Black screen + access Denied trough web
11 Posts 4 Posters 5.4k Views 3 Watching
    reddevel75
    Hello ,
    Im complete new to magicmirror so maybe im seeing something not right.
    First installed everything and after npm start magicmirror Launch and its Black.screen.
    Then intro to acces it trough the web but then i get acces denied.
    I try to delete modules and to charge the config file with different ip adres. But nothing works. Does anybody have a sollotion for me.
    Thnak you !
    B 1 Reply Last reply Apr 20, 2017, 9:19 PM Reply Quote 0
      broberg Project Sponsor @reddevel75
      @reddevel75 use this guide for ip whitelist to access the mirror from another computer :
      https://forum.magicmirror.builders/topic/1326/ipwhitelist-howto
      OR change the config to ipWhitelist: [ ], To allow every ip to access the mirror
      Please post you config file content so we can see if there is any issues with it (but remove any personal api-keys before you post)
        reddevel75
        Thank you for you reaction.
        First off thanks for helping out with the connecting that problem is solved now.
        Still I have the problem that nothing seems to work because it’s still black screen…
        here is my config.js
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
                port: 8080,
                ipWhitelist: [ ],
                language: "nl",
                timeFormat: 24,
                units: "metric",
                                module: "alert",
                                module: "updatenotification",
                                position: "top_bar"
                                module: "clock",
                                position: "top_left"
                                header: "US Holidays",
                                                        symbol: "calendar-check-o ",
                                module: "compliments",
                                position: "lower_third"
                                module: "currentweather",
                                        locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                module: "weatherforecast",
                                header: "Weather Forecast",
                                        locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                                module: "newsfeed",
                                position: "bottom_bar",
                                        feeds: [
                                                        title: "New York Times",
                                        showSourceTitle: true,
                                        showPublishDate: true
        hopefully you can find the problem…
          reddevel75
          when just programming one module i get this error: 0_1492796484347_Schermafbeelding 2017-04-21 om 19.39.56.png
          B M 2 Replies Last reply Apr 21, 2017, 7:40 PM Reply Quote 0
            @reddevel75
            could you please try this config?
             * MIT Licensed.
            var config = {
            	port: 8080,
            	ipWhitelist: [], // Set [] to allow all IP addresses.
            	language: "en",
            	timeFormat: 24,
            	units: "metric",
            			module: "clock",
            But it seems you have other issues, it tries to load a module that doesn’t exist (alarm module).
            M 1 Reply Last reply Apr 21, 2017, 7:43 PM Reply Quote 0
              Mykle1 Project Sponsor Module Developer @reddevel75
              @reddevel75
              What module are your programming? Do you mean you are trying to add a module to the default config. I just loaded your config from above, adding my API key, and it works correctly. Can you explain a little better what you are trying to do, please?
                Mykle1 Project Sponsor Module Developer @broberg
                @broberg said in Black screen + access Denied trough web:
                Ah, you beat me! :thumbsup:
                  reddevel75
                  Just trying to get it running for the first time nothing custom stuff.
                  when i upload you code i get this problem.
                  Maybe a fresh install will do the trick ?
                  B 1 Reply Last reply Apr 22, 2017, 2:56 PM Reply Quote 0
                    @reddevel75 did you do the npm install in the magicmirror folder after you cloned the magicmirror?
                      reddevel75
                      just did a fresh install, now everything seems to work :)
