    Chromium RPI-1 display strange
    8 Posts 5 Posters 5.9k Views 4 Watching
      benjee
      I would rather know how to uninstall Chromium and install a compliant brower following same how-to than modify code (that would be updated…)
        chenz0 @benjee
        @benjee I have the same problem. I’m running MM2 on RPi 1 (Version B with Debian) through Chromium. I’ve been trying to fix the layout in ~/MagicMirror/css/main.css. By changing position of the body to relative and leaving the positions of regions as absolute, I was able to get to this point. I still can’t figure out how to get the compliments (or newsfeed) to the bottom. I also can’t get the calendar to sync. Let me know if you find a fix beyond this.
          chenz0 @chenz0
          I used @PtdBld 's recommendation and it worked. Now I just need to figure out why the calendar and newsfeed aren’t working. 0_1464708767868_Screen Shot 2016-05-31 at 11.32.14 AM.png
            Silversonic @chenz0
            @chenz0 I am having the same issue with the compliments and newsfeed not going to the bottom, I am also running this on a B+. Could you explain in a little more detail what you changed? Changing calc(100%-120px) to 100% just makes everything go off the right of the screen (and those are the only uses of the calc function I could find in main.css). I am very new to CSS.
              Silversonic
