    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 586.1k Views 48 Watching
    • A
      Anhalter42
      Anyone considered adding support of multiple locations? Useful for example for commuters to lookup prices at start and destination (and/or somewhere in between) of their daily way to work.
      • garblefluxG
        garbleflux Project Sponsor
        hi strawberry. Absolut nice work, I use it daily! One question: How did you get the in the example (Cheapest Gas Stations) all the text in the listing left justified?
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @garbleflux
          @garbleflux if you scroll down there is module configuration https://github.com/MichMich/MagicMirror#configuration you can add the class align-left
          • strawberry 3.141S
            Changelog v1.1.1
            • Disabled markdownlint rule MD024 (no-duplicate-header)
            • Config option toFixed to show only 2 decimals for the price.
            • Coordinate.to() throws exception if start point is not set.
            Upcoming release v1.2.0
            https://github.com/fewieden/MMM-Fuel/projects/1
            [card:fewieden/MMM-Fuel]
            • rudibaraniR
              rudibarani Project Sponsor @strawberry 3.141
              Hi @strawberry-3.141,
              thanks for creating this great module! Would any of the following be possible?
              • hide the distance column
              • show the prices of pre-selected gas stations
              • show e.g. the three cheapest plus some pre-selected gas stations
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @rudibarani
                @rudibarani you can hide the distance column with css in custom.css, the other points are currently not possible
                • K
                  kiki99
                  Hi and Thanks for this module.
                  I’ve only one Problem: I did not get the column with the price ;)
                  It seems all other things are okay.
                  What can i do/check?
                  Thanks a lot for every tip :)
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @kiki99
                    @kiki99 can you post your config?
                    • K
                      kiki99 @strawberry 3.141
                      @strawberry-3.141: yes, of course ;)
                      		module: 'MMM-Fuel',
                      		position: 'lower_third',
                          		api_key: 'myApiKeyHere,
                          		lat: 49.164136,
                          		lng: 9.059751,
                          		types: ["E5"],
                      		sortBY: "E5",
                      		radius: 10,
                      		colored: true,
                      		open: true,
                      		rotate: false
                      i see no prices (no column for that). But the List works.
                      • strawberry 3.141S
                        @kiki99
                          module: 'MMM-Fuel',
                            api_key: 'myApiKeyHere',
                            lat: 49.164136,
                            lng: 9.059751,
                            types: ["e5"],
                            sortBy: "e5",
                            radius: 10,
                            colored: true,
                            open: true,
                            rotate: false
                        • K
                          @strawberry-3.141 Oh my …, sorry for this stupid Mistake and the bad format.
                          Many thanks for the quick help :)
                          • F
                            FreddeHamm
                            @strawberry-3.141 I have some issues getting this thing fired up. I have a working api and found my location. But for some reason, the magic mirror won’t show the Fuel List.
                              module: "MMM-Fuel",
                              position: "bottom_right",
                                api_key: 'Just My API',
                                lat: 51.674177,
                                lng: 6.460384,
                                types: ["diesel"],
                                sortBy: "diesel",
                                radius: 10,
                                colored: true,
                                open: true,
                                rotate: false
                            Where is my mistake?!
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @FreddeHamm
                              @FreddeHamm you should remove the api key from your post, it’s kind of a password.
                              I have to look on this on the weekend, can’t spot something obvious right now
                              • F
                                FreddeHamm
                                any news?
                                • strawberry 3.141S
                                  @FreddeHamm sorry, forgot about you. cant reproduce your issue though, i did a refresh install of mmm-fuel on my machine and inserted your config which resulted in the following state
                                  can you spot any errors in the logs (electron or terminal, pm2)? did you try to disable all other modules to reduce side effects?
                                  • F
                                    FreddeHamm
                                    Thanks for your help. If i open the magic mirror site via browser (my.rasperry.pi.ip:8080) i see the module. But its not shown on the screen of the mirror itself…
                                    • strawberry 3.141S
                                      @FreddeHamm any errors?
                                      • F
                                        FreddeHamm
                                        noob-question: how can i see the log?
                                        • strawberry 3.141S
                                          @FreddeHamm in the terminal where you start the mirror or pm2 logs, and in the electron console(start the mirror with npm start dev)
                                          • F
                                            FreddeHamm
                                            i found this
                                            ** Message: console message: http://localhost:8080/modules/MMM-Fuel//MMM-Fuel.js @117: SyntaxError: Unexpected token ‘(’. Expected a ‘:’ following the property name 'getTranslati$
                                            • 4 / 9
