    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 579.6k Views 48 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @kiki99
      @kiki99 can you post your config?
      • K Offline
        kiki99 @strawberry 3.141
        @strawberry-3.141: yes, of course ;)
        		module: 'MMM-Fuel',
        		position: 'lower_third',
            		api_key: 'myApiKeyHere,
            		lat: 49.164136,
            		lng: 9.059751,
            		types: ["E5"],
        		sortBY: "E5",
        		radius: 10,
        		colored: true,
        		open: true,
        		rotate: false
        i see no prices (no column for that). But the List works.
          @kiki99
            module: 'MMM-Fuel',
              api_key: 'myApiKeyHere',
              lat: 49.164136,
              lng: 9.059751,
              types: ["e5"],
              sortBy: "e5",
              radius: 10,
              colored: true,
              open: true,
              rotate: false
          • K Offline
            @strawberry-3.141 Oh my …, sorry for this stupid Mistake and the bad format.
            Many thanks for the quick help :)
            • F Offline
              FreddeHamm
              @strawberry-3.141 I have some issues getting this thing fired up. I have a working api and found my location. But for some reason, the magic mirror won’t show the Fuel List.
                module: "MMM-Fuel",
                position: "bottom_right",
                  api_key: 'Just My API',
                  lat: 51.674177,
                  lng: 6.460384,
                  types: ["diesel"],
                  sortBy: "diesel",
                  radius: 10,
                  colored: true,
                  open: true,
                  rotate: false
              Where is my mistake?!
                strawberry 3.141 Project Sponsor Module Developer @FreddeHamm
                @FreddeHamm you should remove the api key from your post, it’s kind of a password.
                I have to look on this on the weekend, can’t spot something obvious right now
                • F Offline
                  FreddeHamm
                  any news?
                    @FreddeHamm sorry, forgot about you. cant reproduce your issue though, i did a refresh install of mmm-fuel on my machine and inserted your config which resulted in the following state
                    can you spot any errors in the logs (electron or terminal, pm2)? did you try to disable all other modules to reduce side effects?
                    • F Offline
                      FreddeHamm
                      Thanks for your help. If i open the magic mirror site via browser (my.rasperry.pi.ip:8080) i see the module. But its not shown on the screen of the mirror itself…
                        @FreddeHamm any errors?
                        • F Offline
                          FreddeHamm
                          noob-question: how can i see the log?
                            @FreddeHamm in the terminal where you start the mirror or pm2 logs, and in the electron console(start the mirror with npm start dev)
                            • F Offline
                              FreddeHamm
                              i found this
                              ** Message: console message: http://localhost:8080/modules/MMM-Fuel//MMM-Fuel.js @117: SyntaxError: Unexpected token ‘(’. Expected a ‘:’ following the property name 'getTranslati$
                              • F Offline
                                FreddeHamm
                                if i use npm start dev i get this…
                                1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’, ‘dev’ ]
                                2 info using npm@5.5.1
                                3 info using node@v8.3.0
                                4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
                                5 verbose stack Error: ENOENT: no such file or directory, open ‘/home/pi/package.json’
                                6 verbose cwd /home/pi
                                7 verbose Linux 4.9.35+
                                8 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start” “dev”
                                9 verbose node v8.3.0
                                10 verbose npm v5.5.1
                                11 error path /home/pi/package.json
                                12 error code ENOENT
                                13 error errno -2
                                14 error syscall open
                                15 error enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                                16 error enoent This is related to npm not being able to find a file.
                                17 verbose exit [ -2, true ]
                                I did try to set up another mm … Same problem. only the fuel module doesnt show up. But if i use the browser on my pc it shows up…
                                • Y Offline
                                  yawns Moderator @FreddeHamm
                                  @FreddeHamm
                                  Looks like you are not in the MagicMirror folder when running npm start dev
                                  Please try
                                  npm start dev
                                    @FreddeHamm sounds like you are using midori browser or something similar which doesnt support es6 syntax
                                      rrrene
                                      Hi
                                      great module!
                                      I wanted to use my own header for your module to get the same look as the other moduled.
                                      Unfortunately I don‘t understand how to disable the view of your implemented header.
                                      At the moment I have two headers :)
                                      Thanks.
                                      Best regards
                                        strawberry 3.141 Project Sponsor Module Developer @rrrene
                                        @rrrene custom.css .MMM-Fuel header.align-left { display: none; }
                                          DamienWakeford1
                                          Hi guys I’m from South Africa, I have just started playing with the magic mirror today I have managed to the calendar weather and news for South Africa I would really like to add fuel prices and email notifications to it but don’t know how and can find any videos showing how to do it just that they did it if that makes sence
                                          strawberry 3.141S D 2 Replies Last reply Reply Quote 0
                                            strawberry 3.141 Project Sponsor Module Developer @DamienWakeford1
                                            @DamienWakeford1 this module supports only germany and austria, not sure if it is possible to get the same information for your country via an api
                                            • 4 / 9
