    MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures)
    84 Posts 25 Posters 124.8k Views 25 Watching
    • BehB
      Beh @Jay
      Hey @Jay,
      what did you have to change for the module name in the config?! o_O
      I didn’t make any changes according this…
      You can get valid station IDs via an easy cURL command as mentioned in the readme like this (you can do it from the mirror’s command line):
      curl 'https://transport.rest/stations?query=alexanderplatz'
      You just have to switch ‘alexanderplatz’ with your nearest station. This command will return all station fitting the search term.
      JayJ 1 Reply Last reply
      • JayJ
        Jay @Beh
        @Beh
        After the recent update from olexs (2-3 days ago), the module works like a charm.
        • BehB
          Beh
          Okay, I think there’s a misunderstanding here.
          To make things clear for the future:
          The Module from @olexs MMM-PublicTransportDB is not really the same as my MMM-PublicTransportBerlin. Olexs made some changes on the original module to use the data from DB (Deutsche Bahn) while my module is just using the data from VBB (Verkehrsverbund Berlin-Brandenburg).
          I think this could be the reason why the stationIds you used did not work @Jay. Since you used a stationId from VBB for DB data. I didn’t test this but maybe @olexs can make a statement to this?
          O 1 Reply Last reply
            Dicous
              Dicous
              Hallo Gemeinde,
              ich probiere es mal in Deutsch.
              Wenn ich das Module hinzufüge, sehe ich nur noch ein schwarzen Bildschirm. Kann mir jmd helfen?
              Vielen Dank.
              /* Magic Mirror Config Sample
               * MIT Licensed.
              var config = {
              	port: 8080,
              	language: 'de',
              	timeFormat: 24,
              	units: 'metric',
              			module: 'alert',
              			module: "updatenotification",
              			position: "top_bar"
              			module: 'clock',
              			position: 'top_left'
              			module: 'calendar',
              			header: 'Berlin',
              			position: 'top_left',
              						symbol: 'calendar-check-o ',
              						url: 'https://calendar.google.com/calendar/ical/XXXX.ics'
              			module: 'calendar',
              			header: 'Basti',
              			module: 'compliments',
              			position: 'lower_third'
              			module: 'currentweather',
              			position: 'top_right',
              				locationID: '6545310',  //ID from http://www.openweathermap.org
              				appid: 'xxx'
              			module: 'weatherforecast',
              			header: 'Weather Forecast',
              				appid: 'xxx'
              				locationID: '2937591',  //ID from http://www.openweathermap.org
              				appid: '6f549a70275dff25b166f08f5ea012f7'
              			module: 'newsfeed',
              			position: 'bottom_bar',
              				feeds: [
              						title: "Spiegel Online",
              						url: "http://www.spiegel.de/schlagzeilen/tops/index.rss"
              						title: "Kicker",
              						url: "http://rss.kicker.de/news/fussball"
              				showSourceTitle: true,
              				showPublishDate: true
                  module: 'MMM-PublicTransportBerlin',
                  position: 'bottom_right',
                      stationId: 900000120003,
                      hidden: false,
                      ignoredStations: [9100003,2342,1337],
                      excludedTransportationTypes: 'bus,suburban,subway',
                      delay: 10,
                      interval: 120000,
                      departureMinutes: 10,
                      maxDepartures: 15,
                      marqueeLongDirections: true,
                      showColoredLineSymbols: true,
                      useColorForRealtimeInfo: true,
                      showTableHeadersAsSymbols: true,
                      maxUnreachableDepartures: 3,
                      maxReachableDepartures: 7,
                      fadeUnreachableDepartures: true,
                      fadeReachableDepartures: true,
                      fadePointForReachableDepartures: 0.25
              yawnsY 1 Reply Last reply
              • yawnsY
                yawns Moderator @Dicous
                @Dicous
                Did you install (git clone) the module into the right folder ~/MagicMirror/modules/ ? Did you also run npm install in the new subfolder ~/MagicMirror/modules/MMM-PublicTransportBerlin ?
                  Dicous
                  yes. i did:
                  pi@raspberrypi:~/MagicMirror/modules/default $ git clone https://github.com/deg0nz/MMM-PublicTransportBerlin.git
                  Klone nach 'MMM-PublicTransportBerlin'...
                  remote: Counting objects: 184, done.
                  remote: Total 184 (delta 0), reused 0 (delta 0), pack-reused 184
                  Empfange Objekte: 100% (184/184), 109.67 KiB | 0 bytes/s, Fertig.
                  Löse Unterschiede auf: 100% (110/110), Fertig.
                  Prüfe Konnektivität... Fertig.
                  pi@raspberrypi:~/MagicMirror/modules/default $ cd MMM-PublicTransportBerlin
                  pi@raspberrypi:~/MagicMirror/modules/default/MMM-PublicTransportBerlin $ npm install
                  MMM-PublicTransportBerlin@0.2.0 /home/pi/MagicMirror/modules/default/MMM-PublicTransportBerlin
                  └─┬ vbb-client@1.0.0
                    ├─┬ isomorphic-fetch@2.2.1
                    │ ├─┬ node-fetch@1.6.3
                    │ │ ├─┬ encoding@0.1.12
                    │ │ │ └── iconv-lite@0.4.15
                    │ │ └── is-stream@1.1.0
                    │ └── whatwg-fetch@2.0.3
                    └─┬ ndjson@1.5.0
                      ├── json-stringify-safe@5.0.1
                      ├── minimist@1.2.0
                      ├── split2@2.1.1
                      └─┬ through2@2.0.3
                        ├─┬ readable-stream@2.2.6
                        │ ├── buffer-shims@1.0.0
                        │ ├── core-util-is@1.0.2
                        │ ├── inherits@2.0.3
                        │ ├── isarray@1.0.0
                        │ ├── process-nextick-args@1.0.7
                        │ ├── string_decoder@0.10.31
                        │ └── util-deprecate@1.0.2
                        └── xtend@4.0.1
                  • yawnsY
                    yawns Moderator
                    No, you did not. You are in ~/MagicMirror/modules/default and not ~/MagicMirror/modules. Modules in default won’t be executed, the default area is “protected”.
                      Dicous
                      Thank You.
                      I am still a Noob
                      You made my day
                      • O
                        olexs @Beh
                        @Beh This is correct. Station IDs are different between DB and BVG networks (and others, such as my local RMV), and I haven’t yet added a proper error message for “wrong” IDs, instead it fails silently. Getting DB IDs is a bit of a pain, too, I’m working on a small public interface for that. I’ll open a separate thread for the fork.
                        While I’m here: thanks a lot for your work! Without your code, my module would never exist. I’ve put an attribution in the readme, if you want it higher up just say a word :)
                        BehB rudibaraniR 2 Replies Last reply
                        • BehB
                          Beh @olexs
                          @olexs
                          You’re very welcome :smile:
                          I’m happy that someone had use for it, so the code is not useless :) I already noticed the attribution in the readme and appreciated it ;) Thanks a lot
                            pauabaer
                            hey guys,
                            i am still a noob. please be patient with me :)
                            i dont know how to get the station id. obviously i dont understand the api-documentation. can you please help me with this?
                            i have already installed the mmm-publictransportberlin module and the vbb-rest from github. but now i dont get on.
                            greets
                            pauabaer
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @pauabaer
                              @pauabaer you have to open a terminal and execute the command curl 'https://transport.rest/stations?query=alexanderplatz' replace alexanderplatz with your station name or part of it. then your response will look like this
                              {"type":"station","relevance":1.0161290322580645,"id":"900000100003","name":"S+U Alexanderplatz","tokens":["sbahn","ubahn","alexanderplatz","bahnhof","berlin"]}
                              {"type":"station","relevance":1.0119047619047619,"id":"900000100006","name":"S+U Alexanderplatz/Grunerstr.","tokens":["sbahn","ubahn","alexanderplatz","bahnhof","gruner","strasse","berlin"]}
                              {"type":"station","relevance":1.015625,"id":"900000100005","name":"U Alexanderplatz [Tram]","tokens":["ubahn","alexanderplatz","berlin","tram"]}
                              so if you want to use the station S+U Alexanderplatz/Grunerstr. you have to use the id 900000100006
                                pauabaer
                                @strawberry-3-141
                                thanks! worked fine. Now i have a new question. is it possible to hide a line on a station instead of the whole station?
                                • strawberry 3.141S
                                  @pauabaer I’m not sure if that is possible as no config option looks like that it handles this case.
                                  But if it is e.g. a bus line and you want just display trams and subways you can exclude bus with excludedTransportationTypes
                                    pauabaer
                                    It is indeed a busline, but the station has only buslines. But one of these lines is for me irrelevant, that’s why I asked for that option. But it’s ok. It is a really good module. Thank you for this one!!
                                    • BehB
                                      Beh
                                      Hey, @strawberry-3-141, thanks for supporting!
                                      @pauabaer:
                                      currently there is no such function to filter out lines directly. Only to filter for stations, as @strawberry-3-141 mentioned. But I can implement that function if you want to have it. It’s not soo much effort I think… I can’t promise to do this fast, but I would try to find time for it ASAP.
                                      If you want that feature, please open an issue for that on github, so I won’t forget it ^^’
                                        pauabaer
                                        @Beh sounds great! thanks so far.
                                        for now i dont have a github acc, so i will wait a bit. i dont forget my issue. so if you forget it, i will remember this oder create a github acc ;)
                                        • BehB
                                          Beh
                                          To all users of this module:
                                          The transportation data in the background changed and I added support for this in the module. You should update the module asap.
                                          You can update it with these commands in the MMM-PublicTransportBerlin-folder:
                                          git pull
                                          npm install
                                          The npm install-command is very important, since the vbb-client module needs to be updated to use the new transport API.
                                          Greetings!
                                          • BehB
                                            Beh
                                            Hey, @pauabaer
                                            I implemented your feature request ;)
                                            you can now exclude lines via the ignoredStations option in your config.
                                            • 2 / 5
