    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 586.1k Views 48 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @reaper81
      @reaper81 the api only provides diesel e5 and e10 sorry
        jayjay2017
        Hi
        If I take the example with a matching token,
        “Node serveronly” does not start.
        Loading config …
        Loading module helpers …
        WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
        Whoops! There was an uncaught exception…
        [SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode]
        var config = {
        port: 8070,
        ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “192.168.1.22”],
        language: 'de',
        timeFormat: 24,
        units: 'metric',
        module: ‘MMM-Fuel’,
        position: ‘top_right’,
        api_key: ‘f9fXXXXXXX’,
        lat: 51.899177,
        lng: 10.184662,
        types: [‘diesel’],
        Y strawberry 3.141S 2 Replies Last reply Reply Quote 0
        • Y
          yawns Moderator @jayjay2017
          @jayjay2017 please post your config without api keys or check your config on jshint.com
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @jayjay2017
            @jayjay2017 sounds like your node version doesnt support es6 which node version are you using?
              jayjay2017
              The version of node was the point. I had Version 4.2.6, now updated to V7.7.2.
              It works now.
              Thank you very much.
                sindbad6
                Hi, have an issue with the shortenText parameter. When I use it, the address is max shorter(in px) then the name of the gas station. That’s a little bit anoying if more then one station is shown from the big companies and I can’t see the complete address, even if there is still enough place. Any idea, how I can change it? In the custom.css for example.
                0_1489269011731_upload-acb11020-7933-41d5-a659-9402199ec1a1
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @sindbad6
                  @sindbad6 looks strange, your name gets cut after 35 chars and your address after ~19 can you send me your geo data you’re using in config as a private message?
                    sindbad6 @strawberry 3.141
                    @strawberry-3.141 Sorry, I’m a complete newbie and can’t see how to send a private message. I tried it over the chat button. I hope you meant this.
                    • strawberry 3.141S
                      @sindbad6 do a git pull in ~/MagicMirror/modules/MMM-Fuel
                        @strawberry-3.141 Thanks a lot. That’s much better.
                          Stabber
                          A great modul!!
                          What should I do to see the map? I have google maps API, but I don’t know where to add it.
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @Stabber
                            @Stabber Currently the map can only be shown with my voice module https://github.com/fewieden/MMM-voice
                              sindbad6
                              Hi, I made a change in my MM-Fuel.js to implement an additional parameter for shortening the address of a gas station. It is not a big thing, but I would like if it would be integrated in the repository. The point is, I never have done it before. In between I got an account at github, but know? Can somebody give me a link where I can find belonging infos?
                              • strawberry 3.141S
                                @sindbad6 in short:
                                • fork the repository
                                • make your changes
                                • push them to the fork
                                • create a pull request
                                  @strawberry-3.141 Ok, I did it now. I’m not sure if I did right. Please inform me if something was wrong. I’m a little bit surprised, to get the possibility to merge my changes.
                                  • strawberry 3.141S
                                    @sindbad6 you closed your pull request and deleted the branch so there is no possibility to merge your changes
                                      @strawberry-3.141 That’s what I was afraid of. I will try to correct it.
                                      • strawberry 3.141S
                                        Changelog v1.1.0
                                        • API provider development Guide.
                                        • API provider spritpreisrechner.at.
                                        • Disabled markdownlint rule MD026 (no-trailing-punctuation)
                                        • Disabled eslint rule no-console
                                        • Doclets.io integration
                                        • Contributing guidelines
                                        • Issue template
                                        • Pull request template
                                        [card:fewieden/MMM-Fuel]
                                        • A
                                          Anhalter42
                                          Anyone considered adding support of multiple locations? Useful for example for commuters to lookup prices at start and destination (and/or somewhere in between) of their daily way to work.
                                          • garblefluxG
                                            garbleflux Project Sponsor
                                            hi strawberry. Absolut nice work, I use it daily! One question: How did you get the in the example (Cheapest Gas Stations) all the text in the listing left justified?
                                            • 3 / 9
