    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 579.6k Views 48 Watching
      Stabber
      A great modul!!
      What should I do to see the map? I have google maps API, but I don’t know where to add it.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Stabber
        @Stabber Currently the map can only be shown with my voice module https://github.com/fewieden/MMM-voice
          sindbad6
          Hi, I made a change in my MM-Fuel.js to implement an additional parameter for shortening the address of a gas station. It is not a big thing, but I would like if it would be integrated in the repository. The point is, I never have done it before. In between I got an account at github, but know? Can somebody give me a link where I can find belonging infos?
            strawberry 3.141 Project Sponsor Module Developer @sindbad6
            @sindbad6 in short:
            • fork the repository
            • make your changes
            • push them to the fork
            • create a pull request
              sindbad6 @strawberry 3.141
              @strawberry-3.141 Ok, I did it now. I’m not sure if I did right. Please inform me if something was wrong. I’m a little bit surprised, to get the possibility to merge my changes.
                @sindbad6 you closed your pull request and deleted the branch so there is no possibility to merge your changes
                  @strawberry-3.141 That’s what I was afraid of. I will try to correct it.
                    Changelog v1.1.0
                    • API provider development Guide.
                    • API provider spritpreisrechner.at.
                    • Disabled markdownlint rule MD026 (no-trailing-punctuation)
                    • Disabled eslint rule no-console
                    • Doclets.io integration
                    • Contributing guidelines
                    • Issue template
                    • Pull request template
                    [card:fewieden/MMM-Fuel]
                      Anhalter42
                      Anyone considered adding support of multiple locations? Useful for example for commuters to lookup prices at start and destination (and/or somewhere in between) of their daily way to work.
                      • garblefluxG Offline
                        garbleflux Project Sponsor
                        hi strawberry. Absolut nice work, I use it daily! One question: How did you get the in the example (Cheapest Gas Stations) all the text in the listing left justified?
                          strawberry 3.141 Project Sponsor Module Developer @garbleflux
                          @garbleflux if you scroll down there is module configuration https://github.com/MichMich/MagicMirror#configuration you can add the class align-left
                            Changelog v1.1.1
                            • Disabled markdownlint rule MD024 (no-duplicate-header)
                            • Config option toFixed to show only 2 decimals for the price.
                            • Coordinate.to() throws exception if start point is not set.
                            Upcoming release v1.2.0
                            https://github.com/fewieden/MMM-Fuel/projects/1
                            • rudibaraniR Offline
                              rudibarani Project Sponsor @strawberry 3.141
                              Hi @strawberry-3.141,
                              thanks for creating this great module! Would any of the following be possible?
                              • hide the distance column
                              • show the prices of pre-selected gas stations
                              • show e.g. the three cheapest plus some pre-selected gas stations
                                strawberry 3.141 Project Sponsor Module Developer @rudibarani
                                @rudibarani you can hide the distance column with css in custom.css, the other points are currently not possible
                                • K Offline
                                  kiki99
                                  Hi and Thanks for this module.
                                  I’ve only one Problem: I did not get the column with the price ;)
                                  It seems all other things are okay.
                                  What can i do/check?
                                  Thanks a lot for every tip :)
                                    strawberry 3.141 Project Sponsor Module Developer @kiki99
                                    @kiki99 can you post your config?
                                    • K Offline
                                      kiki99 @strawberry 3.141
                                      @strawberry-3.141: yes, of course ;)
                                      		module: 'MMM-Fuel',
                                      		position: 'lower_third',
                                          		api_key: 'myApiKeyHere,
                                          		lat: 49.164136,
                                          		lng: 9.059751,
                                          		types: ["E5"],
                                      		sortBY: "E5",
                                      		radius: 10,
                                      		colored: true,
                                      		open: true,
                                      		rotate: false
                                      i see no prices (no column for that). But the List works.
                                        @kiki99
                                          module: 'MMM-Fuel',
                                            api_key: 'myApiKeyHere',
                                            lat: 49.164136,
                                            lng: 9.059751,
                                            types: ["e5"],
                                            sortBy: "e5",
                                            radius: 10,
                                            colored: true,
                                            open: true,
                                            rotate: false
                                        • K Offline
                                          @strawberry-3.141 Oh my …, sorry for this stupid Mistake and the bad format.
                                          Many thanks for the quick help :)
                                          • F Offline
                                            FreddeHamm
                                            @strawberry-3.141 I have some issues getting this thing fired up. I have a working api and found my location. But for some reason, the magic mirror won’t show the Fuel List.
                                              module: "MMM-Fuel",
                                              position: "bottom_right",
                                                api_key: 'Just My API',
                                                lat: 51.674177,
                                                lng: 6.460384,
                                                types: ["diesel"],
                                                sortBy: "diesel",
                                                radius: 10,
                                                colored: true,
                                                open: true,
                                                rotate: false
                                            Where is my mistake?!
                                            • 4 / 9
