    Update says to "commit your changes or stash them before you can merge." ?
    26 Posts 8 Posters 44.3k Views 8 Watching
    • yawnsY Offline
      yawns Moderator @Richard238
      @Richard238
      No, there is no need at all to change these files.
      next to main.css you find custom.css, there you can add any css styles which will override existing styles.
      To add compliments, calendars, newsfeeds and forecast you set your values in config/config.js.
      This way you don’t lose your changes :)
        Richard238 @yawns
        @yawns Ok, thanks. I’ve some work to do there then!
          Richard238
          Lost and confused already.
          How much of calendar.js needs to be copied to config,js?
          johnnyboyJ 1 Reply Last reply Reply Quote 0
          • johnnyboyJ Offline
            johnnyboy @Richard238
            @Richard238 said in Update says to “commit your changes or stash them before you can merge.” ?:
            About this much…
            			module: 'calendar',
            			header: 'My Family Home Calendar',
            			position: 'top_right',
                                             maximumEntries: 13,
                                             maximumNumberOfDays: 365,
                                             maxTitleLength: 25,
                                             animationSpeed: 0,
                                             fadePoint: 3,
                                             timeFormat: 'absolute',
                                             urgency: 7,
                                             getRelative: 0,
            						symbol: 'calendar-check-o ',
            						url: 'webcal://www.calendarlabs.com/templates/ical/UK-Holidays.ics'
                                                            symbol: `calendar-check-o `,
                                                            url: "https://calendar.google.com/calendar/ical/mydetails.co.uk/private-mydetails/basic.ics"
            			module: 'compliments',
              Richard238 @johnnyboy
              Ok, these are done and no longer an issue, hurrah!:grinning:
                  css/main.css
                  modules/default/compliments/compliments.js
                  modules/default/newsfeed/newsfeed.js
                  modules/default/weatherforecast/weatherforecast.js
              Can’t get
                  modules/default/calendar/calendar.js
              into config.js though.
              			module: 'calendar',
              			header: 'Calendar',
              			position: 'top_left',
                                  maximumEntries: 8, // Total Maximum Entries
                                  displaySymbol: true,
                                  defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
                                  displayRepeatingCountTitle: false,
                                  defaultRepeatingCountTitle: "",
                                  maxTitleLength: 25,
                                  fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                                  animationSpeed: 2000,
                                  fade: true,
                                  urgency: 0,
                                  timeFormat: "absolute",
                                  dateFormat: "ddd Do MMMM",
                                  getRelative: 2,
                                  fadePoint: 0.25, // Start on 1/4th of the list.
                                  hidePrivate: false,
              						url: 'https://calendar.google.com/calendar/ical/PRIVATE_KEY/basic.ics'
              			module: 'calendar',
              			header: 'Binday',
              			position: 'bottom_left',
                                  maxTitleLength: 25,
                                  fade: true,
                                  urgency: 0,
                                  getRelative: 2,
                                  hidePrivate: false,
              						symbol: 'pagelines ',
                              titleReplace: {
                              //	"'s birthday": "",
                              //	"Recycling": "Bins",
                                  "Red Bin": "Red and Black Bins",
                                  "Green Bin": "Green and Black Bins"
              What have I missed?!
              Thanks.
              • yawnsY Offline
                yawns Moderator
                At least there is a single comma missing after the closing ] of your calendars entry
                  Richard238
                  @yawns Brilliant! A comma after each of the ] seems to have fixed it.
                  Thank you.
                    Richard238
                    		module: 'calendar',
                    		header: 'Calendar',
                    		module: 'calendar',
                    		header: 'Binday',
                    With two calendars, how do I get different icons / icon colours again in custom.css?
                     .calendar .fa.fa-calendar-check-o {
                      color: #00d2FF /* 55=Green FF=Blue*/
                     .calendar .fa.fa-trash-o  {
                      color: #C97F7F; /* Brown */
                    • strawberry 3.141S Offline
                      strawberry 3.141 Project Sponsor Module Developer @Richard238
                      @Richard238 you can use the module identifier for it as it is unique
                      #module_7_calendar .fa.fa-calendar-check-o {
                      #module_8_calendar .fa.fa-calendar-check-o {
                      the number is the index of the entry in your config starting at 0
                      e.g.
                        {module: "A", position: "top_right"}, //index: 0
                        {module: "B", position: "top_right"}, //index: 1
                        {module: "calendar", position: "top_right"}, //index: 2
                        Richard238
                        Ok, like this?
                        			module: 'alert',   # Module 0
                                   module: "MMM-MyTemps",  # Module 1
                                    header: "Home Sensors",
                                    position: "bottom_right",
                                        host: "192.168.1.41",
                                        path: "/temp2mcf.php?format=json",
                                        reloadInterval: 2 * 1000   //2 seconds
                        			module: "updatenotification",  # Module 2
                        			position: "top_bar"
                        			module: 'clock',   # Module 3
                        			module: 'calendar',  # Module 4
                        . … …And second calendar = # Module 5
                        making the custom.css look like this:
                         #module_4_calendar .fa.fa-calendar-check-o {
                          #module_5_calendar  .fa.fa-trash-o  {
