    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 579.6k Views 48 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @jayjay2017
      @jayjay2017 sounds like your node version doesnt support es6 which node version are you using?
        jayjay2017
        The version of node was the point. I had Version 4.2.6, now updated to V7.7.2.
        It works now.
        Thank you very much.
          sindbad6
          Hi, have an issue with the shortenText parameter. When I use it, the address is max shorter(in px) then the name of the gas station. That’s a little bit anoying if more then one station is shown from the big companies and I can’t see the complete address, even if there is still enough place. Any idea, how I can change it? In the custom.css for example.
          0_1489269011731_upload-acb11020-7933-41d5-a659-9402199ec1a1
            strawberry 3.141 Project Sponsor Module Developer @sindbad6
            @sindbad6 looks strange, your name gets cut after 35 chars and your address after ~19 can you send me your geo data you’re using in config as a private message?
              sindbad6 @strawberry 3.141
              @strawberry-3.141 Sorry, I’m a complete newbie and can’t see how to send a private message. I tried it over the chat button. I hope you meant this.
                @sindbad6 do a git pull in ~/MagicMirror/modules/MMM-Fuel
                  @strawberry-3.141 Thanks a lot. That’s much better.
                    Stabber
                    A great modul!!
                    What should I do to see the map? I have google maps API, but I don’t know where to add it.
                      strawberry 3.141 Project Sponsor Module Developer @Stabber
                      @Stabber Currently the map can only be shown with my voice module https://github.com/fewieden/MMM-voice
                        sindbad6
                        Hi, I made a change in my MM-Fuel.js to implement an additional parameter for shortening the address of a gas station. It is not a big thing, but I would like if it would be integrated in the repository. The point is, I never have done it before. In between I got an account at github, but know? Can somebody give me a link where I can find belonging infos?
                          @sindbad6 in short:
                          • fork the repository
                          • make your changes
                          • push them to the fork
                          • create a pull request
                            @strawberry-3.141 Ok, I did it now. I’m not sure if I did right. Please inform me if something was wrong. I’m a little bit surprised, to get the possibility to merge my changes.
                              @sindbad6 you closed your pull request and deleted the branch so there is no possibility to merge your changes
                                @strawberry-3.141 That’s what I was afraid of. I will try to correct it.
                                  Changelog v1.1.0
                                  • API provider development Guide.
                                  • API provider spritpreisrechner.at.
                                  • Disabled markdownlint rule MD026 (no-trailing-punctuation)
                                  • Disabled eslint rule no-console
                                  • Doclets.io integration
                                  • Contributing guidelines
                                  • Issue template
                                  • Pull request template
                                  [card:fewieden/MMM-Fuel]
                                    Anhalter42
                                    Anyone considered adding support of multiple locations? Useful for example for commuters to lookup prices at start and destination (and/or somewhere in between) of their daily way to work.
                                    • garblefluxG Offline
                                      garbleflux Project Sponsor
                                      hi strawberry. Absolut nice work, I use it daily! One question: How did you get the in the example (Cheapest Gas Stations) all the text in the listing left justified?
                                        strawberry 3.141 Project Sponsor Module Developer @garbleflux
                                        @garbleflux if you scroll down there is module configuration https://github.com/MichMich/MagicMirror#configuration you can add the class align-left
                                          Changelog v1.1.1
                                          • Disabled markdownlint rule MD024 (no-duplicate-header)
                                          • Config option toFixed to show only 2 decimals for the price.
                                          • Coordinate.to() throws exception if start point is not set.
                                          Upcoming release v1.2.0
                                          https://github.com/fewieden/MMM-Fuel/projects/1
                                          • rudibaraniR Offline
                                            rudibarani Project Sponsor @strawberry 3.141
                                            Hi @strawberry-3.141,
                                            thanks for creating this great module! Would any of the following be possible?
                                            • hide the distance column
                                            • show the prices of pre-selected gas stations
                                            • show e.g. the three cheapest plus some pre-selected gas stations
                                            • 3 / 9
