    How do I make my 27" monitor (smartmirror) touchscreen *using raspberry Pi*
    Scheduled Pinned Locked Moved Solved Hardware
    24 Posts 5 Posters 37.5k Views 4 Watching
    • T
      TheMexicoon @cowboysdude
      @cowboysdude i found the store, its $137 for 32" 6 point touch which comes to $180 dollars (aud)
      cowboysdudeC strawberry 3.141S 2 Replies Last reply
      • cowboysdudeC
        cowboysdude Module Developer @TheMexicoon
        @TheMexicoon said in How do I make my 27" monitor (smartmirror) touchscreen *using raspberry Pi*:
        Wow… that’s alot…
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @TheMexicoon
          @TheMexicoon when I used to live in Australia everything was 2-3 times more expensive than elsewhere, but also the minimum salary was about 21$/hour so i think this is still a valuable price
          T 1 Reply Last reply
          • T
            TheMexicoon @strawberry 3.141
            @strawberry-3.141 so you think this is the cheapest im going to find???
            • strawberry 3.141S
              @TheMexicoon not saying that, but you probably can find the cheapest on aliexpress. my old roommate bought nearly everything there and sometimes even imported containers :D
              • T
                @strawberry-3.141 found this ???https://www.aliexpress.com/item/27-Inch-16-9-Wide-Multi-Touch-IR-Infrared-Touch-Screen-Frame-Overlay-Kit-2-4/32360101915.html?spm=2114.01010208.3.385.SfrBFY&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10130_10068_433_434_10136_10137_10138_10060_10131_10132_10062_10133_10141_10056_10140_126_10055_10054_10059_10099_10103_10102_10096_10052_10053_10050_10107_10142_10051_10106_10084_10083_10080_10082_10081_10110_10111_10112_10113_10114_10078_10079_10073_10070_10122_10123_10124,searchweb201603_1,afswitch_1,ppcSwitch_5,single_sort_0_price_asc&btsid=8984b02b-d7da-48f7-aa17-07e18aa40e7d&algo_expid=1f5fae33-a294-42bf-bc8a-bd6938b6e93c-46&algo_pvid=1f5fae33-a294-42bf-bc8a-bd6938b6e93c
                • strawberry 3.141S
                  @TheMexicoon I don’t have experience with ir frames, but this is 200AUD included shipping
                    rentaro
                    Thanks for the great advice, was wondering so these IR touch frames work with the acrylic see-through mirror film?
                    • cowboysdudeC
                      cowboysdude Module Developer @rentaro
                      @rentaro I would ask the people you are buying it from. I mean it works with 1/8 glass so I would think it would …
                        rentaro
                        Thanks for the advice will post a reply once ive put it together to share my results
