    MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures)
    84 Posts 25 Posters 106.7k Views 25 Watching
    • BehB Offline
      Beh @Jay
      Hey @Jay,
      what did you have to change for the module name in the config?! o_O
      I didn’t make any changes according this…
      You can get valid station IDs via an easy cURL command as mentioned in the readme like this (you can do it from the mirror’s command line):
      curl 'https://transport.rest/stations?query=alexanderplatz'
      You just have to switch ‘alexanderplatz’ with your nearest station. This command will return all station fitting the search term.
      JayJ 1 Reply Last reply Reply Quote 0
      • JayJ Offline
        Jay @Beh
        @Beh
        After the recent update from olexs (2-3 days ago), the module works like a charm.
        • BehB Offline
          Beh
          Okay, I think there’s a misunderstanding here.
          To make things clear for the future:
          The Module from @olexs MMM-PublicTransportDB is not really the same as my MMM-PublicTransportBerlin. Olexs made some changes on the original module to use the data from DB (Deutsche Bahn) while my module is just using the data from VBB (Verkehrsverbund Berlin-Brandenburg).
          I think this could be the reason why the stationIds you used did not work @Jay. Since you used a stationId from VBB for DB data. I didn’t test this but maybe @olexs can make a statement to this?
            Dicous
              Dicous
              Hallo Gemeinde,
              ich probiere es mal in Deutsch.
              Wenn ich das Module hinzufüge, sehe ich nur noch ein schwarzen Bildschirm. Kann mir jmd helfen?
              Vielen Dank.
              /* Magic Mirror Config Sample
               * MIT Licensed.
              var config = {
              	port: 8080,
              	language: 'de',
              	timeFormat: 24,
              	units: 'metric',
              			module: 'alert',
              			module: "updatenotification",
              			position: "top_bar"
              			module: 'clock',
              			position: 'top_left'
              			module: 'calendar',
              			header: 'Berlin',
              			position: 'top_left',
              						symbol: 'calendar-check-o ',
              						url: 'https://calendar.google.com/calendar/ical/XXXX.ics'
              			module: 'calendar',
              			header: 'Basti',
              			module: 'compliments',
              			position: 'lower_third'
              			module: 'currentweather',
              			position: 'top_right',
              				locationID: '6545310',  //ID from http://www.openweathermap.org
              				appid: 'xxx'
              			module: 'weatherforecast',
              			header: 'Weather Forecast',
              				appid: 'xxx'
              				locationID: '2937591',  //ID from http://www.openweathermap.org
              				appid: '6f549a70275dff25b166f08f5ea012f7'
              			module: 'newsfeed',
              			position: 'bottom_bar',
              				feeds: [
              						title: "Spiegel Online",
              						url: "http://www.spiegel.de/schlagzeilen/tops/index.rss"
              						title: "Kicker",
              						url: "http://rss.kicker.de/news/fussball"
              				showSourceTitle: true,
              				showPublishDate: true
                  module: 'MMM-PublicTransportBerlin',
                  position: 'bottom_right',
                      stationId: 900000120003,
                      hidden: false,
                      ignoredStations: [9100003,2342,1337],
                      excludedTransportationTypes: 'bus,suburban,subway',
                      delay: 10,
                      interval: 120000,
                      departureMinutes: 10,
                      maxDepartures: 15,
                      marqueeLongDirections: true,
                      showColoredLineSymbols: true,
                      useColorForRealtimeInfo: true,
                      showTableHeadersAsSymbols: true,
                      maxUnreachableDepartures: 3,
                      maxReachableDepartures: 7,
                      fadeUnreachableDepartures: true,
                      fadeReachableDepartures: true,
                      fadePointForReachableDepartures: 0.25
              • yawnsY Offline
                yawns Moderator @Dicous
                @Dicous
                Did you install (git clone) the module into the right folder ~/MagicMirror/modules/ ? Did you also run npm install in the new subfolder ~/MagicMirror/modules/MMM-PublicTransportBerlin ?
                  Dicous
                  yes. i did:
                  pi@raspberrypi:~/MagicMirror/modules/default $ git clone https://github.com/deg0nz/MMM-PublicTransportBerlin.git
                  Klone nach 'MMM-PublicTransportBerlin'...
                  remote: Counting objects: 184, done.
                  remote: Total 184 (delta 0), reused 0 (delta 0), pack-reused 184
                  Empfange Objekte: 100% (184/184), 109.67 KiB | 0 bytes/s, Fertig.
                  Löse Unterschiede auf: 100% (110/110), Fertig.
                  Prüfe Konnektivität... Fertig.
                  pi@raspberrypi:~/MagicMirror/modules/default $ cd MMM-PublicTransportBerlin
                  pi@raspberrypi:~/MagicMirror/modules/default/MMM-PublicTransportBerlin $ npm install
                  MMM-PublicTransportBerlin@0.2.0 /home/pi/MagicMirror/modules/default/MMM-PublicTransportBerlin
                  └─┬ vbb-client@1.0.0
                    ├─┬ isomorphic-fetch@2.2.1
                    │ ├─┬ node-fetch@1.6.3
                    │ │ ├─┬ encoding@0.1.12
                    │ │ │ └── iconv-lite@0.4.15
                    │ │ └── is-stream@1.1.0
                    │ └── whatwg-fetch@2.0.3
                    └─┬ ndjson@1.5.0
                      ├── json-stringify-safe@5.0.1
                      ├── minimist@1.2.0
                      ├── split2@2.1.1
                      └─┬ through2@2.0.3
                        ├─┬ readable-stream@2.2.6
                        │ ├── buffer-shims@1.0.0
                        │ ├── core-util-is@1.0.2
                        │ ├── inherits@2.0.3
                        │ ├── isarray@1.0.0
                        │ ├── process-nextick-args@1.0.7
                        │ ├── string_decoder@0.10.31
                        │ └── util-deprecate@1.0.2
                        └── xtend@4.0.1
                  • yawnsY Offline
                    yawns Moderator
                    No, you did not. You are in ~/MagicMirror/modules/default and not ~/MagicMirror/modules. Modules in default won’t be executed, the default area is “protected”.
                      Dicous
                      Thank You.
                      I am still a Noob
                      You made my day
                      • O Offline
                        olexs @Beh
                        @Beh This is correct. Station IDs are different between DB and BVG networks (and others, such as my local RMV), and I haven’t yet added a proper error message for “wrong” IDs, instead it fails silently. Getting DB IDs is a bit of a pain, too, I’m working on a small public interface for that. I’ll open a separate thread for the fork.
                        While I’m here: thanks a lot for your work! Without your code, my module would never exist. I’ve put an attribution in the readme, if you want it higher up just say a word :)
                        BehB rudibaraniR 2 Replies Last reply Reply Quote 0
                        • 3 / 9
