    MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures)
    84 Posts 25 Posters 124.4k Views 25 Watching
    • BehB
      Beh
      Okay, I think there’s a misunderstanding here.
      To make things clear for the future:
      The Module from @olexs MMM-PublicTransportDB is not really the same as my MMM-PublicTransportBerlin. Olexs made some changes on the original module to use the data from DB (Deutsche Bahn) while my module is just using the data from VBB (Verkehrsverbund Berlin-Brandenburg).
      I think this could be the reason why the stationIds you used did not work @Jay. Since you used a stationId from VBB for DB data. I didn’t test this but maybe @olexs can make a statement to this?
      O 1 Reply Last reply
        Dicous
          Dicous
          Hallo Gemeinde,
          ich probiere es mal in Deutsch.
          Wenn ich das Module hinzufüge, sehe ich nur noch ein schwarzen Bildschirm. Kann mir jmd helfen?
          Vielen Dank.
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: 'de',
          	timeFormat: 24,
          	units: 'metric',
          			module: 'alert',
          			module: "updatenotification",
          			position: "top_bar"
          			module: 'clock',
          			position: 'top_left'
          			module: 'calendar',
          			header: 'Berlin',
          			position: 'top_left',
          						symbol: 'calendar-check-o ',
          						url: 'https://calendar.google.com/calendar/ical/XXXX.ics'
          			module: 'calendar',
          			header: 'Basti',
          			module: 'compliments',
          			position: 'lower_third'
          			module: 'currentweather',
          			position: 'top_right',
          				locationID: '6545310',  //ID from http://www.openweathermap.org
          				appid: 'xxx'
          			module: 'weatherforecast',
          			header: 'Weather Forecast',
          				appid: 'xxx'
          				locationID: '2937591',  //ID from http://www.openweathermap.org
          				appid: '6f549a70275dff25b166f08f5ea012f7'
          			module: 'newsfeed',
          			position: 'bottom_bar',
          				feeds: [
          						title: "Spiegel Online",
          						url: "http://www.spiegel.de/schlagzeilen/tops/index.rss"
          						title: "Kicker",
          						url: "http://rss.kicker.de/news/fussball"
          				showSourceTitle: true,
          				showPublishDate: true
              module: 'MMM-PublicTransportBerlin',
              position: 'bottom_right',
                  stationId: 900000120003,
                  hidden: false,
                  ignoredStations: [9100003,2342,1337],
                  excludedTransportationTypes: 'bus,suburban,subway',
                  delay: 10,
                  interval: 120000,
                  departureMinutes: 10,
                  maxDepartures: 15,
                  marqueeLongDirections: true,
                  showColoredLineSymbols: true,
                  useColorForRealtimeInfo: true,
                  showTableHeadersAsSymbols: true,
                  maxUnreachableDepartures: 3,
                  maxReachableDepartures: 7,
                  fadeUnreachableDepartures: true,
                  fadeReachableDepartures: true,
                  fadePointForReachableDepartures: 0.25
          yawnsY 1 Reply Last reply
          • yawnsY
            yawns Moderator @Dicous
            @Dicous
            Did you install (git clone) the module into the right folder ~/MagicMirror/modules/ ? Did you also run npm install in the new subfolder ~/MagicMirror/modules/MMM-PublicTransportBerlin ?
              Dicous
              yes. i did:
              pi@raspberrypi:~/MagicMirror/modules/default $ git clone https://github.com/deg0nz/MMM-PublicTransportBerlin.git
              Klone nach 'MMM-PublicTransportBerlin'...
              remote: Counting objects: 184, done.
              remote: Total 184 (delta 0), reused 0 (delta 0), pack-reused 184
              Empfange Objekte: 100% (184/184), 109.67 KiB | 0 bytes/s, Fertig.
              Löse Unterschiede auf: 100% (110/110), Fertig.
              Prüfe Konnektivität... Fertig.
              pi@raspberrypi:~/MagicMirror/modules/default $ cd MMM-PublicTransportBerlin
              pi@raspberrypi:~/MagicMirror/modules/default/MMM-PublicTransportBerlin $ npm install
              MMM-PublicTransportBerlin@0.2.0 /home/pi/MagicMirror/modules/default/MMM-PublicTransportBerlin
              └─┬ vbb-client@1.0.0
                ├─┬ isomorphic-fetch@2.2.1
                │ ├─┬ node-fetch@1.6.3
                │ │ ├─┬ encoding@0.1.12
                │ │ │ └── iconv-lite@0.4.15
                │ │ └── is-stream@1.1.0
                │ └── whatwg-fetch@2.0.3
                └─┬ ndjson@1.5.0
                  ├── json-stringify-safe@5.0.1
                  ├── minimist@1.2.0
                  ├── split2@2.1.1
                  └─┬ through2@2.0.3
                    ├─┬ readable-stream@2.2.6
                    │ ├── buffer-shims@1.0.0
                    │ ├── core-util-is@1.0.2
                    │ ├── inherits@2.0.3
                    │ ├── isarray@1.0.0
                    │ ├── process-nextick-args@1.0.7
                    │ ├── string_decoder@0.10.31
                    │ └── util-deprecate@1.0.2
                    └── xtend@4.0.1
              • yawnsY
                yawns Moderator
                No, you did not. You are in ~/MagicMirror/modules/default and not ~/MagicMirror/modules. Modules in default won’t be executed, the default area is “protected”.
                  Dicous
                  Thank You.
                  I am still a Noob
                  You made my day
                  • O
                    olexs @Beh
                    @Beh This is correct. Station IDs are different between DB and BVG networks (and others, such as my local RMV), and I haven’t yet added a proper error message for “wrong” IDs, instead it fails silently. Getting DB IDs is a bit of a pain, too, I’m working on a small public interface for that. I’ll open a separate thread for the fork.
                    While I’m here: thanks a lot for your work! Without your code, my module would never exist. I’ve put an attribution in the readme, if you want it higher up just say a word :)
                    BehB rudibaraniR 2 Replies Last reply
                    • BehB
                      Beh @olexs
                      @olexs
                      You’re very welcome :smile:
                      I’m happy that someone had use for it, so the code is not useless :) I already noticed the attribution in the readme and appreciated it ;) Thanks a lot
                        pauabaer
                        hey guys,
                        i am still a noob. please be patient with me :)
                        i dont know how to get the station id. obviously i dont understand the api-documentation. can you please help me with this?
                        i have already installed the mmm-publictransportberlin module and the vbb-rest from github. but now i dont get on.
                        greets
                        pauabaer
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @pauabaer
                          @pauabaer you have to open a terminal and execute the command curl 'https://transport.rest/stations?query=alexanderplatz' replace alexanderplatz with your station name or part of it. then your response will look like this
                          {"type":"station","relevance":1.0161290322580645,"id":"900000100003","name":"S+U Alexanderplatz","tokens":["sbahn","ubahn","alexanderplatz","bahnhof","berlin"]}
                          {"type":"station","relevance":1.0119047619047619,"id":"900000100006","name":"S+U Alexanderplatz/Grunerstr.","tokens":["sbahn","ubahn","alexanderplatz","bahnhof","gruner","strasse","berlin"]}
                          {"type":"station","relevance":1.015625,"id":"900000100005","name":"U Alexanderplatz [Tram]","tokens":["ubahn","alexanderplatz","berlin","tram"]}
                          so if you want to use the station S+U Alexanderplatz/Grunerstr. you have to use the id 900000100006
                            pauabaer
                            @strawberry-3-141
                            thanks! worked fine. Now i have a new question. is it possible to hide a line on a station instead of the whole station?
                            • strawberry 3.141S
                              @pauabaer I’m not sure if that is possible as no config option looks like that it handles this case.
                              But if it is e.g. a bus line and you want just display trams and subways you can exclude bus with excludedTransportationTypes
                                pauabaer
                                It is indeed a busline, but the station has only buslines. But one of these lines is for me irrelevant, that’s why I asked for that option. But it’s ok. It is a really good module. Thank you for this one!!
                                • BehB
                                  Beh
                                  Hey, @strawberry-3-141, thanks for supporting!
                                  @pauabaer:
                                  currently there is no such function to filter out lines directly. Only to filter for stations, as @strawberry-3-141 mentioned. But I can implement that function if you want to have it. It’s not soo much effort I think… I can’t promise to do this fast, but I would try to find time for it ASAP.
                                  If you want that feature, please open an issue for that on github, so I won’t forget it ^^’
                                    pauabaer
                                    @Beh sounds great! thanks so far.
                                    for now i dont have a github acc, so i will wait a bit. i dont forget my issue. so if you forget it, i will remember this oder create a github acc ;)
                                    • BehB
                                      Beh
                                      To all users of this module:
                                      The transportation data in the background changed and I added support for this in the module. You should update the module asap.
                                      You can update it with these commands in the MMM-PublicTransportBerlin-folder:
                                      git pull
                                      npm install
                                      The npm install-command is very important, since the vbb-client module needs to be updated to use the new transport API.
                                      Greetings!
                                      • BehB
                                        Beh
                                        Hey, @pauabaer
                                        I implemented your feature request ;)
                                        you can now exclude lines via the ignoredStations option in your config.
                                          M1dn8
                                          Hey @Beh,
                                          thank u for ur big updates last days works great for me.
                                          My problem is…my station has only 1 Tramline and your module show me departures in both directions but I only need one direction cause the other way is the last station so I never will took this one :P
                                          Is there any possibilities to show only one direction?
                                          I think it’s not the same option like your “ignoredStations” and “ignoredLines” config, right?
                                          thank u and greetings
                                          M1dn8
                                          G BehB 2 Replies Last reply
                                          • rudibaraniR
                                            rudibarani Project Sponsor @olexs
                                            @olexs Hi olexs,
                                            I have not found another entry form you for the PublicTransportDB-module - so I am replying here. It is really great - thanks a lot!
                                            I am commuting on a daily basis to Berlin and would like to use it to see, if my train is delayed. So far, I am using MMM-MyCommute to show the next connection to Berlin - but Google still lacks realtime-data on train delays.
                                            Would it be possible to show only trains with defined destination (e.g. Berlin Hbf / Berlin Hbf (tief))? This would make it much easier to show only relevant departures. Alternatively, I have also tried the ignoredLines variable - but it is complex to exclude everything else and I did not have success to hide any of the irrelevant departures so far.
                                            Thanks a lot for your help!
                                            • 2 / 5
