    MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures)
    84 Posts 25 Posters 124.8k Views 25 Watching
      Photon2000
      Hi all,
      good news for Pi Zero users:
      The new image “Raspbian Jessie with PIXEL” comes bundled with the chromium browser. I’ve installed it tonight and chromium works on the Pi Zero (W). If I connect to a serveronly installation of MagicMirror the “ES6-problematic” modules (im my case: compliments, MMM-PublicTransportBerlin) comes up.
      It’s not that fluently; CPU is 100% but it work’s.
      • JayJ
        Jay @Beh
        @Beh
        I did a sudo apt-get dist-upgrade recently, so it has to be the latest version
        • JayJ
          Jay
          Does anybody have a working stationID in order to test the module itself, so others can verify if the module is working?
          D 1 Reply Last reply
            done @Jay
            @Jay
            There is an ID mentioned in the readme
            JayJ 1 Reply Last reply
            • JayJ
              Jay @done
              @done
              the station ID in the readme of Berlin-Alexanderplatz indicates a “There are currently no departures.” message.
              I think the readme is a bit deprecated, the modulename had to be reconfigered in the config as well.
              All I need to know is, where can I get a list with the stationIDs? As I posted above, my source could be wrong for this task.
              Any experience?
              BehB 1 Reply Last reply
                done
                @Jay
                Have you checked “How to get the stationId” in the readme?
                I have no installation right now. Otherwise you could have my ID.
                But as far as I remember it was pretty easy to get an id.
                If it’s missing station names:
                Zoologischer Garten
                Osloer Straße
                Ostkreuz
                Westkreuz
                Hope this helps.
                • BehB
                  Beh @Jay
                  Hey @Jay,
                  what did you have to change for the module name in the config?! o_O
                  I didn’t make any changes according this…
                  You can get valid station IDs via an easy cURL command as mentioned in the readme like this (you can do it from the mirror’s command line):
                  curl 'https://transport.rest/stations?query=alexanderplatz'
                  You just have to switch ‘alexanderplatz’ with your nearest station. This command will return all station fitting the search term.
                  • JayJ
                    Jay @Beh
                    @Beh
                    After the recent update from olexs (2-3 days ago), the module works like a charm.
                    • BehB
                      Beh
                      Okay, I think there’s a misunderstanding here.
                      To make things clear for the future:
                      The Module from @olexs MMM-PublicTransportDB is not really the same as my MMM-PublicTransportBerlin. Olexs made some changes on the original module to use the data from DB (Deutsche Bahn) while my module is just using the data from VBB (Verkehrsverbund Berlin-Brandenburg).
                      I think this could be the reason why the stationIds you used did not work @Jay. Since you used a stationId from VBB for DB data. I didn’t test this but maybe @olexs can make a statement to this?
                      O 1 Reply Last reply
                        Dicous
                          Dicous
                          Hallo Gemeinde,
                          ich probiere es mal in Deutsch.
                          Wenn ich das Module hinzufüge, sehe ich nur noch ein schwarzen Bildschirm. Kann mir jmd helfen?
                          Vielen Dank.
                          /* Magic Mirror Config Sample
                           * MIT Licensed.
                          var config = {
                          	port: 8080,
                          	language: 'de',
                          	timeFormat: 24,
                          	units: 'metric',
                          			module: 'alert',
                          			module: "updatenotification",
                          			position: "top_bar"
                          			module: 'clock',
                          			position: 'top_left'
                          			module: 'calendar',
                          			header: 'Berlin',
                          			position: 'top_left',
                          						symbol: 'calendar-check-o ',
                          						url: 'https://calendar.google.com/calendar/ical/XXXX.ics'
                          			module: 'calendar',
                          			header: 'Basti',
                          			module: 'compliments',
                          			position: 'lower_third'
                          			module: 'currentweather',
                          			position: 'top_right',
                          				locationID: '6545310',  //ID from http://www.openweathermap.org
                          				appid: 'xxx'
                          			module: 'weatherforecast',
                          			header: 'Weather Forecast',
                          				appid: 'xxx'
                          				locationID: '2937591',  //ID from http://www.openweathermap.org
                          				appid: '6f549a70275dff25b166f08f5ea012f7'
                          			module: 'newsfeed',
                          			position: 'bottom_bar',
                          				feeds: [
                          						title: "Spiegel Online",
                          						url: "http://www.spiegel.de/schlagzeilen/tops/index.rss"
                          						title: "Kicker",
                          						url: "http://rss.kicker.de/news/fussball"
                          				showSourceTitle: true,
                          				showPublishDate: true
                              module: 'MMM-PublicTransportBerlin',
                              position: 'bottom_right',
                                  stationId: 900000120003,
                                  hidden: false,
                                  ignoredStations: [9100003,2342,1337],
                                  excludedTransportationTypes: 'bus,suburban,subway',
                                  delay: 10,
                                  interval: 120000,
                                  departureMinutes: 10,
                                  maxDepartures: 15,
                                  marqueeLongDirections: true,
                                  showColoredLineSymbols: true,
                                  useColorForRealtimeInfo: true,
                                  showTableHeadersAsSymbols: true,
                                  maxUnreachableDepartures: 3,
                                  maxReachableDepartures: 7,
                                  fadeUnreachableDepartures: true,
                                  fadeReachableDepartures: true,
                                  fadePointForReachableDepartures: 0.25
                          yawnsY 1 Reply Last reply
                          • yawnsY
                            yawns Moderator @Dicous
                            @Dicous
                            Did you install (git clone) the module into the right folder ~/MagicMirror/modules/ ? Did you also run npm install in the new subfolder ~/MagicMirror/modules/MMM-PublicTransportBerlin ?
                              Dicous
                              yes. i did:
                              pi@raspberrypi:~/MagicMirror/modules/default $ git clone https://github.com/deg0nz/MMM-PublicTransportBerlin.git
                              Klone nach 'MMM-PublicTransportBerlin'...
                              remote: Counting objects: 184, done.
                              remote: Total 184 (delta 0), reused 0 (delta 0), pack-reused 184
                              Empfange Objekte: 100% (184/184), 109.67 KiB | 0 bytes/s, Fertig.
                              Löse Unterschiede auf: 100% (110/110), Fertig.
                              Prüfe Konnektivität... Fertig.
                              pi@raspberrypi:~/MagicMirror/modules/default $ cd MMM-PublicTransportBerlin
                              pi@raspberrypi:~/MagicMirror/modules/default/MMM-PublicTransportBerlin $ npm install
                              MMM-PublicTransportBerlin@0.2.0 /home/pi/MagicMirror/modules/default/MMM-PublicTransportBerlin
                              └─┬ vbb-client@1.0.0
                                ├─┬ isomorphic-fetch@2.2.1
                                │ ├─┬ node-fetch@1.6.3
                                │ │ ├─┬ encoding@0.1.12
                                │ │ │ └── iconv-lite@0.4.15
                                │ │ └── is-stream@1.1.0
                                │ └── whatwg-fetch@2.0.3
                                └─┬ ndjson@1.5.0
                                  ├── json-stringify-safe@5.0.1
                                  ├── minimist@1.2.0
                                  ├── split2@2.1.1
                                  └─┬ through2@2.0.3
                                    ├─┬ readable-stream@2.2.6
                                    │ ├── buffer-shims@1.0.0
                                    │ ├── core-util-is@1.0.2
                                    │ ├── inherits@2.0.3
                                    │ ├── isarray@1.0.0
                                    │ ├── process-nextick-args@1.0.7
                                    │ ├── string_decoder@0.10.31
                                    │ └── util-deprecate@1.0.2
                                    └── xtend@4.0.1
                              • yawnsY
                                yawns Moderator
                                No, you did not. You are in ~/MagicMirror/modules/default and not ~/MagicMirror/modules. Modules in default won’t be executed, the default area is “protected”.
                                  Dicous
                                  Thank You.
                                  I am still a Noob
                                  You made my day
                                  • O
                                    olexs @Beh
                                    @Beh This is correct. Station IDs are different between DB and BVG networks (and others, such as my local RMV), and I haven’t yet added a proper error message for “wrong” IDs, instead it fails silently. Getting DB IDs is a bit of a pain, too, I’m working on a small public interface for that. I’ll open a separate thread for the fork.
                                    While I’m here: thanks a lot for your work! Without your code, my module would never exist. I’ve put an attribution in the readme, if you want it higher up just say a word :)
                                    BehB rudibaraniR 2 Replies Last reply
                                    • BehB
                                      Beh @olexs
                                      @olexs
                                      You’re very welcome :smile:
                                      I’m happy that someone had use for it, so the code is not useless :) I already noticed the attribution in the readme and appreciated it ;) Thanks a lot
                                        pauabaer
                                        hey guys,
                                        i am still a noob. please be patient with me :)
                                        i dont know how to get the station id. obviously i dont understand the api-documentation. can you please help me with this?
                                        i have already installed the mmm-publictransportberlin module and the vbb-rest from github. but now i dont get on.
                                        greets
                                        pauabaer
                                        • strawberry 3.141S
                                          strawberry 3.141 Project Sponsor Module Developer @pauabaer
                                          @pauabaer you have to open a terminal and execute the command curl 'https://transport.rest/stations?query=alexanderplatz' replace alexanderplatz with your station name or part of it. then your response will look like this
                                          {"type":"station","relevance":1.0161290322580645,"id":"900000100003","name":"S+U Alexanderplatz","tokens":["sbahn","ubahn","alexanderplatz","bahnhof","berlin"]}
                                          {"type":"station","relevance":1.0119047619047619,"id":"900000100006","name":"S+U Alexanderplatz/Grunerstr.","tokens":["sbahn","ubahn","alexanderplatz","bahnhof","gruner","strasse","berlin"]}
                                          {"type":"station","relevance":1.015625,"id":"900000100005","name":"U Alexanderplatz [Tram]","tokens":["ubahn","alexanderplatz","berlin","tram"]}
                                          so if you want to use the station S+U Alexanderplatz/Grunerstr. you have to use the id 900000100006
                                            pauabaer
                                            @strawberry-3-141
                                            thanks! worked fine. Now i have a new question. is it possible to hide a line on a station instead of the whole station?
                                            • 2 / 5
