @strawberry 3.141
                                      @strawberry-3.141 Sorry, I’m a complete newbie and can’t see how to send a private message. I tried it over the chat button. I hope you meant this.
                                        @sindbad6 do a git pull in ~/MagicMirror/modules/MMM-Fuel
                                          @strawberry-3.141 Thanks a lot. That’s much better.
                                            Stabber
                                            A great modul!!
                                            What should I do to see the map? I have google maps API, but I don’t know where to add it.
                                            • 3 / 9
