    Help... I need help installing 3rd party modules to Magic Mirror 2
    26 Posts 4 Posters 21.9k Views 3 Watching
    • A
      Anhalter42
      I suspect the quotation marks not only to be in a different font but to be different signs. This is indeed an issue since javascript defines strings by double (") and single quotes (') only (for reference see: https://www.w3schools.com/jsref/jsref_obj_string.asp).
      So, just to be sure: After removing unnecessary properties you have a config.js that looks something like this minimal example
      var config = {
        port: 8080,
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: 'MMM-Traffic',
      			position: 'top_left',
      				api_key: 'your_apikey_here',
      				origin: '4 Pennsylvania Plaza, New York, NY 10001',
      				destination: '1 MetLife Stadium Dr, East Rutherford, NJ 07073'
      with some content from the default config.js at the “[…]” places, your API-key instead of " ‘your_apikey_here’ " and possibly some lines commented out by prepending “//”, correct?
      The fact that the MM2 starts without error message about config.js indicates, that the issue is within the properties you set, i.e. the origin/destination or the API key.
      Some suggestions:
      1. Did you try to run it with default properties of the MMM-Traffic module (the ones I copied above)? Of course you have to input your own API key.
      2. Did you check whether your API key is valid?
        2.a Is your API key configured correctly? As far as I know you have to login into google account and there assign the key to a project and get the access restrictions right.
        2.b In case you didn’t copy the key: have you checked for typos?
      If you use default config.js parameters and example parameters from MMM-Traffic module it should run. From there, you can incrementally add your changes and figure out, which property leads to the issue.
        joeytuck
        module: ‘MMM-Traffic’,
        position: ‘bottom_right’,
        classes: ‘bright small’,
        api_key: ‘api key redacted’,
        mode: ‘driving’,
        origin: ‘origin redacted’,
        destination: ‘destination address redacted’,
        arrival_time: ‘’,
        route_name: ‘Home to Work’,
        changeColor: true,
        showGreen: false,
        limitYellow: 5,
        limitRed: 20,
        traffic_model: ‘pessimistic’,
        interval: 120000,
        showWeekend: true,
        allTime: false
        module: “newsfeed”,
        position: “bottom_bar”,
        feeds: [
        I copied my API key from Google directly but Iĺl register for another one and give that a shot.
        J 1 Reply Last reply
          joeytuck @joeytuck
          @joeytuck Tried a new API key and still no luck. Moved the module to a different portion of the config file just to see if there was somehow a limit on the amount of allowed modules that I haven’t been able to find. Still nothing.
            joeytuck @joeytuck
            @joeytuck Okay, so I deleted the MMM-Traffic folder and files that I had and did a new git clone and npm install for a fresh start. It works!! I’m sure I’m at fault for doing something stupid within the MMM-Traffic config file like changing a comma or something. Really happy about this one and I am very thankful for everyones help! I’ve learned quite a bit more about this than I thought I would need to. Onto wunderground!
              joeytuck
              Has anyone run into the issue where you´ve installed MMM-WunderGround with your api key and pws and it just says
              ¨loading¨ on the magic mirror screen?
              Mykle1M 1 Reply Last reply
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @joeytuck
                @joeytuck
                That usually means one or more of the following:
                Your API key is entered incorrectly.
                Your API key is not valid.
                Your pws is entered incorrectly.
                Your pws is down. Choose another.
                I’ll test your pws on my machine if you tell me which one you are using.
                  joeytuck @Mykle1
                  @Mykle1 This might sound really ignorant but do I actually need PWS equipment to run this module? Can I not just receive and not transmit? My PWS is KTNMADIS13
                  • Mykle1M
                    @joeytuck said in Help... I need help installing 3rd party modules to Magic Mirror 2:
                    No, you don’t need your own PWS equipment. I meant the pws that you chose from WeatherUnderground. It would be cool to have your own though.
                    The PWS that you gave me (KTNMADIS13) is either down, or not valid. I tested it and it does not work. As soon as I returned mine to my config, it fired right up.
                    You can try mine as a test. This is the whole line from the config:
                    pws: 'pws:KNYNEWYO103',
                    In any case, you’ll have to choose another pws from the WunderMap at WeatherUnderground because yours is not working. If you can’t manage that then I can get one for you and test it. I would need the name of your country, city, town, neighborhood if that is the case. Or the name of your nearest airport. They all have weather stations.
                      joeytuck
                      I found a pws nearby and everything is working great now. Thanks for the help!!
                      • Mykle1M
                        You’re welcome. :thumbsup:
