    [SOLVED] Help on Install
    9 Posts 2 Posters 3.8k Views 2 Watching
    • hartattackH Offline
      hartattack
      I seem to have installed everything, but when i run cd MagicMirror/config I get -bash: cd: MagicMirror/config: No such file or directory
      Ideas?
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @hartattack
        @hartattack did you try cd ~/MagicMirror/config?
        hartattackH 1 Reply Last reply Reply Quote 0
          hartattack @strawberry 3.141
          @strawberry-3.141 said in Help on Install:
          Yes, same result…
            hartattack
            Should I try and re-install Magic Mirror?
              @hartattack when you open the terminal in which directory are you and in which did you install the MagicMirror? can you execute ls
                I am stuck in the pi@retropie command line, can’t seem to switch
                  hartattack
                  tried the su pi command, i enter my password, but it takes me back to pi@retropie
                    @hartattack you’re already logged in as pi user@host
                      Hey! I was able to figure this out pretty late last night. When I updated/installed the latest node version, it must not have taken. I re-updated it and now it is working like a charm! Thank you for the help~
