    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 576.5k Views 48 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @garbleflux
      @garbleflux if you scroll down there is module configuration https://github.com/MichMich/MagicMirror#configuration you can add the class align-left
        Changelog v1.1.1
        • Disabled markdownlint rule MD024 (no-duplicate-header)
        • Config option toFixed to show only 2 decimals for the price.
        • Coordinate.to() throws exception if start point is not set.
        Upcoming release v1.2.0
        https://github.com/fewieden/MMM-Fuel/projects/1
        [card:fewieden/MMM-Fuel]
        • rudibaraniR Offline
          rudibarani Project Sponsor @strawberry 3.141
          Hi @strawberry-3.141,
          thanks for creating this great module! Would any of the following be possible?
          • hide the distance column
          • show the prices of pre-selected gas stations
          • show e.g. the three cheapest plus some pre-selected gas stations
            strawberry 3.141 Project Sponsor Module Developer @rudibarani
            @rudibarani you can hide the distance column with css in custom.css, the other points are currently not possible
            • K Offline
              kiki99
              Hi and Thanks for this module.
              I’ve only one Problem: I did not get the column with the price ;)
              It seems all other things are okay.
              What can i do/check?
              Thanks a lot for every tip :)
                strawberry 3.141 Project Sponsor Module Developer @kiki99
                @kiki99 can you post your config?
                • K Offline
                  kiki99 @strawberry 3.141
                  @strawberry-3.141: yes, of course ;)
                  		module: 'MMM-Fuel',
                  		position: 'lower_third',
                      		api_key: 'myApiKeyHere,
                      		lat: 49.164136,
                      		lng: 9.059751,
                      		types: ["E5"],
                  		sortBY: "E5",
                  		radius: 10,
                  		colored: true,
                  		open: true,
                  		rotate: false
                  i see no prices (no column for that). But the List works.
                    @kiki99
                      module: 'MMM-Fuel',
                        api_key: 'myApiKeyHere',
                        lat: 49.164136,
                        lng: 9.059751,
                        types: ["e5"],
                        sortBy: "e5",
                        radius: 10,
                        colored: true,
                        open: true,
                        rotate: false
                    • K Offline
                      @strawberry-3.141 Oh my …, sorry for this stupid Mistake and the bad format.
                      Many thanks for the quick help :)
                      • F Offline
                        FreddeHamm
                        @strawberry-3.141 I have some issues getting this thing fired up. I have a working api and found my location. But for some reason, the magic mirror won’t show the Fuel List.
                          module: "MMM-Fuel",
                          position: "bottom_right",
                            api_key: 'Just My API',
                            lat: 51.674177,
                            lng: 6.460384,
                            types: ["diesel"],
                            sortBy: "diesel",
                            radius: 10,
                            colored: true,
                            open: true,
                            rotate: false
                        Where is my mistake?!
                          strawberry 3.141 Project Sponsor Module Developer @FreddeHamm
                          @FreddeHamm you should remove the api key from your post, it’s kind of a password.
                          I have to look on this on the weekend, can’t spot something obvious right now
                          • F Offline
                            FreddeHamm
                            any news?
                              @FreddeHamm sorry, forgot about you. cant reproduce your issue though, i did a refresh install of mmm-fuel on my machine and inserted your config which resulted in the following state
                              can you spot any errors in the logs (electron or terminal, pm2)? did you try to disable all other modules to reduce side effects?
                              • F Offline
                                FreddeHamm
                                Thanks for your help. If i open the magic mirror site via browser (my.rasperry.pi.ip:8080) i see the module. But its not shown on the screen of the mirror itself…
                                  @FreddeHamm any errors?
                                  • F Offline
                                    FreddeHamm
                                    noob-question: how can i see the log?
                                      @FreddeHamm in the terminal where you start the mirror or pm2 logs, and in the electron console(start the mirror with npm start dev)
                                      • F Offline
                                        FreddeHamm
                                        i found this
                                        ** Message: console message: http://localhost:8080/modules/MMM-Fuel//MMM-Fuel.js @117: SyntaxError: Unexpected token ‘(’. Expected a ‘:’ following the property name 'getTranslati$
                                        • F Offline
                                          FreddeHamm
                                          if i use npm start dev i get this…
                                          1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’, ‘dev’ ]
                                          2 info using npm@5.5.1
                                          3 info using node@v8.3.0
                                          4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
                                          5 verbose stack Error: ENOENT: no such file or directory, open ‘/home/pi/package.json’
                                          6 verbose cwd /home/pi
                                          7 verbose Linux 4.9.35+
                                          8 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start” “dev”
                                          9 verbose node v8.3.0
                                          10 verbose npm v5.5.1
                                          11 error path /home/pi/package.json
                                          12 error code ENOENT
                                          13 error errno -2
                                          14 error syscall open
                                          15 error enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                                          16 error enoent This is related to npm not being able to find a file.
                                          17 verbose exit [ -2, true ]
                                          I did try to set up another mm … Same problem. only the fuel module doesnt show up. But if i use the browser on my pc it shows up…
                                          • Y Offline
                                            yawns Moderator @FreddeHamm
                                            @FreddeHamm
                                            Looks like you are not in the MagicMirror folder when running npm start dev
                                            Please try
                                            npm start dev
                                            • 4 / 9
