    MMM-AlexaPi
    48 Posts 8 Posters 44.5k Views 9 Watching
    • mymmbeginnerM
      mymmbeginner
      Hello everybody,
      first off all i want to give all of you a BIG THANKS for helping me out ;-) :-)
      I had some trouble’s installing and setting up Alexa with MM.
      After reading the forums and the people having the same issue, this entry helped me a lot and i have Alexa integrated in MM and working now.
      Wow wat is everybody so motivated and helpfull. Keep up the good work everybody and looking forward making MM the best.
      Greets a happy MM beginner.
      D johnnyboyJ 2 Replies Last reply
        Davepre @mymmbeginner
        @mymmbeginner I am happy this post helped. As a newbie here I am really impressed with the support from this community as well. Glad to be a part of it!
        • johnnyboyJ
          johnnyboy @mymmbeginner
          • johnnyboyJ
            johnnyboy @Davepre
            D lucallmonL 3 Replies Last reply
              Davepre @johnnyboy
              @johnnyboy Sorry, I am currently traveling with work and dont have access to my setup, but I am back end of this week and have a look. I will report back Friday night :)
              johnnyboyJ 1 Reply Last reply
              • lucallmonL
                lucallmon @johnnyboy
                @johnnyboy if you need to rename a file mv config.template.yaml config.yaml. If that doesn’t work, put sudo in front of it.
                • johnnyboyJ
                  johnnyboy @lucallmon
                  • johnnyboyJ
                    johnnyboy @Davepre
                    • strawberry 3.141S
                      strawberry 3.141 Project Sponsor Module Developer @johnnyboy
                      @johnnyboy the # is like // in javascript so it will comment out that line
                      • johnnyboyJ
                        johnnyboy @strawberry 3.141
                        • strawberry 3.141S
                          @johnnyboy i have no idea how this file looks, but if it is like
                          token = ...
                          #token = ...
                          you should remove it
                            Davepre @johnnyboy
                            @johnnyboy so sorry for late reply. Only now got the chance to look for the config.yaml file.
                            Yes, my config.template.yaml is (same as yours) in opt/Alexapi/src.
                            However my config.yaml file is in etc/opt/Alexapi.
                            Thats the only file in that folder.
                            Is that what you were looking for?
                            Best regards / David
                            lucallmonL 1 Reply Last reply
                            • lucallmonL
                              lucallmon @Davepre
                              @Davepre don’t worry about the template one. Just edit the one in ‘’‘/etc/opt/AlexaPi/config.yaml’‘’
                              • johnnyboyJ
                                johnnyboy
                                • lucallmonL
                                  @johnnyboy i think you may be trying too hard. I followed the instructions to a T and haven’t had any problems. I had to reset my Pi twice after installing other modules that use sound… such as MMM-Voice. This module ruined my AlexaPi. I started my Pi over after installing that one because it ruined my sound profile. You may just need to figure out what you want to do with the mirror and install only those things. That’s what I did. After resetting my Pi 3 times and starting over each time, I’ve got it exactly the way I want it. when I move coming up in the next month, I’m going to make a touch screen family board for the kitchen kind of like this out of a Smart Screen. Then I’m going to buy an Alexa-powered remote control for my home entertainment center from Logitech that let’s you say, “Alexa, turn on the TV.” It should be fun.
                                  • johnnyboyJ
                                    • lucallmonL
                                      @johnnyboy no way brother. Don’t give up! If you want to have AlexaPi and MagicMirror on the same device I recommend starting over with a fresh copy of Raspbian, installing AlexaPi first and getting it to work. Then installing magic mirror with the AlexaPi module.
                                      • johnnyboyJ
                                        • lucallmonL
                                          @johnnyboy get another microSD card and give it a whirl from scratch.
                                          • johnnyboyJ
                                            • 2 / 3
