    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 589.6k Views 48 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @sindbad6
      @sindbad6 looks strange, your name gets cut after 35 chars and your address after ~19 can you send me your geo data you’re using in config as a private message?
        sindbad6 @strawberry 3.141
        @strawberry-3.141 Sorry, I’m a complete newbie and can’t see how to send a private message. I tried it over the chat button. I hope you meant this.
        • strawberry 3.141S
          @sindbad6 do a git pull in ~/MagicMirror/modules/MMM-Fuel
            @strawberry-3.141 Thanks a lot. That’s much better.
              Stabber
              A great modul!!
              What should I do to see the map? I have google maps API, but I don’t know where to add it.
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @Stabber
                @Stabber Currently the map can only be shown with my voice module https://github.com/fewieden/MMM-voice
                  sindbad6
                  Hi, I made a change in my MM-Fuel.js to implement an additional parameter for shortening the address of a gas station. It is not a big thing, but I would like if it would be integrated in the repository. The point is, I never have done it before. In between I got an account at github, but know? Can somebody give me a link where I can find belonging infos?
                  • strawberry 3.141S
                    @sindbad6 in short:
                    • fork the repository
                    • make your changes
                    • push them to the fork
                    • create a pull request
                      @strawberry-3.141 Ok, I did it now. I’m not sure if I did right. Please inform me if something was wrong. I’m a little bit surprised, to get the possibility to merge my changes.
                      • strawberry 3.141S
                        @sindbad6 you closed your pull request and deleted the branch so there is no possibility to merge your changes
                          @strawberry-3.141 That’s what I was afraid of. I will try to correct it.
                          • strawberry 3.141S
                            Changelog v1.1.0
                            • API provider development Guide.
                            • API provider spritpreisrechner.at.
                            • Disabled markdownlint rule MD026 (no-trailing-punctuation)
                            • Disabled eslint rule no-console
                            • Doclets.io integration
                            • Contributing guidelines
                            • Issue template
                            • Pull request template
                            [card:fewieden/MMM-Fuel]
                            • A
                              Anhalter42
                              Anyone considered adding support of multiple locations? Useful for example for commuters to lookup prices at start and destination (and/or somewhere in between) of their daily way to work.
                              • garblefluxG
                                garbleflux Project Sponsor
                                hi strawberry. Absolut nice work, I use it daily! One question: How did you get the in the example (Cheapest Gas Stations) all the text in the listing left justified?
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @garbleflux
                                  @garbleflux if you scroll down there is module configuration https://github.com/MichMich/MagicMirror#configuration you can add the class align-left
                                  • strawberry 3.141S
                                    Changelog v1.1.1
                                    • Disabled markdownlint rule MD024 (no-duplicate-header)
                                    • Config option toFixed to show only 2 decimals for the price.
                                    • Coordinate.to() throws exception if start point is not set.
                                    Upcoming release v1.2.0
                                    https://github.com/fewieden/MMM-Fuel/projects/1
                                    • rudibaraniR
                                      rudibarani Project Sponsor @strawberry 3.141
                                      Hi @strawberry-3.141,
                                      thanks for creating this great module! Would any of the following be possible?
                                      • hide the distance column
                                      • show the prices of pre-selected gas stations
                                      • show e.g. the three cheapest plus some pre-selected gas stations
                                      • strawberry 3.141S
                                        strawberry 3.141 Project Sponsor Module Developer @rudibarani
                                        @rudibarani you can hide the distance column with css in custom.css, the other points are currently not possible
                                        • K
                                          kiki99
                                          Hi and Thanks for this module.
                                          I’ve only one Problem: I did not get the column with the price ;)
                                          It seems all other things are okay.
                                          What can i do/check?
                                          Thanks a lot for every tip :)
                                          • strawberry 3.141S
                                            strawberry 3.141 Project Sponsor Module Developer @kiki99
                                            @kiki99 can you post your config?
                                            K 1 Reply Last reply
                                            • 4 / 9
