    stumped newbe
    40 Posts 3 Posters 24.1k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @trader dude
      @trader-dude said in stumped newbe:
      ok i posted some pic hope this helps
      Here is my entry for weather. Please post yours here so I can see it
      		module: "currentweather",
      		position: "top_right",	// This can be any of the regions.
      			locationID: "", //Location ID from http://openweathermap.org/help/city_list.txt
      			appid: "abcde12345abcde12345abcde12345ab" //openweathermap.org API key.
        Mykle1 Project Sponsor Module Developer @Mykle1
        Just copy your config.js file and past it here, as I have done above
        • T Offline
          trader dude
          https://goo.gl/photos/2GKDMrT24BDquX498
          Mykle1M T 2 Replies Last reply Reply Quote 0
            @trader-dude It’s not very easy to see those pictures so it’s difficult for me to help you. Can you paste your config here instead of linking it to a picture?
              @Mykle1 Just put XXXXXXXXXXXXXXXXX where your api key goes
              • yawnsY Offline
                yawns Moderator
                There is no error message, it just says there is no helper module. That’s fine, these modules don’t use a helper module.
                There was another guy some days ago with the same trouble, but he switched to Wunderground so we were unable to troubleshoot
                • T Offline
                  trader dude @trader dude
                  @trader-dude does that help?give me a sec i will do that
                    @trader-dude Lets start with locationID: That is usually a 6 digit number obtained from openweathermap.org. e.g 512856. Make sure that is correct. Next, the appid: is just a long sequence of numbers and letters obtained from openweathermap.org. e.g 12345gu3454uddu4u5uu64u3. Make sure you enter this exactly as provided. Do not enter the entire url, just the number itself. You need to do that in both the currentweather and weatherforecast.
                    • T Offline
                      trader dude @Mykle1
                      @Mykle1 that i have can i post That?
                        your appid? No, don’t post that. That is yours and it is private
                        • 1 / 4
