    Slim Monitor or TV
    9 Posts 4 Posters 8.1k Views 5 Watching
      SoleLo
      Can you guys share if you know what brands has slim monitors or TVs to use for my build. I’m looking for something about 28-32"? Any information will be greatly appreciated.
      • cowboysdudeC Offline
        cowboysdude Module Developer @SoleLo
        @SoleLo Not sure about TV but do your homework… some tv’s are better than others as monitors…
          SoleLo
          Yeah I’ve been looking, mostly seems like Samsung ones are the best. I just want to see if anyone has any other recommendations
          • slametpsS Offline
            slametps
            I’m using 24" TV. But for better quality, you should consider using a monitor rather than a TV (based on ppi value).
            regards,
            Slamet PS
            S A 2 Replies Last reply Reply Quote 2
              SoleLo @slametps
              @slametps that makes sense. I’ll keep that in mind.
                almasgai @slametps
                @slametps Hi, I’m considering using a 720p TV with a USB to power my RPi and because a TV has built in speakers. TV’s are a lot cheaper than monitors in my area so I am leaning towards purchasing a 720p TV. If you do not mind me asking, is using a TV worth it in your experience or should I just spend more on a monitor? Any help is greatly appreciated. Thank you!
                slametpsS 1 Reply Last reply Reply Quote 0
                • slametpsS Offline
                  slametps @almasgai
                  @almasgai I’m using FHD TV myself. If you’re satisfied enough with the display result, that’s ok. But I think, it will be much better display if using monitor. Power source for raspi, it is not recommended to use USB port from the TV since raspi require 5v 2A for better performance since USB from TV just have 1A or less output.
                  regards,
                  Slamet PS
                  A 1 Reply Last reply Reply Quote 2
                    almasgai @slametps
                    @slametps Thank you so much! I ended up getting a monitor.
                    • slametpsS Offline
                      slametps @almasgai
                      @almasgai said in Slim Monitor or TV:
                      @almasgai Please ensure that if your requirement and goal about MM is also involving sound output, using TV rather than monitor is better choice, except monitor is already has built-in speaker. It is also my consideration about using TV for my MM.
                      regards,
                      Slamet PS
