    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 586.1k Views 48 Watching
      DeSlow
      do you meen this
      module: “MMM-Fuel”,
      position: “top_right”,
      api_key: “api key”,
      lat: 53.931775,
      lng: 9.505148,
      types: [“e5”],
      strawberry 3.141S D 2 Replies Last reply Reply Quote 0
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @DeSlow
        @DeSlow you should remove the api key here in the forum this is kind of a password and should not be shared with someone else. i will test this on my machine
          DeSlow @DeSlow
            DeSlow
            and 1 question to this:
            Dependencies
            An installation of MagicMirror2
            OPTIONAL: Voice Control
            npm
            request -------what is this and what got i go white is
            im so bad in englisch, got dam
            • strawberry 3.141S
              @DeSlow The config works for me when I replace the quotes. check your pm for support in german
              EDIT: the problem was a missing comma in the config file
                Dom1n1c
                The Addon works great
                But: is a filter based on opened station in a defined radius possible?
                I want to hide the distance and detailed address, to reduce the size of the mmm-fuel box.
                Only Shell (Zip/City), Aral (Zip/City) should be displayed.
                my requirements in detail:
                no rotate (check)
                2 types of gas (check)
                maximum of 3 displayed station (check)
                not possible yet:
                display only open stations
                reduce length of the station name, remove address, or at least shorten.
                Thanks (and merry christmas btw)
                  Dom1n1c @Dom1n1c
                  Furthermore i want to hide the car icon, because it does not fit into the mm style (just my opinion)
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @Dom1n1c
                    Changelog:
                    4 new config options
                    • shortenText: shorten name and address after certain characters
                    • showAddress: show address of gas station or not
                    • showOpenOnly: show only gas stations that are open or all
                    • iconHeader: display icon in header
                    [card:fewieden/MMM-Fuel]
                      Dom1n1c
                      I did a replacement on the Station names, because “Shell” is typically naming there stations after the Street name.
                      I fixed the City name to have only the first Letter in uppercase.
                      How can i remove the " null" part, which is occuring at JET stations,
                      or how can i tidy up the street names? (every seperate word starting with an uppercase)
                      of course i can start with a list of the complete string that should be replaced, but there might be another option.
                      • strawberry 3.141S
                        @Dom1n1c
                        • null @jets is propably that they inserted the house number in the street name and the house number value returns null
                        • for the street names i would split at the space character and then for each array item charAt(0).toUpperCase() and the rest of the string lowercase and finally join them together
                          Dom1n1c
                          I added checks for house numbers==null and splitted the street names.
                          Also the Brand names starting with (star,ESSO,Aral were replaced automatically)
                          (Shell and no-name stations are a special case, so i need to handle them individually)
                          But, there is still another special case:
                          Streetnames with " " or “-” should be splitted, but no housenumbers (from JET :D ).
                          How can i avoid splitting numbers:
                          This is the section that does the splitting
                          words = str.toLowerCase().split(/-| /);
                          can be found here in total:
                          https://github.com/Dom1n1c/MMM-Fuel/blob/master/MMM-Fuel.js
                          • strawberry 3.141S
                            @Dom1n1c I commented on your changes
                              reaper81
                              Is it possible to choose other typs of fuel like non-leaded supergrade plus petrol or premium?
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @reaper81
                                @reaper81 the api only provides diesel e5 and e10 sorry
                                  jayjay2017
                                  Hi
                                  If I take the example with a matching token,
                                  “Node serveronly” does not start.
                                  Loading config …
                                  Loading module helpers …
                                  WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                                  Whoops! There was an uncaught exception…
                                  [SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode]
                                  var config = {
                                  port: 8070,
                                  ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “192.168.1.22”],
                                  language: 'de',
                                  timeFormat: 24,
                                  units: 'metric',
                                  module: ‘MMM-Fuel’,
                                  position: ‘top_right’,
                                  api_key: ‘f9fXXXXXXX’,
                                  lat: 51.899177,
                                  lng: 10.184662,
                                  types: [‘diesel’],
                                  Y strawberry 3.141S 2 Replies Last reply Reply Quote 0
                                  • Y
                                    yawns Moderator @jayjay2017
                                    @jayjay2017 please post your config without api keys or check your config on jshint.com
                                    • strawberry 3.141S
                                      strawberry 3.141 Project Sponsor Module Developer @jayjay2017
                                      @jayjay2017 sounds like your node version doesnt support es6 which node version are you using?
                                        jayjay2017
                                        The version of node was the point. I had Version 4.2.6, now updated to V7.7.2.
                                        It works now.
                                        Thank you very much.
                                          sindbad6
                                          Hi, have an issue with the shortenText parameter. When I use it, the address is max shorter(in px) then the name of the gas station. That’s a little bit anoying if more then one station is shown from the big companies and I can’t see the complete address, even if there is still enough place. Any idea, how I can change it? In the custom.css for example.
                                          0_1489269011731_upload-acb11020-7933-41d5-a659-9402199ec1a1
                                          • strawberry 3.141S
                                            strawberry 3.141 Project Sponsor Module Developer @sindbad6
                                            @sindbad6 looks strange, your name gets cut after 35 chars and your address after ~19 can you send me your geo data you’re using in config as a private message?
                                            • 3 / 9
