    How do I make my 27" monitor (smartmirror) touchscreen *using raspberry Pi*
    Scheduled Pinned Locked Moved Solved Hardware
    24 Posts 5 Posters 37.5k Views 4 Watching
    • T
      TheMexicoon @broberg
      @broberg how does the coding work because i was planning on using Android os on the Pi would that be a viable option? Im open to use linux but would prefer android
      B 1 Reply Last reply
        broberg Project Sponsor @TheMexicoon
        @TheMexicoon Should work on android as well as long as the android OS and IR-Frame support each others.
        The frame should just be recognized and used as any other input (like mouse or keyboard), no coding should be necessary.
        T 1 Reply Last reply
        • T
          @broberg Oh sweet! Whats the price range on Ir panels that are 27" because the one i found came to $240 wondering if there’s any cheaper options
            @TheMexicoon That I don’t know, Maybe somebody else will chime in with some better information!
            • T
              @broberg Alright thanks for your help man, appreciate it
              • cowboysdudeC
                I don’t understand I just got a 32" IR Frame from AliExpress for 111.00 that included shipping…
                I’m here to tell you it works perfectly!!
                • cowboysdudeC
                  Go here: Store name: NCOOVERLAYFOIL TouchScreen Store On AliExpress these guys are awesome!!
                  T 2 Replies Last reply
                  • T
                    TheMexicoon @cowboysdude
                    • T
                      @cowboysdude i found the store, its $137 for 32" 6 point touch which comes to $180 dollars (aud)
                      cowboysdudeC strawberry 3.141S 2 Replies Last reply
                      • cowboysdudeC
                        cowboysdude Module Developer @TheMexicoon
                        @TheMexicoon said in How do I make my 27" monitor (smartmirror) touchscreen *using raspberry Pi*:
                        Wow… that’s alot…
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @TheMexicoon
                          @TheMexicoon when I used to live in Australia everything was 2-3 times more expensive than elsewhere, but also the minimum salary was about 21$/hour so i think this is still a valuable price
                          • T
                            TheMexicoon @strawberry 3.141
                            @strawberry-3.141 so you think this is the cheapest im going to find???
                            • strawberry 3.141S
                              @TheMexicoon not saying that, but you probably can find the cheapest on aliexpress. my old roommate bought nearly everything there and sometimes even imported containers :D
                              • T
                                @strawberry-3.141 found this ???https://www.aliexpress.com/item/27-Inch-16-9-Wide-Multi-Touch-IR-Infrared-Touch-Screen-Frame-Overlay-Kit-2-4/32360101915.html?spm=2114.01010208.3.385.SfrBFY&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10130_10068_433_434_10136_10137_10138_10060_10131_10132_10062_10133_10141_10056_10140_126_10055_10054_10059_10099_10103_10102_10096_10052_10053_10050_10107_10142_10051_10106_10084_10083_10080_10082_10081_10110_10111_10112_10113_10114_10078_10079_10073_10070_10122_10123_10124,searchweb201603_1,afswitch_1,ppcSwitch_5,single_sort_0_price_asc&btsid=8984b02b-d7da-48f7-aa17-07e18aa40e7d&algo_expid=1f5fae33-a294-42bf-bc8a-bd6938b6e93c-46&algo_pvid=1f5fae33-a294-42bf-bc8a-bd6938b6e93c
                                • strawberry 3.141S
                                  @TheMexicoon I don’t have experience with ir frames, but this is 200AUD included shipping
                                    rentaro
                                    Thanks for the great advice, was wondering so these IR touch frames work with the acrylic see-through mirror film?
                                    • cowboysdudeC
                                      cowboysdude Module Developer @rentaro
                                      @rentaro I would ask the people you are buying it from. I mean it works with 1/8 glass so I would think it would …
                                        rentaro
                                        Thanks for the advice will post a reply once ive put it together to share my results
