    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 574.6k Views 48 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @Stabber
      @Stabber Currently the map can only be shown with my voice module https://github.com/fewieden/MMM-voice
        sindbad6
        Hi, I made a change in my MM-Fuel.js to implement an additional parameter for shortening the address of a gas station. It is not a big thing, but I would like if it would be integrated in the repository. The point is, I never have done it before. In between I got an account at github, but know? Can somebody give me a link where I can find belonging infos?
          strawberry 3.141 Project Sponsor Module Developer @sindbad6
          @sindbad6 in short:
          • fork the repository
          • make your changes
          • push them to the fork
          • create a pull request
            sindbad6 @strawberry 3.141
            @strawberry-3.141 Ok, I did it now. I’m not sure if I did right. Please inform me if something was wrong. I’m a little bit surprised, to get the possibility to merge my changes.
              @sindbad6 you closed your pull request and deleted the branch so there is no possibility to merge your changes
                @strawberry-3.141 That’s what I was afraid of. I will try to correct it.
                  Changelog v1.1.0
                  • API provider development Guide.
                  • API provider spritpreisrechner.at.
                  • Disabled markdownlint rule MD026 (no-trailing-punctuation)
                  • Disabled eslint rule no-console
                  • Doclets.io integration
                  • Contributing guidelines
                  • Issue template
                  • Pull request template
                  [card:fewieden/MMM-Fuel]
                    Anhalter42
                    Anyone considered adding support of multiple locations? Useful for example for commuters to lookup prices at start and destination (and/or somewhere in between) of their daily way to work.
                    • garblefluxG Offline
                      garbleflux Project Sponsor
                      hi strawberry. Absolut nice work, I use it daily! One question: How did you get the in the example (Cheapest Gas Stations) all the text in the listing left justified?
                        strawberry 3.141 Project Sponsor Module Developer @garbleflux
                        @garbleflux if you scroll down there is module configuration https://github.com/MichMich/MagicMirror#configuration you can add the class align-left
                          Changelog v1.1.1
                          • Disabled markdownlint rule MD024 (no-duplicate-header)
                          • Config option toFixed to show only 2 decimals for the price.
                          • Coordinate.to() throws exception if start point is not set.
                          Upcoming release v1.2.0
                          https://github.com/fewieden/MMM-Fuel/projects/1
                          • rudibaraniR Offline
                            rudibarani Project Sponsor @strawberry 3.141
                            Hi @strawberry-3.141,
                            thanks for creating this great module! Would any of the following be possible?
                            • hide the distance column
                            • show the prices of pre-selected gas stations
                            • show e.g. the three cheapest plus some pre-selected gas stations
                              strawberry 3.141 Project Sponsor Module Developer @rudibarani
                              @rudibarani you can hide the distance column with css in custom.css, the other points are currently not possible
                              • K Offline
                                kiki99
                                Hi and Thanks for this module.
                                I’ve only one Problem: I did not get the column with the price ;)
                                It seems all other things are okay.
                                What can i do/check?
                                Thanks a lot for every tip :)
                                  strawberry 3.141 Project Sponsor Module Developer @kiki99
                                  @kiki99 can you post your config?
                                  • K Offline
                                    kiki99 @strawberry 3.141
                                    @strawberry-3.141: yes, of course ;)
                                    		module: 'MMM-Fuel',
                                    		position: 'lower_third',
                                        		api_key: 'myApiKeyHere,
                                        		lat: 49.164136,
                                        		lng: 9.059751,
                                        		types: ["E5"],
                                    		sortBY: "E5",
                                    		radius: 10,
                                    		colored: true,
                                    		open: true,
                                    		rotate: false
                                    i see no prices (no column for that). But the List works.
                                      @kiki99
                                        module: 'MMM-Fuel',
                                          api_key: 'myApiKeyHere',
                                          lat: 49.164136,
                                          lng: 9.059751,
                                          types: ["e5"],
                                          sortBy: "e5",
                                          radius: 10,
                                          colored: true,
                                          open: true,
                                          rotate: false
                                      • K Offline
                                        @strawberry-3.141 Oh my …, sorry for this stupid Mistake and the bad format.
                                        Many thanks for the quick help :)
                                        • F Offline
                                          FreddeHamm
                                          @strawberry-3.141 I have some issues getting this thing fired up. I have a working api and found my location. But for some reason, the magic mirror won’t show the Fuel List.
                                            module: "MMM-Fuel",
                                            position: "bottom_right",
                                              api_key: 'Just My API',
                                              lat: 51.674177,
                                              lng: 6.460384,
                                              types: ["diesel"],
                                              sortBy: "diesel",
                                              radius: 10,
                                              colored: true,
                                              open: true,
                                              rotate: false
                                          Where is my mistake?!
                                            strawberry 3.141 Project Sponsor Module Developer @FreddeHamm
                                            @FreddeHamm you should remove the api key from your post, it’s kind of a password.
                                            I have to look on this on the weekend, can’t spot something obvious right now
                                            • 4 / 9
