    MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures)
    84 Posts 25 Posters 120.0k Views 25 Watching
      Beh @Photon2000
      @Photon2000 Yeah, the problem is, that midori doesn’t support ECMAScript 6 (ES6) features. But the module is using some of them.
      Unfortunately I don’t have much time in the near future to convert the module to vanilla JavaScript in ES5 for you. You could try to convert the code with a compiler like Babel. Then it should work with midori.
        Photon2000
        @Beh Thanks for pointing me in the right direction! So I have two choices: finding a browser for th pi zero that supports ES6 or switch to PI2/3. Fair enough. I guess that other modules use ES6 too.
          Photon2000
          Hi all,
          good news for Pi Zero users:
          The new image “Raspbian Jessie with PIXEL” comes bundled with the chromium browser. I’ve installed it tonight and chromium works on the Pi Zero (W). If I connect to a serveronly installation of MagicMirror the “ES6-problematic” modules (im my case: compliments, MMM-PublicTransportBerlin) comes up.
          It’s not that fluently; CPU is 100% but it work’s.
            Jay @Beh
            @Beh
            I did a sudo apt-get dist-upgrade recently, so it has to be the latest version
              Jay
              Does anybody have a working stationID in order to test the module itself, so others can verify if the module is working?
                done @Jay
                @Jay
                There is an ID mentioned in the readme
                  Jay @done
                  @done
                  the station ID in the readme of Berlin-Alexanderplatz indicates a “There are currently no departures.” message.
                  I think the readme is a bit deprecated, the modulename had to be reconfigered in the config as well.
                  All I need to know is, where can I get a list with the stationIDs? As I posted above, my source could be wrong for this task.
                  Any experience?
                    done
                    @Jay
                    Have you checked “How to get the stationId” in the readme?
                    I have no installation right now. Otherwise you could have my ID.
                    But as far as I remember it was pretty easy to get an id.
                    If it’s missing station names:
                    Zoologischer Garten
                    Osloer Straße
                    Ostkreuz
                    Westkreuz
                    Hope this helps.
                      Beh @Jay
                      Hey @Jay,
                      what did you have to change for the module name in the config?! o_O
                      I didn’t make any changes according this…
                      You can get valid station IDs via an easy cURL command as mentioned in the readme like this (you can do it from the mirror’s command line):
                      curl 'https://transport.rest/stations?query=alexanderplatz'
                      You just have to switch ‘alexanderplatz’ with your nearest station. This command will return all station fitting the search term.
                        Jay @Beh
                        @Beh
                        After the recent update from olexs (2-3 days ago), the module works like a charm.
                          Beh
                          Okay, I think there’s a misunderstanding here.
                          To make things clear for the future:
                          The Module from @olexs MMM-PublicTransportDB is not really the same as my MMM-PublicTransportBerlin. Olexs made some changes on the original module to use the data from DB (Deutsche Bahn) while my module is just using the data from VBB (Verkehrsverbund Berlin-Brandenburg).
                          I think this could be the reason why the stationIds you used did not work @Jay. Since you used a stationId from VBB for DB data. I didn’t test this but maybe @olexs can make a statement to this?
                            Dicous
                              Dicous
                              Hallo Gemeinde,
                              ich probiere es mal in Deutsch.
                              Wenn ich das Module hinzufüge, sehe ich nur noch ein schwarzen Bildschirm. Kann mir jmd helfen?
                              Vielen Dank.
                              /* Magic Mirror Config Sample
                               * MIT Licensed.
                              var config = {
                              	port: 8080,
                              	language: 'de',
                              	timeFormat: 24,
                              	units: 'metric',
                              			module: 'alert',
                              			module: "updatenotification",
                              			position: "top_bar"
                              			module: 'clock',
                              			position: 'top_left'
                              			module: 'calendar',
                              			header: 'Berlin',
                              			position: 'top_left',
                              						symbol: 'calendar-check-o ',
                              						url: 'https://calendar.google.com/calendar/ical/XXXX.ics'
                              			module: 'calendar',
                              			header: 'Basti',
                              			module: 'compliments',
                              			position: 'lower_third'
                              			module: 'currentweather',
                              			position: 'top_right',
                              				locationID: '6545310',  //ID from http://www.openweathermap.org
                              				appid: 'xxx'
                              			module: 'weatherforecast',
                              			header: 'Weather Forecast',
                              				appid: 'xxx'
                              				locationID: '2937591',  //ID from http://www.openweathermap.org
                              				appid: '6f549a70275dff25b166f08f5ea012f7'
                              			module: 'newsfeed',
                              			position: 'bottom_bar',
                              				feeds: [
                              						title: "Spiegel Online",
                              						url: "http://www.spiegel.de/schlagzeilen/tops/index.rss"
                              						title: "Kicker",
                              						url: "http://rss.kicker.de/news/fussball"
                              				showSourceTitle: true,
                              				showPublishDate: true
                                  module: 'MMM-PublicTransportBerlin',
                                  position: 'bottom_right',
                                      stationId: 900000120003,
                                      hidden: false,
                                      ignoredStations: [9100003,2342,1337],
                                      excludedTransportationTypes: 'bus,suburban,subway',
                                      delay: 10,
                                      interval: 120000,
                                      departureMinutes: 10,
                                      maxDepartures: 15,
                                      marqueeLongDirections: true,
                                      showColoredLineSymbols: true,
                                      useColorForRealtimeInfo: true,
                                      showTableHeadersAsSymbols: true,
                                      maxUnreachableDepartures: 3,
                                      maxReachableDepartures: 7,
                                      fadeUnreachableDepartures: true,
                                      fadeReachableDepartures: true,
                                      fadePointForReachableDepartures: 0.25
                              • Y Offline
                                yawns Moderator @Dicous
                                @Dicous
                                Did you install (git clone) the module into the right folder ~/MagicMirror/modules/ ? Did you also run npm install in the new subfolder ~/MagicMirror/modules/MMM-PublicTransportBerlin ?
                                  Dicous
                                  yes. i did:
                                  pi@raspberrypi:~/MagicMirror/modules/default $ git clone https://github.com/deg0nz/MMM-PublicTransportBerlin.git
                                  Klone nach 'MMM-PublicTransportBerlin'...
                                  remote: Counting objects: 184, done.
                                  remote: Total 184 (delta 0), reused 0 (delta 0), pack-reused 184
                                  Empfange Objekte: 100% (184/184), 109.67 KiB | 0 bytes/s, Fertig.
                                  Löse Unterschiede auf: 100% (110/110), Fertig.
                                  Prüfe Konnektivität... Fertig.
                                  pi@raspberrypi:~/MagicMirror/modules/default $ cd MMM-PublicTransportBerlin
                                  pi@raspberrypi:~/MagicMirror/modules/default/MMM-PublicTransportBerlin $ npm install
                                  MMM-PublicTransportBerlin@0.2.0 /home/pi/MagicMirror/modules/default/MMM-PublicTransportBerlin
                                  └─┬ vbb-client@1.0.0
                                    ├─┬ isomorphic-fetch@2.2.1
                                    │ ├─┬ node-fetch@1.6.3
                                    │ │ ├─┬ encoding@0.1.12
                                    │ │ │ └── iconv-lite@0.4.15
                                    │ │ └── is-stream@1.1.0
                                    │ └── whatwg-fetch@2.0.3
                                    └─┬ ndjson@1.5.0
                                      ├── json-stringify-safe@5.0.1
                                      ├── minimist@1.2.0
                                      ├── split2@2.1.1
                                      └─┬ through2@2.0.3
                                        ├─┬ readable-stream@2.2.6
                                        │ ├── buffer-shims@1.0.0
                                        │ ├── core-util-is@1.0.2
                                        │ ├── inherits@2.0.3
                                        │ ├── isarray@1.0.0
                                        │ ├── process-nextick-args@1.0.7
                                        │ ├── string_decoder@0.10.31
                                        │ └── util-deprecate@1.0.2
                                        └── xtend@4.0.1
                                  • Y Offline
                                    yawns Moderator
                                    No, you did not. You are in ~/MagicMirror/modules/default and not ~/MagicMirror/modules. Modules in default won’t be executed, the default area is “protected”.
                                      Dicous
                                      Thank You.
                                      I am still a Noob
                                      You made my day
                                      • O Offline
                                        olexs @Beh
                                        @Beh This is correct. Station IDs are different between DB and BVG networks (and others, such as my local RMV), and I haven’t yet added a proper error message for “wrong” IDs, instead it fails silently. Getting DB IDs is a bit of a pain, too, I’m working on a small public interface for that. I’ll open a separate thread for the fork.
                                        While I’m here: thanks a lot for your work! Without your code, my module would never exist. I’ve put an attribution in the readme, if you want it higher up just say a word :)
                                        B rudibaraniR 2 Replies Last reply Reply Quote 0
                                          Beh @olexs
                                          @olexs
                                          You’re very welcome :smile:
                                          I’m happy that someone had use for it, so the code is not useless :) I already noticed the attribution in the readme and appreciated it ;) Thanks a lot
                                            pauabaer
                                            hey guys,
                                            i am still a noob. please be patient with me :)
                                            i dont know how to get the station id. obviously i dont understand the api-documentation. can you please help me with this?
                                            i have already installed the mmm-publictransportberlin module and the vbb-rest from github. but now i dont get on.
                                            greets
                                            pauabaer
                                            • 2 / 5
