    Black screen + access Denied trough web
    11 Posts 4 Posters 6.3k Views 3 Watching
      reddevel75
      Thank you for you reaction.
      First off thanks for helping out with the connecting that problem is solved now.
      Still I have the problem that nothing seems to work because it’s still black screen…
      here is my config.js
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
              port: 8080,
              ipWhitelist: [ ],
              language: "nl",
              timeFormat: 24,
              units: "metric",
                              module: "alert",
                              module: "updatenotification",
                              position: "top_bar"
                              module: "clock",
                              position: "top_left"
                              header: "US Holidays",
                                                      symbol: "calendar-check-o ",
                              module: "compliments",
                              position: "lower_third"
                              module: "currentweather",
                                      locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                              module: "weatherforecast",
                              header: "Weather Forecast",
                                      locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                              module: "newsfeed",
                              position: "bottom_bar",
                                      feeds: [
                                                      title: "New York Times",
                                      showSourceTitle: true,
                                      showPublishDate: true
      hopefully you can find the problem…
        reddevel75
        when just programming one module i get this error: 0_1492796484347_Schermafbeelding 2017-04-21 om 19.39.56.png
        brobergB Mykle1M 2 Replies Last reply Reply Quote 0
        • brobergB Offline
          broberg Project Sponsor @reddevel75
          @reddevel75
          could you please try this config?
           * MIT Licensed.
          var config = {
          	port: 8080,
          	ipWhitelist: [], // Set [] to allow all IP addresses.
          	language: "en",
          	timeFormat: 24,
          	units: "metric",
          			module: "clock",
          But it seems you have other issues, it tries to load a module that doesn’t exist (alarm module).
            Mykle1 Project Sponsor Module Developer @reddevel75
            @reddevel75
            What module are your programming? Do you mean you are trying to add a module to the default config. I just loaded your config from above, adding my API key, and it works correctly. Can you explain a little better what you are trying to do, please?
              Mykle1 Project Sponsor Module Developer @broberg
              @broberg said in Black screen + access Denied trough web:
              Ah, you beat me! :thumbsup:
                reddevel75
                Just trying to get it running for the first time nothing custom stuff.
                when i upload you code i get this problem.
                Maybe a fresh install will do the trick ?
                • brobergB Offline
                  @reddevel75 did you do the npm install in the magicmirror folder after you cloned the magicmirror?
                    reddevel75
                    just did a fresh install, now everything seems to work :)
                    • N Offline
                      n8ms
                      I am getting the same issue with the black screen. When I access via localhost:8080, I get the default screen that tells you to create a config file. I was using a config.js file from an old build I did that worked, but I replaced it with the config file posted above and I get the same issue.
                      pi@n8MM:~/MagicMirror $ npm start
                      > magicmirror@2.1.1 start /home/pi/MagicMirror
                      > sh run-start.sh
                      Starting MagicMirror: v2.1.1
                      Loading config ...
                      Loading module helpers ...
                      All module helpers loaded.
                      Starting server op port 8080 ...
                      You're using a full whitelist configuration to allow for all IPs
                      Server started ...
                      Launching application.
                      ^C
                      pi@n8MM:~/MagicMirror $ node -v
                      v7.9.0
                      pi@n8MM:~/MagicMirror $ electron -v
                      v1.3.15
