    MMM-AlexaPi
    48 Posts 8 Posters 44.5k Views 9 Watching
    • johnnyboyJ
      johnnyboy @cyberphox
      • johnnyboyJ
        johnnyboy @Davepre
        • lucallmonL
          lucallmon @Davepre
          @Davepre If you lost the “hello” at the beginning, you might be able to change back to ‘vlc’ as playback_handler and see if that works. I’ve had the best results with ‘sox’, however, I’m currently running on v1.4 with vlc as my handler and it’s working great. I get my flash briefing, I get music access from TuneIn and iHeartRadio. It’s almost as good as my Dot that I have in the kitchen.
          • lucallmonL
            lucallmon @Davepre
            @Davepre said in MMM-AlexaPi:
            Good morning guys,
            a quick question for everyone who managed to get this to work. How is the performance when leaving the mirror on for a couple of hours?
            I havent had the time to properly test it yet, but yesterday night I was under the impression that the MMM-AlexaPi module is quite a heavy hitter performance wise. I use a raspberry pi 3 and don’t feel like I overloaded it (only default modules + mmm-alexapi, motion detection and mmm-uklivebusinfo as 3rd party ones). But the newsticker got stuck after ten minutes and I was unable to close or alt+tab out of magic mirror. Again, I havent tested it properly yet since I didnt have the time, just wondering whether you experienced similar slow-downs.
            Best regards / Dave
            Every once in a while the mirror sticks but not often. I’ve been running AlexaPi from the start. Usually I just CTRL+Q to restart the mirror or I reboot. I have a reboot button on the side of my mirror. see my setup here. I also have a monitor off button. I have an old LCD monitor that get very hot and overheats, turning off the HDMI, so I keep it off most of the time, however Alexa still runs in the background. I also have a temperature sensor on my MM and I have a 5V fan attached to my Pi to keep it cool. It stays belwo 45degC.
            D 1 Reply Last reply
              Davepre @lucallmon
              @lucallmon Thanks for the feedback. I hope to get the chance to test a bit more during the weekend and report back if the performce issues become really bad :)
              Best regards / Dave
                cyberphox
                changing to sox helped me get the hello at start…and improved playback for me…it’s a little slow but a cool feature…
                • mymmbeginnerM
                  mymmbeginner
                  Hello everybody,
                  first off all i want to give all of you a BIG THANKS for helping me out ;-) :-)
                  I had some trouble’s installing and setting up Alexa with MM.
                  After reading the forums and the people having the same issue, this entry helped me a lot and i have Alexa integrated in MM and working now.
                  Wow wat is everybody so motivated and helpfull. Keep up the good work everybody and looking forward making MM the best.
                  Greets a happy MM beginner.
                  D johnnyboyJ 2 Replies Last reply
                    Davepre @mymmbeginner
                    @mymmbeginner I am happy this post helped. As a newbie here I am really impressed with the support from this community as well. Glad to be a part of it!
                    • johnnyboyJ
                      johnnyboy @mymmbeginner
                      • johnnyboyJ
                        johnnyboy @Davepre
                        D lucallmonL 3 Replies Last reply
                          Davepre @johnnyboy
                          @johnnyboy Sorry, I am currently traveling with work and dont have access to my setup, but I am back end of this week and have a look. I will report back Friday night :)
                          johnnyboyJ 1 Reply Last reply
                          • lucallmonL
                            lucallmon @johnnyboy
                            @johnnyboy if you need to rename a file mv config.template.yaml config.yaml. If that doesn’t work, put sudo in front of it.
                            • johnnyboyJ
                              johnnyboy @lucallmon
                              • johnnyboyJ
                                johnnyboy @Davepre
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @johnnyboy
                                  @johnnyboy the # is like // in javascript so it will comment out that line
                                  • johnnyboyJ
                                    johnnyboy @strawberry 3.141
                                    • strawberry 3.141S
                                      @johnnyboy i have no idea how this file looks, but if it is like
                                      token = ...
                                      #token = ...
                                      you should remove it
                                        Davepre @johnnyboy
                                        @johnnyboy so sorry for late reply. Only now got the chance to look for the config.yaml file.
                                        Yes, my config.template.yaml is (same as yours) in opt/Alexapi/src.
                                        However my config.yaml file is in etc/opt/Alexapi.
                                        Thats the only file in that folder.
                                        Is that what you were looking for?
                                        Best regards / David
                                        lucallmonL 1 Reply Last reply
                                        • lucallmonL
                                          lucallmon @Davepre
                                          @Davepre don’t worry about the template one. Just edit the one in ‘’‘/etc/opt/AlexaPi/config.yaml’‘’
                                          • johnnyboyJ
                                            johnnyboy
                                            • 2 / 3
