    MMM-Wunderground
    12 Posts 2 Posters 8.1k Views 2 Watching
      Chrispl2000
      Hello All,
      I am trying to get the Wunderground module to load on my mirror. When I start the mirror program from the command line it simply does not show up. I have cloned the data in the gitHub link and have added it to my config but it still does not show up.
      My Config:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	zoom: 1,
      	port: 8080,
      	language: 'en',
      	timeFormat: 12,
      	units: 'imperial',
      			module: 'clock',
      			position: 'top_bar',
      					displaySeconds: false,
      					showDate: false
      			module: 'MMM-WunderGround',
      			position: 'top_third',
      					apikey: '--------------------',
      					pws: 'pws:KTXIRVIN10',
      					hourly: '1'
      When I start the Program in the terminal, it outputs this:
      pi@SmartScreen1:~/MagicMirror $ npm start
      magicmirror@2.1.0 start /home/pi/MagicMirror
      electron js/electron.js
      Starting MagicMirror: v2.1.0
      Loading config …
      Loading module helpers …
      All module helpers loaded.
      Starting server op port 8080 …
      Server started …
      Connecting socket for: MMM-WunderGround
      MMM-WunderGround helper started …
      Sockets connected & modules started …
      Launching application.
      GET_WUNDERGROUND
      Thank you in advance for any help.
        Mykle1 Project Sponsor Module Developer @Chrispl2000
        @Chrispl2000
        You’re missing a comma on the second to last }. It should look like this }, Look how I changed it below
        					hourly: '1'
          Chrispl2000
          The extra comma didn’t change anything. I thought you only used a comma when there is another item behind it?
            @Chrispl2000
            That is true, but you are closing out the config at this point. Here is the end of my config. Notice the comma.
            						title: "New York Times",
                                				title: "BBC World News",
                                				url: "http://feeds.bbci.co.uk/news/world/us_and_canada/rss.xml"
            				showSourceTitle: true,
            				showPublishDate: true
              Mykle1 Project Sponsor Module Developer @Mykle1
              If everything else is working then the error lies in the config entry for WonderGround.
                Here is my entry for WunderGround.
                			disabled: f,
                    			position: 'top_right',
                        		apikey: 'YOUR API KEY', // private
                        		pws: 'pws:KNYNEWYO103',
                			currentweather: 0,
                        		coloricon: true,
                        		hourly: '1',
                        		fctext: '1',
                        		fcdaycount: "10",
                        		fcdaystart: "0",
                        		hourlyinterval: "2",
                        		hourlycount: "1",
                			animationSpeed: 5000,
                        		alerttime: 10000,
                        		alerttruncatestring: "english:",
                    			roundTmpDecs: 0,
                    			UseCardinals: 1,
                    			layout: "vertical",
                			windunits: "mph",
                    			sysstat: "0"
                  Wait! top_third is not valid. Try top_right
                    Hover your mouse over my avatar to the left of my name and click chat
                      Chrispl2000
                      Great catch!!! I’m new to pretty much everything involved in programming this thing.
                        @Chrispl2000
                        No worries. If you have TeamSpeak I can help you more easily if you’d like
                          @Chrispl2000
                          This will definitely help you.
                          https://forum.magicmirror.builders/topic/286/regions
                            @Chrispl2000 said in MMM-Wunderground:
                            You are absolutely right. That comma is NOT necessary in this case. However, it works with or without. I just removed mine and it still works :thumbsup_tone1:
