    Using the Raspberry Pi Camera to see through the mirror
    24 Posts 7 Posters 27.5k Views 7 Watching
      Synthic @johnnyboy
      @johnnyboy The thing is that my design is a frameless mirror - hence why I wanted the camera to be able to see through the mirror. But a webcamera that incorporates the microphone was a really good idea as I also intend to some voice command recognition.
      I only want the camera for doing facial recognition, so as long as the noir camera is able to get high enough quality for facial features to be distinguished - that will be good enough for me.
      Thanks!
        Synthic @dpenney
        @dpenney Whether the PiCamera is directly behind the mirror, or looking through the mirror through the drilled hole does not matter. The images taken are equally bad
          Synthic @johnnyboy
          @johnnyboy Do you have any familiarity with webcams with built-in microphone that are small and compact? As to not make the mirror thicker than needs be.
          johnnyboyJ 1 Reply Last reply Reply Quote 0
          • slametpsS Offline
            slametps
            I’m using the exact rpi camera, and it’s working flawlessly with facial-recognition module. also taking a picture or record video. Have you test the camera before attached to its place?
            regards,
            Slamet PS
            • johnnyboyJ Offline
              johnnyboy @Synthic
              @Synthic
              There are quite a lot of webcams out there with built in microphones… So best Google or have a look at styles/shapes/sizes on Amazon or Fleabay to get an idea of what suits. Im sure they are all more-or-less same megapixels? apart for the higher end ones that also record in HD, and has twin microphones… also ones with Facial recognition like the M$ Hello Face recognition which I think is windows 10 only??? so all depends on your budget, and what you want from it, also the size and casing incase you can/want to strip it down for a better fit?
              • lolobyteL Offline
                lolobyte
                Hi @Synthic,
                i use since 2 weeks the mirror glass ordered at @Goldjunge_Chriz ad the result is fantastic. With my mirror before the video was very darken. i send you asap a picture of my videoframe.
                  Synthic @slametps
                  @slametps Yeah, I know the camera works well normally. So your camera works by seeing through the mirror from the other side? Did you have to tweak any camera settings or did it just work?
                  lolobyteL 1 Reply Last reply Reply Quote 0
                  • lolobyteL Offline
                    lolobyte @Synthic
                    @Synthic yes behind the mirror glass without any tweaks.
                    • brobergB Offline
                      broberg Project Sponsor
                      Do consider that there is difference in properties between the types of two way mirrors out there,
                      one type could work well with a camera lens while another type doesn’t work at all.
                      for an example many two way coatings are made to filter out IR light.
                        Synthic @broberg
                        @broberg That is a valid point. How would one know what kind of two-way mirror I posess? Haven’t been able to find any “comprehensive overview” of two-way mirrors
