    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 586.1k Views 48 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @DeSlow
      @DeSlow can you post your config snippet? dont forget to replace your api key first
        DeSlow
        do you meen this
        module: “MMM-Fuel”,
        position: “top_right”,
        api_key: “api key”,
        lat: 53.931775,
        lng: 9.505148,
        types: [“e5”],
        strawberry 3.141S D 2 Replies Last reply Reply Quote 0
        • strawberry 3.141S
          @DeSlow you should remove the api key here in the forum this is kind of a password and should not be shared with someone else. i will test this on my machine
            DeSlow @DeSlow
              DeSlow
              and 1 question to this:
              Dependencies
              An installation of MagicMirror2
              OPTIONAL: Voice Control
              npm
              request -------what is this and what got i go white is
              im so bad in englisch, got dam
              • strawberry 3.141S
                @DeSlow The config works for me when I replace the quotes. check your pm for support in german
                EDIT: the problem was a missing comma in the config file
                  Dom1n1c
                  The Addon works great
                  But: is a filter based on opened station in a defined radius possible?
                  I want to hide the distance and detailed address, to reduce the size of the mmm-fuel box.
                  Only Shell (Zip/City), Aral (Zip/City) should be displayed.
                  my requirements in detail:
                  no rotate (check)
                  2 types of gas (check)
                  maximum of 3 displayed station (check)
                  not possible yet:
                  display only open stations
                  reduce length of the station name, remove address, or at least shorten.
                  Thanks (and merry christmas btw)
                    Dom1n1c @Dom1n1c
                    Furthermore i want to hide the car icon, because it does not fit into the mm style (just my opinion)
                    • strawberry 3.141S
                      strawberry 3.141 Project Sponsor Module Developer @Dom1n1c
                      Changelog:
                      4 new config options
                      • shortenText: shorten name and address after certain characters
                      • showAddress: show address of gas station or not
                      • showOpenOnly: show only gas stations that are open or all
                      • iconHeader: display icon in header
                      [card:fewieden/MMM-Fuel]
                        Dom1n1c
                        I did a replacement on the Station names, because “Shell” is typically naming there stations after the Street name.
                        I fixed the City name to have only the first Letter in uppercase.
                        How can i remove the " null" part, which is occuring at JET stations,
                        or how can i tidy up the street names? (every seperate word starting with an uppercase)
                        of course i can start with a list of the complete string that should be replaced, but there might be another option.
                        • strawberry 3.141S
                          @Dom1n1c
                          • null @jets is propably that they inserted the house number in the street name and the house number value returns null
                          • for the street names i would split at the space character and then for each array item charAt(0).toUpperCase() and the rest of the string lowercase and finally join them together
                            Dom1n1c
                            I added checks for house numbers==null and splitted the street names.
                            Also the Brand names starting with (star,ESSO,Aral were replaced automatically)
                            (Shell and no-name stations are a special case, so i need to handle them individually)
                            But, there is still another special case:
                            Streetnames with " " or “-” should be splitted, but no housenumbers (from JET :D ).
                            How can i avoid splitting numbers:
                            This is the section that does the splitting
                            words = str.toLowerCase().split(/-| /);
                            can be found here in total:
                            https://github.com/Dom1n1c/MMM-Fuel/blob/master/MMM-Fuel.js
                            • strawberry 3.141S
                              @Dom1n1c I commented on your changes
                                reaper81
                                Is it possible to choose other typs of fuel like non-leaded supergrade plus petrol or premium?
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @reaper81
                                  @reaper81 the api only provides diesel e5 and e10 sorry
                                    jayjay2017
                                    Hi
                                    If I take the example with a matching token,
                                    “Node serveronly” does not start.
                                    Loading config …
                                    Loading module helpers …
                                    WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                                    Whoops! There was an uncaught exception…
                                    [SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode]
                                    var config = {
                                    port: 8070,
                                    ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “192.168.1.22”],
                                    language: 'de',
                                    timeFormat: 24,
                                    units: 'metric',
                                    module: ‘MMM-Fuel’,
                                    position: ‘top_right’,
                                    api_key: ‘f9fXXXXXXX’,
                                    lat: 51.899177,
                                    lng: 10.184662,
                                    types: [‘diesel’],
                                    Y strawberry 3.141S 2 Replies Last reply Reply Quote 0
                                    • Y
                                      yawns Moderator @jayjay2017
                                      @jayjay2017 please post your config without api keys or check your config on jshint.com
                                      • strawberry 3.141S
                                        strawberry 3.141 Project Sponsor Module Developer @jayjay2017
                                        @jayjay2017 sounds like your node version doesnt support es6 which node version are you using?
                                          jayjay2017
                                          The version of node was the point. I had Version 4.2.6, now updated to V7.7.2.
                                          It works now.
                                          Thank you very much.
                                            sindbad6
                                            Hi, have an issue with the shortenText parameter. When I use it, the address is max shorter(in px) then the name of the gas station. That’s a little bit anoying if more then one station is shown from the big companies and I can’t see the complete address, even if there is still enough place. Any idea, how I can change it? In the custom.css for example.
                                            0_1489269011731_upload-acb11020-7933-41d5-a659-9402199ec1a1
                                            • 3 / 9
