    Help... I need help installing 3rd party modules to Magic Mirror 2
    26 Posts 4 Posters 21.9k Views 3 Watching
      joeytuck
      Thank you for the replies. I did get Magic Mirror working for the initial setup prior to the 3rd party addition. I was missing the cd MMM-Traffic npm install portion. I did the npm install through Tools Open Folder in Terminal the first time. Not sure if that accomplishes the same goal? Itś still giving me the config.js error. Here is what I have for a config file with my personal info and API key copied and pasted directly from Google redacted.
      		module: "newsfeed",
      		position: "bottom_bar",
      			feeds: [
      					title: "New York Times",
      			showSourceTitle: true,
      			showPublishDate: true
      		module:´MMM-Traffic´,
      		position: ´bottom_right´
      		classes: ´dimmed medium´,
      		config:  {
      			api_key: ´
      mode: ´driving´,
      origin: ´´,
      destination: ´´,
      arrival_time: ´´,
      route_name: ´Home to Work´,
      changeColor: true,
      showgreen: false,
      limitYellow: 5,
      limitRed: 20,
      traffic_model: ´pessimistic´,
      interval: 120000,
      showWeekend: true
      allTime: true
        joeytuck
        		module: "newsfeed",
        			feeds: [
        		config:  {
        			api_key: ´´,
        			mode: ´driving´,
        			origin: ´´,
        			destination: ´´,
        			arrival_time: ´´,
        			changeColor: true,
        			showgreen: false,
        			limitYellow: 5,
        			limitRed: 20,
        			interval: 120000,
        			showWeekend: true
        			allTime: true
        B 1 Reply Last reply
          broberg Project Sponsor @joeytuck
          @joeytuck
          you are missing a , after showWeekend: true,
            joeytuck
            Good catch. I added the comma, saved the config file and tried pi@raspberrypi: ~/MagicMirror $ npm start To no avail. Do I need to do anything to the MMM-Traffic config.js file defaults?
              @joeytuck there is also another comma missing after the position line
                joeytuck
                Added that comma as well and itś still failing. Hereś what Iḿ getting.
                magicmirror@2.1.1 start /home/pi/MagicMirror
                sh run-start.sh
                Starting MagicMirror: v2.1.1
                Loading config …
                WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                Loading module helpers …
                No helper found for module: helloworld.
                All module helpers loaded.
                Starting server on port 8080 …
                Starting server op port 8080 …
                Server started …
                Sockets connected & modules started …
                Launching application.
                  joeytuck
                  This has been kicking my butt for the last day and a half. Learning a lot during the beating though. Do I need to add ’ ’ around numeric values as well?
                  A 1 Reply Last reply
                    joeytuck
                    Also, do I need to do anything to the MMM-Traffic.js file defaults like adding the api_key or changing values to match my selections on the config.js file? It seems like it’s really easy when I read the readme files and I’m looking forward to that being the case. Any help in taking a step in the right direction would be much appreciated.
                      joeytuck
                      Fixed the config errors. Turns out that if you put Drive, instead of Dr, it won’t recognize it. Unfortunately, now Magic Mirror is starting normally but I don’t see the MMM-Traffic module being displayed. I’ve tried multiple screen positions and nothing.
                      • A
                        Anhalter42 @joeytuck
                        @joeytuck said in Help... I need help installing 3rd party modules to Magic Mirror 2:
                        Usually you don’t. It distinguishes between (for example) the NUMBER 5 and the TEXT containing “5”. To be sure, you should look at the default values and just do it in the same way. For example, arrival_time seems to require " " even though the given example “1445” also could have been a plain number (I guess the reason is the leading 0 at for example “0800” which gets ignored when inputting as number)
                        Also, you got some strange quotation marks ´ ´. Until now I thought, only " " and ’ ’ were valid.
                        • A
                          No. To include the MMM-Traffic module you just have to include it in your config.js (providing all the required settings).
                          Where do you put Drive or Dr? In the readMe, possible values for “mode” are described to be ‘driving’, ‘walking’, ‘bicycling’, ‘transit’.
                          I suggest to delete or comment (adding // before the line) all not-required settings of MMM-Traffic at first to minimize possible sources for errors.
                            joeytuck
                            I’ve noticed that my quotation marks are a different font and wondered if that would be an issue? If I copy the quotation marks on the config file and use those in place of the ones that I key on my keyboard it works. I got the program to run but it’s not reflecting the addition of the module even though in the script it says that it’s installing and helpers are installing. As far as the Dr, vs. Drive that was in the addresses that I input. When doing for example Cherry Drive it gave me a config error. But Cherry Dr did not.
                              joeytuck
                              I removed all the forward // text not required for the code and MMM-Traffic still won’t populate on my mirror. Is there any code that limits it to only the factory module placement?
                              • A
                                Anhalter42
                                I suspect the quotation marks not only to be in a different font but to be different signs. This is indeed an issue since javascript defines strings by double (") and single quotes (') only (for reference see: https://www.w3schools.com/jsref/jsref_obj_string.asp).
                                So, just to be sure: After removing unnecessary properties you have a config.js that looks something like this minimal example
                                var config = {
                                  port: 8080,
                                			module: "alert",
                                			module: "updatenotification",
                                			position: "top_bar"
                                			module: 'MMM-Traffic',
                                			position: 'top_left',
                                				api_key: 'your_apikey_here',
                                				origin: '4 Pennsylvania Plaza, New York, NY 10001',
                                				destination: '1 MetLife Stadium Dr, East Rutherford, NJ 07073'
                                with some content from the default config.js at the “[…]” places, your API-key instead of " ‘your_apikey_here’ " and possibly some lines commented out by prepending “//”, correct?
                                The fact that the MM2 starts without error message about config.js indicates, that the issue is within the properties you set, i.e. the origin/destination or the API key.
                                Some suggestions:
                                1. Did you try to run it with default properties of the MMM-Traffic module (the ones I copied above)? Of course you have to input your own API key.
                                2. Did you check whether your API key is valid?
                                  2.a Is your API key configured correctly? As far as I know you have to login into google account and there assign the key to a project and get the access restrictions right.
                                  2.b In case you didn’t copy the key: have you checked for typos?
                                If you use default config.js parameters and example parameters from MMM-Traffic module it should run. From there, you can incrementally add your changes and figure out, which property leads to the issue.
                                  joeytuck
                                  module: ‘MMM-Traffic’,
                                  position: ‘bottom_right’,
                                  classes: ‘bright small’,
                                  api_key: ‘api key redacted’,
                                  mode: ‘driving’,
                                  origin: ‘origin redacted’,
                                  destination: ‘destination address redacted’,
                                  arrival_time: ‘’,
                                  route_name: ‘Home to Work’,
                                  changeColor: true,
                                  showGreen: false,
                                  limitYellow: 5,
                                  limitRed: 20,
                                  traffic_model: ‘pessimistic’,
                                  interval: 120000,
                                  showWeekend: true,
                                  allTime: false
                                  module: “newsfeed”,
                                  position: “bottom_bar”,
                                  feeds: [
                                  I copied my API key from Google directly but Iĺl register for another one and give that a shot.
                                  J 1 Reply Last reply
                                    joeytuck @joeytuck
                                    @joeytuck Tried a new API key and still no luck. Moved the module to a different portion of the config file just to see if there was somehow a limit on the amount of allowed modules that I haven’t been able to find. Still nothing.
                                      joeytuck @joeytuck
                                      @joeytuck Okay, so I deleted the MMM-Traffic folder and files that I had and did a new git clone and npm install for a fresh start. It works!! I’m sure I’m at fault for doing something stupid within the MMM-Traffic config file like changing a comma or something. Really happy about this one and I am very thankful for everyones help! I’ve learned quite a bit more about this than I thought I would need to. Onto wunderground!
                                        joeytuck
                                        Has anyone run into the issue where you´ve installed MMM-WunderGround with your api key and pws and it just says
                                        ¨loading¨ on the magic mirror screen?
                                        Mykle1M 1 Reply Last reply
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @joeytuck
                                          @joeytuck
                                          That usually means one or more of the following:
                                          Your API key is entered incorrectly.
                                          Your API key is not valid.
                                          Your pws is entered incorrectly.
                                          Your pws is down. Choose another.
                                          I’ll test your pws on my machine if you tell me which one you are using.
                                            joeytuck @Mykle1
                                            @Mykle1 This might sound really ignorant but do I actually need PWS equipment to run this module? Can I not just receive and not transmit? My PWS is KTNMADIS13
