    Weatherunderground - currently - hourly - daily - configurable
    126 Posts 26 Posters 245.9k Views 13 Watching
      Crispis
      Honestly not too sure what I did… I mean I just re-cloned things in the module folder and now things are working. …So I guess if someone is having problems, simply start over from the beginning and try again?? No…idea… Anyways thanks for your help!
      • L
        lsfourwheeler
        So I just updated both my Raspberry pi, MagicMirror software, and MMM-Wunderground. The module still works but the moon phases icon is now a blank “image missing” box. Strangely, I can see the moon image just fine on a computer by going to the MagicmirroIP:8080 and viewing the magicmirror sofware from there. Any suggestions?
        • E
          eppzenberg @lsfourwheeler
          @lsfourwheeler
          I’m facing the same problem. Module is working and up-to-date, but moon phase icon is just showing the “image missing” box. Did you find any solution?
          • L
            lsfourwheeler @eppzenberg
            @eppzenberg
            Yes, I found out this issue actually happened because of the MagicMirror Update. Make sure that after you run the “git pull” command you also run the “npm install” command. This fixed my issue. I hope that helps.
            • E
              @lsfourwheeler
              Indeed, I missed that step. It works now. :) Thank you very much!
              • O
                ostfilinchen
                @RedNax : you have update the Module and it doesn’t look like the old style. The humidity is permanent shown and between Icon Wind Direction and Humidity is no space. Also between humidity and sunset/sunrise is no space.
                Can u please change this?
                • O
                  ostfilinchen
                  @RedNax: it’s still not fine:0_1485700269786_upload-26f37467-942f-462d-af4a-c3a3e1bca669
                  Font is not the same as the other modules and there is not a space between winddirection and humidity-icon
                  And another issue is the size of the current weather Icon. It’s too big:
                  0_1485700407613_upload-4cec9558-640a-4d7b-9621-35093b3c4d22
                  Can u have a look of this?
                  • O
                    ostfilinchen
                    Hi all,
                    has anyone ideas to Change the iconsize of the current weather? It’s to big and to bold for me.
                    Thx, Daniel
                      bocapie
                      I am having a error. It just says loading. I did a npm start dev. I get a error that says: Failed to decode downloaded font: http://localhost:8080/vendor/weather-icons/font/weathericons-regular-webfont.woff2
                        christophehlert @yo-less
                        @yo-less
                        i would like also got youre configuration.
                        • 7 / 7
